Has anyone here tried the Tamron 200-500mm f/5-6,3 super tele?
Started Jun 19, 2013 | Discussions
Petroglyph
Petroglyph Senior Member • Posts: 4,806
If so what were your impressions of this lens?
Cheers.
 Petroglyph's gear list:Petroglyph's gear list
Pentax K-3 Sony Alpha 7R II Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 43mm F1.9 Limited +4 more
greeman
greeman Regular Member • Posts: 324
Re: Has anyone here tried the Tamron 200-500mm f/5-6,3 super tele?
I have never used this lens, but have looked at a lot of work with this lens that looks good.  HERE is a link to some work by a guy that seems to have this lens figured out.
Petroglyph
Petroglyph OP Senior Member • Posts: 4,806
Thank you.  I'll take a look.
Kris in CT
Kris in CT Senior Member • Posts: 2,209
Cheers.
I shot with one for my first full year in bird photography. It is incredibly light for a 500 consumer lens which makes it great for hand-holding. At first I shot it with a D90 and the AF system didn't work so well with it. I ended up getting a D300 and once I had it fine tuned it performs very well for what it is.. I found that it really performs best under 150 Feet, but I'm a birder, with larger objects it holds up better. I recently got a Tokina 300 F2.8 and I shoot with that now. I'm still thinking about selling the Tamron but haven't yet. Here's my flickr gallery shot with the Tamron http://www.flickr.com/search/?q=Tamron+200+500&w=63476818%40N08&s=rec
Here's my best...Audubon Magazine 2012 Top 100 and Photo of the Year on The Photo Forum.. Taken with the Tamron 200-500
A few more from my gallery here...
My sober voyage into bird photography
http://www.facebook.com/KristoferRowePhotography
 Kris in CT's gear list:Kris in CT's gear list
Canon EOS-1D Mark IV Canon EOS 7D Mark II Canon EF 300mm f/4.0L IS USM Canon EF 500mm f/4.0L IS USM Sigma 150mm F2.8 EX DG Macro HSM +1 more
photodgm
photodgm Regular Member • Posts: 125
Have used and still own this lens. Very light for 500mm, needs good motor in camera for AF D300 is fine, from memory softer beyond 470mm, optically good BUT needs good light to impress.
It's all about light
ABA DABA
ABA DABA Veteran Member • Posts: 3,063
I have one and use it for airshows. The light weight helps quite a bit, image quality is also good.
ABA DABA
 ABA DABA's gear list:ABA DABA's gear list
Nikon D500
richard stern
richard stern Contributing Member • Posts: 511
I had one a few years ago when I had a D70s, and loved it. Now I use a D7000 and 300 f/4 AF-S and 1.7TC, which is sharper, but I miss the light weight and zoom of the Tammy. Here is a pic shot with the D70s and Tammy, which came 1st in a DpReview Challenge.
Richard (rb_stern),
www.pbase.com/rb_stern
richard-s.smugmug.com
bflood
bflood Senior Member • Posts: 1,013
I have the Tamron 200-500 and use it with a D7000. At first I was disappointed with the lens, but gradually I learned that 1) like Kris in CT, it gives best results for subjects within about 50 yards, and 2) I needed a better support. I can't hand hold a lens that long, and always use a tripod, but that wasn't enough. A tripod/head setup that works well for shorter lenses and has the weight-carrying capacity for the longer lens may not be a satisfactory setup for a long lens.  I was using a Manfrotto tripod (perfectly adequate) with a Manfrotto 496 ball head that was inadequate for a 400 or 500 mm lens. The head has sufficient weight carrying ability, but the quick disconnect plate was about 1.5" square, too small to provide a vibration-free platform for a long lens. I moved to the Manfrotto 054 head with the Q5 plate. That plate is about 2" wide and about 3.5" long, which give a much more stable platform for long lenses. My image sharpness improved dramatically.
As others have said, the lens is very light for its 500 mm length, so if you have good hand-holding technique, you may find it won't necessarily require a tripod for you. It gets noticeably softer for subjects over 50 yards away, but I understand this is common among long zooms.  My 80-400 VR does the same thing.
 bflood's gear list:bflood's gear list
Nikon D70 Nikon D80 Nikon D7000 Nikon D610 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +8 more
