Which is better in low light D5100 or 5200? DXO likes 5100
Started Jun 20, 2013 | Discussions
photo perzon
photo perzon Veteran Member • Posts: 4,175
5100 has better score for low light
for pictures of smiling dogs not moving in low light with 1.8 prime
what about the 5200 with no AA?
 photo perzon's gear list:photo perzon's gear list
Sony Cyber-shot DSC-RX100 III Olympus PEN E-PL5 Fujifilm X-A1 Panasonic Lumix DMC-GM1
Horshack
Horshack Veteran Member • Posts: 5,803
D5100 = 1183, D5200 = 1284 for low-light ISO score
Which numbers were you looking at?
Terry Vickers
Terry Vickers Regular Member • Posts: 332
Re: D5100 = 1183, D5200 = 1284 for low-light ISO score
Yeah. Horshack has the figures right. There is about .1 stop difference in favour of the D5200.
Not worth worrying about in the real world. But DXO certainly thinks the D5200 is marginally better.
The numbers mean that ISO 1183 on the D5100 is equivalent to ISO 1284 on the D5200.
The D5200 is marginally better because it allows you to shoot at a slightly higher ISO to give (roughly) the same picture quality.
 Terry Vickers's gear list:Terry Vickers's gear list
Nikon D3100 Nikon D7000 Nikon D5200 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +7 more
Horshack
The D5200's advantage is a bit more than reflected in DxO's composite low-light score. The 18% SNR difference is tiny but the D5200 has about a 2/3 stop advantage in the shadows at High ISO.
kgbruce01
kgbruce01 Senior Member • Posts: 1,245
This one is better...
... The one in the hands of the photographer that shoots and exposes better.
mosswings
mosswings Veteran Member • Posts: 7,292
Is this reflected in their measurements or your own?  It's certainly not in their graphs...more smoothing going on, AA filter or otherwise? High ISO is ... what?  3200? 6400?
 mosswings's gear list:mosswings's gear list
Olympus XZ-1 Olympus Stylus 1 Nikon D90 Nikon D7100 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +5 more
nfpotter
nfpotter Veteran Member • Posts: 4,080
Re: Which is better in low light D5100 or 5200? DXO likes 5100
Look at similar pictures taken with the 2 cameras.  Pick which one you like the look of better.  DXO is half crap, IMO.
Horshack
You wont see it on the 18% SNR graphs. Look at either at the bottom of the Full SNR graphs for High ISO (shadows) or the DR graphs for DR. They both tell the same story about the D5200's lower noise in the shadows.
mosswings
Ah.  One has to flip rapidly between browser panes to see it. There is a bit more rolloff at ISO3200 below 1%, but things match up again at higher ISOs; there are small differences throughout the range that would make me want to see results from a larger sample size.  At least for the two cameras tested there is a difference, but I would wonder if it would hold true in the aggregate.
coudet
coudet Veteran Member • Posts: 3,867
More.
KennyXL
KennyXL Contributing Member • Posts: 710
I don't know where you got your information, but the D5200 does have an AA filter.  The D7100 does not have an AA filter.
 KennyXL's gear list:KennyXL's gear list
Sony RX100 Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 28-300mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 85mm f/1.8G +3 more
jonikon
jonikon Veteran Member • Posts: 5,739
DxOMark sensor scores are often misleading because they do not compare image quality, but rather only potential IQ based on the RAW file data only It is only after the the RAW image has been processed with all it's algorithmic compromises  that a real world evaluation of the IQ can begin. Different RAW converters will produce different real world IQ results.
Personally, I prefer the real world image output of the 16MP sesnor to that of the 24MP because it does not have nearly as much of the high frequency noise  that the 24MP sensor has. Removing the high frequency noise in the 24MP images will reduce the detail to a point below that of the 16MP sensor, so if you can look beyond the HF noise then the 24MP sensor would be your best choice, but if you can not, then the 16MP sensor would please you more.  In the final analysis you should trust your own eye and decide what you like best in terms of IQ based on real image output, and just use the DxOMark scores as one piece of the IQ comparison conundrum.
-Jon
 jonikon's gear list:jonikon's gear list
Nikon Coolpix A Nikon D7000 Nikon 1 V1 Nikon 1 V2 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +11 more
Nexu1
Nexu1 Senior Member • Posts: 2,556
D5100 vs D5200 in low light is splitting hairs.  Negligible difference.
Horshack
My D5100 vs D5200 High ISO comparison
Here's a High ISO comp I did myself:
http://www.dpreview.com/forums/post/51140958
David Lal
David Lal Veteran Member • Posts: 8,525
SB800!
Don't b*gger about with 'available light' and muddy shadows. Whatever the camera body, pop on a SB800/SB900, perhaps with another one or maybe an SB26  on delayed slave auto-ranging mode in the background. As for F1.8 and even bigger apertures think what's going to happen to the depth of field.
David
