View NX2 help
Started Jun 16, 2013 | Discussions
Iain G Foulds
Iain G Foulds Senior Member • Posts: 2,330
View NX2 help
Okay, trying View NX2, transferred photos to the updated program. I can open a RAW photo in the program, but I can't get the sliders to move...?
 Iain G Foulds's gear list:Iain G Foulds's gear list
Tamron SP 150-600mm F/5-6.3 Di VC USD Nikon D7200
Skiies
Skiies Regular Member • Posts: 154
Re: View NX2 help
can you see the images on screen? And the Adjustments panel on the right hand side? If you are using a new camera like 7100 you may have to update NX2 to get the program to work correctly with NX2
BirgerH
BirgerH Senior Member • Posts: 4,110
Re: View NX2 help
The last version, and the one you need to open Pictures from D7100 properly, is ver. 2.7.5.
You can get that from Nikon's homepage.
BirgerH
 BirgerH's gear list:BirgerH's gear list
Nikon D90 Nikon D7000 Nikon D800 Nikon AF Nikkor 85mm f/1.8D Tamron SP AF 11-18mm F/4.5-5.6 Di II LD Aspherical (IF) +14 more
RudyPohl
RudyPohl Senior Member • Posts: 3,729
Re: View NX2 help
Hi Iain:
I don't know if this is your issue but if you locked your photos in the camera to make sure that you don't delete them, the sliders won't move in View NX2.... they are greyed out and disabled/
Rudy
Richy6771
Richy6771 Contributing Member • Posts: 721
Re: View NX2 help
I found that View NX2 took a lot of computing memory. My old laptop would constantly crash, so I had to add memory.
 Richy6771's gear list:Richy6771's gear list
Nikon D7000 Nikon D800 Nikon D600 +1 more
ImFree
ImFree New Member • Posts: 3
Re: View NX2 help
Be sure to use the Transfer utility in ViewNX2, not the old standalone version.  I had the same problem, and it was caused by using the old Nikon Transfer V1, which I made sure to uninstall.
Mark
arbie1
arbie1 Regular Member • Posts: 228
Re: View NX2 help
If you've previously made adjustments to the RAW with CNX2, you can't do anymore adjustments in VNX2. The pics that have been worked on in CNX2 will have the U-Point icon in the thumbnails file# area.
Iain G Foulds
Iain G Foulds OP Senior Member • Posts: 2,330
Thanks to all!
Thanks to all... off and running!
The version that I had was 2.7.2. I clicked on "update" in the program, but it said that there were no updates. So, as recommended, I went to the Nikon site, and version 2.7.6 was available. Installed, and the sliders work perfectly (and the computer doesn't crash).
My first RAW picture. One small step...
BirgerH
Re: Thanks to all!
Thats an QC issue - If you got Windows, there has to be at least one chrash - and two reboots.
Bill won't like it...
