Lens for damselflies, dragonflies, butterflies ..
Started Jun 17, 2013 | Discussions
sicherheit Regular Member • Posts: 496
I currently use the Nikkor 105mm VR on a D5100 to take most of my insect shots but need a bit more distance for the larger insects e.g. damselflies. I need to able to fill the frame as the main purpose is identification and I try to get whole insect in focus head to tail so that the markings can be seen, therefore needs to be sharp as well.
Looking at recommendations it would appear that Sigma 180mm or 150mm (with 1.4 TC) may be the way to go but the weight puts me off a bit as the majority of the images I take are hand held.
I was thinking that the Nikon 70-200mm f4 may be a viable alternative to dedicated macro lenses as I have used the Nikon 70-300mm but found that the results can be a bit soft especially between 200 and 300mm.
Any thoughts?
John
JohnB
http://farm4.static.flickr.com/3182/2298450593_a65e0ee642_m.jpg
One photo out of focus is a mistake, ten photos out of focus are an experimentation, one hundred photos out of focus are a style. Anon
Nikon D5100
Cytokine Contributing Member • Posts: 661
Re: Lens for damselflies, dragonflies, butterflies ..
Any thoughts?
John
The 70-200mm f4 looks good on paper, close focussing 1M,  (1:3.6) Closer than the f2.8 and light.
John
sicherheit OP Regular Member • Posts: 496
John
Funnily enough that was my thinking.
John
JohnB
evan47
evan47 Contributing Member • Posts: 998
when i go on a hunt for dragonflys/butterflys i prefer to use either the sigma 150, non os. sometimes with the sigma 1.4tc but more often without. or more recently with the nikon 300mm f4 af-s with the nikon tc 14 ii.
mounted on a gripped d7000, with a manfrotto 680b monopod and 234rc head to help keep things stable.
when i am having a good day and the creatures let me get close i use the nikon 105 af-d which i keep in my bag mounted on my spare gripped d7000.
 evan47's gear list:evan47's gear list
Nikon D7000 Nikon D7100 Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF Micro-Nikkor 60mm f/2.8D Nikon AF-S Teleconverter TC-14E II +5 more
Thanks evan
I've been finding just lately that the ones I want to photograph are out of reach of the 105. When they behave and come close then the 105 does just fine. Hadn't thought of the 300mm f4 (AF-S but no VR) so I would need to use the monopod a bit more than I do, reasonably priced too currently. How does the AF perform with the TC attached to the 300mm?
John
JohnB
labalaba Contributing Member • Posts: 510
here's some comparisons, if you are prepared to click through the flickr set:http://www.dpreview.com/forums/post/50439961
bottom line: the 70-200 f4 is not bad, better than the 70-300 VR, but not as good at closest focus as other options. It's a great lens otherwise
The simplest option you have is a TC. Both the 1.7x and 2.0x work reasonably well with 105VR (on my D700).
300 AFS f4 is really good at close focus distances. I have hand held this lens a lot, using D5100, D7100, & D700. If you think your light is not good enough to keep the shutter speed up, I suggest a flash and diffuser; I would find a tripod limiting for macro in the field, since you will not get to choose where to plant it.
ERROL FLYNN Forum Member • Posts: 64
I have just acquired the Sigma 180mm F2.8 OS, bit heavy to hand hold after a while, but works fine with a decent monopod.
 ERROL FLYNN's gear list:ERROL FLYNN's gear list
Nikon D810 Nikon AF-S Nikkor 400mm f/2.8G ED VR II Sigma APO Macro 180mm F2.8 EX DG OS HSM Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR Tamron 15-30mm F2.8 +1 more
Thanks for the link and the comparisons really useful.
JohnB
evan47
af is adequate, it helps to pre-focus though. upping iso or using iso auto helps too.
please view full screen to check details.
sicherheit wrote:
Thanks evan
John
JohnB
Thanks for that, nice examples too. I do tend to use Auto ISO but limit it to 800 on the D5100.
That's a nice Orange Tip especially as it's on one of its favourite food plants.
I think I'm being more drawn to the 70-200 f4 though as it is relatively light and might be a bit more versatile. I will try the 300mm out to see how it feels on the camera.
JohnB
