Soap bubbles and strange rendering of edges
Started Jun 17, 2013 | Discussions
bzx
bzx
Regular MemberPosts: 215Gear list
Jun 17, 2013
Hi all,
Here's a picture I made with a NEX-5 and a manual lens, and while checking if I got the bubble sharp (apparently not so much) I noticed a strange rendering of the areas around the top edge of the bubble. This appears similarly on other bubble shots from the same evening.
Could anyone explain what is the reason for this? The only explanation that I can think of is that as the bubble moves and changes shape, its surfaces produce some micro splashes and they're so thin that the sensor gets fooled and can't render the area properly.. Not sure if that makes any sense I would appreciate a rational answer.
100% crop - enhanced a bit to emphasize the behaviour
t[+]m
 bzx's gear list:bzx's gear list
Sony Alpha NEX-5 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake +2 more
Sony Alpha NEX-5
adymitruk
Contributing MemberPosts: 500Gear list
Re: Soap bubbles and strange rendering of edges
In reply to bzx, Jun 17, 2013
Cool phenomenon! Must be something about droplets being emitted off of the bubble. No idea why that would happen, but you have evidence that it's happening!
 adymitruk's gear list:adymitruk's gear list
Sony Alpha NEX-7 Sony a6000 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Tamron SP AF 200-500mm F/5-6.3 Di LD (IF) +12 more
bzx
bzx OP
bump.. anyone could try to explain please?<nt>
In reply to bzx, Jun 30, 2013
t[+]m
SQLGuy
Senior MemberPosts: 3,696Gear list
Re: bump.. anyone could try to explain please?<nt>
JPEG is a lossy format. Have you tried manually cropping and converting from the RAW image?
Nex-7 with kit lenses, Contax G 35, and a number of legacy lenses (mostly Canon FD)
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Nikon D200 A3000 Sony Alpha 7 Nikon AF-S DX Nikkor 35mm f/1.8G +2 more
bzx
bzx OP
this is RAW
In reply to SQLGuy, Jun 30, 2013
these are crops from RAW image in Lightroom, plus this type of "lossyness" doesn't look like characterictics JPEG.
thanks for looking,
t[+]m
