D7100 1.3x crop - Is it my math or...
Started Jun 17, 2013 | Questions
Suhas Sudhakar Kulkarni
Suhas Sudhakar Kulkarni Regular Member • Posts: 259
Nikon claims on their website that 1.3x crop gives 15.4 MP image.
http://imaging.nikon.com/lineup/dslr/d7100/features01.htm#a10
However, If I calculate:
1.3x1.3=1.69
24/1.69=14.20MP approx.
Which one is correct?
Also 1.5x1.3 would give total crop of 1.95x and not 2x as specified by Nikon.
Suhas
website: photo.net/photos/suhaskulkarni
Nikon D7100
BirgerH
BirgerH Senior Member • Posts: 4,091
Re: D7100 1.3x crop - Is it my math or...
1.3x1.3=1.69
Suhas
Because:
1.5 crop is not exactly 1.5 crop. With the D7100 it is 1.53518 if you use the relation of 24 x 36mm.
1.3 crop is not exactly 1.3 crop. In relation to 24 x 36 mm it is 1.91744 (aprox. 2)
The "1.3" crop will then be the square root of the Square of 1.9744 divided by the Square of 1.53518, which wil be 1.2490, aprox. 1.3
And then you got aprox. 15.4 MP (24/1.249/1.249).
Thats the math - but why bother - go use it.
BirgerH.
 BirgerH's gear list:BirgerH's gear list
Nikon D90 Nikon D7000 Nikon D800 Nikon AF Nikkor 85mm f/1.8D Tamron SP AF 11-18mm F/4.5-5.6 Di II LD Aspherical (IF) +14 more
BirgerH
1.3x1.3=1.69
Suhas
Because:
BirgerH.
Sorry, missed a 1 in "Square 1.91744"
Suhas Sudhakar Kulkarni OP Regular Member • Posts: 259
Thanks, that explains. So it is actually 1.917.. crop from full frame and not 2x crop.
Why bother?? Just out of curiosity, I was comparing with Sony smart teleconverter which gives you 2x crop with 12MP image (on A65 / A77).
Suhas
lock
lock Veteran Member • Posts: 6,178
not even that
Look at the hor and vert. Number of pixels. It is a factor of 1.25.
Lock
BirgerH
Re: not even that
Lock
Okay - didn't do that.
It makes a different of size-crop and pixel-crop. Still I can't see any real problem if you want to make Photos.
The D7100 has this extra Facility of cropping - go use it or do not. Math will not give you better Pictures.
BirgerH.
lock
Of course!
By all means, use it.
Lock
BirgerH
Re: not even that
A factor of 1.25 is in my eyes very close to a factor of 1.249.
jimoyer
jimoyer Senior Member • Posts: 1,853
This thread makes my eyes bleed......
 jimoyer's gear list:jimoyer's gear list
Nikon 1 V2 Nikon D7100 Nikon D4S Nikon 1 J5 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +9 more
Red5TX
Red5TX Senior Member • Posts: 1,586
Why bother??
Because in crop mode the autofocus points cover virtually the entire frame.
And if you shoot in jpeg + crop, you have (I believe) unlimited buffer depth. There are limited circumstances where those two factors (full af coverage and limitless buffer) might be very handy in combination.
Erik the Red
Erik the Red Regular Member • Posts: 263
4800 x 3200 = 15,360,000 pixels, for what it's worth.
