Power-On by USB Mouse? ASUS MB
Started Jun 20, 2013 | Discussions
Robert Schoner Contributing Member • Posts: 996
Hi,
I have anew ASUS P8Z77-V LK motherboard. Is there any way to power on by USB mouse. Seems like it will only power-on by PS/2 and nobody seems to carry PS/2 cordless mouse any more.
Thanks,
Bob Schoner
SushiEater
SushiEater Senior Member • Posts: 4,237
Re: Power-On by USB Mouse? ASUS MB
What do you mean Power On by the mouse?
Do you mean awaken from sleep?
 SushiEater's gear list:SushiEater's gear list
Nikon D800E Nikon D810 Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM Sigma 12-24mm F4.5-5.6 II DG HSM +10 more
Robert Schoner OP Contributing Member • Posts: 996
Hi,
I usually power off at night and power on in the morning. The tower will be under a desk so it's not convenient to reach the on button. In the past I had no trouble with ps/2 mouse but this machine has a combo ps/2 port so I can't do both mouse and keyboard. I wanted a new mouse/keyboard but all I can find are USB.  I suppose I could use old ps/2 mouse and new usb keyboard. I think it will wake from sleep by the usb mouse but not a cold start.
Bob Schoner
Tom_N Forum Pro • Posts: 10,021
Robert Schoner wrote:
Hi,
When Apple was still using ADB keyboards, several Macs had this type of power switch on the keyboard.  After Apple went to USB, none did.  I believe people asked "why?", and someone (not sure if it was Apple) said that the USB specifications prohibit the power switch feature.
If there is such a restriction on USB keyboards, I would assume that it also applies to USB mice.
Just about any USB keyboard or mouse can, however, trigger "wake from sleep on input events".
Glenn Haley Senior Member • Posts: 1,206
I used my PS2 keyboard to start my computer until I replaced it with a USB keyboard and I miss that feature too.
It should be possible to disconnect your computer case power switch from the motherboard and replace it with a lead running out of the case to switch box near your mouse/keyboard. If your case has external outputs such as a headset socket that lead out could be used for the power switch input/output source. While you're at it you could also run a lead outs to display an IDE LED and or Power LED.
Hi,
Thanks for the replies. I was afraid I was going to lose this feature. I might try doing a mix of new keyboard with the old PS/2 mouse.
Bob Schoner
han47 Regular Member • Posts: 250
Hello,
dont know your board, but for mine you have to enable this function in the motherboard BIOS.
I`m using a Gigabyte board.
Ciao, Han
EDIT : I`m using a USB mouse so the problem is not USB.
