DPM-colors reviewed
Started Jun 14, 2013 | Discussions
Guenter Borgemeister
Senior MemberPosts: 1,275Gear list
DPM-colors reviewed
Jun 14, 2013
I took images with all WB-settings except bulb with all the DPM´s, all settings and colorspaces equal.
Subject was a print of an image in a window-lit room, all cameras set to 0.6sec. f4 ISO100 sRGB, shots taken in Camera-JPG-mode.
I just changed the distance to the print according to the different focallengths.
My conclusion is, the difference isn´t that strong anymore. Unlike before the recent FW-update, DP1 and DP2 are about equal, DP3 still has nicer colors with more saturation, even in auto or custom WB.
 Guenter Borgemeister's gear list:Guenter Borgemeister's gear list
Sigma 18-35mm F1.8 DC HSM | A
Sigma DP1 Sigma DP2
BobNL
Veteran MemberPosts: 5,027Gear list
Re: DPM-colors reviewed
In reply to Guenter Borgemeister, Jun 14, 2013
thanks, looks indeed much better. not great yet but much better Updating my firmwares now!
Bob van Ooik
V-studio
http://vstudio-magazine.de/
http://www.x3magazine.com/
http://www.flickr.com/photos/bobnl/
 BobNL's gear list:BobNL's gear list
Sigma DP1 Sigma DP1 Merrill Sigma DP3 Merrill Sigma dp2 Quattro Nikon D700 +3 more
Johan Borg
Senior MemberPosts: 2,276
After taking a couple of before/after shots with the DP2M and compared it to DP3M on older firmware, I must agree: The DP3M still has a bit richer colors than the DP2M, at least in the shadows (see lower left corner).
DP3M (firmware 1.01, Sunlight WB)
DP2M (firmware 1.05, Sunlight WB)
yvind Strm
Veteran MemberPosts: 4,130
Nice! Very useful.
BTW: I recall you did a great job calibrating your SD14s some years ago, and was using the 144 patch to calibrate precisely.
How do the SD1 and the DPmx models fare in regard to that. Can they be calibrated with a 16 patch?
Kind regards
Øyvind
Kendall Helmstetter Gelner
Forum ProPosts: 19,204Gear list
Missing vector - color mode?
In reply to Guenter Borgemeister, Jun 16, 2013
I appreciate your time taken in putting that all together.
However one key aspect is not clear - what color mode what used to process?  To my mind that can have as much to say about the color output as the white balance.
Ideally, it would be awesome to see a sheet like you produced for each color mode...  I know that is a lot of extra work, do you have the raw files for that shot somewhere?
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
In reply to yvind Strm, Jun 16, 2013
yvind Strm wrote:
Nice! Very useful.
Kind regards
Øyvind
Hi Øyvind, I didn´t try calibrating the DP´s yet, should I ever do, I´ll let you know.
Re: Missing vector - color mode?
In reply to Kendall Helmstetter Gelner, Jun 16, 2013
Hi Kendall, you are right, forgot about that.
Color mode on all shots was set to neutral.
If you want to spent a day doing as you proposed, I will be happy to send the RAW-files to you via Dropbox.
digi2ap
Regular MemberPosts: 480Gear list
Thanks for doing this. To my eyes the differences appear the least when using the CWB. Perhaps setting a CWB is more important (than Bayer) when using Sigma cams to preserve colour accuracy? Can you say whether the CWB has also rendered the scene more accurately as you remember it?
 digi2ap's gear list:digi2ap's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill
Well, since it was done in Neutral I'm somewhat less interested in actually running through other color modes as that was the main one I was interested in... thanks for the offer though.  I'm sadly too busy to perform that service for everyone just now.
In reply to digi2ap, Jun 17, 2013
Yes, CWB was the most accurate indeed.
And since in CWB the colors in the three cams are almost identical, I wonder why it shouldn´t be possible to get the colors identical in the wired color modes as well. In theory, that shouldn´t be a problem.
There´s another factor in the game of course, and that is consistency from sensor to sensor. I guess, that could be a problem for Foveon sensors more than for the Bayers.
http://idisk.mac.com/ghrdt/Public/Filmstreifen.jpg
http://borgemeister.com
http://swiss-landmarks.ch
http://landmarks-of-iceland.com
http://www.pbase.com/ghoerdt
http://wohntattoos.de
http://wandtattoos.ch
digi2ap
In reply to Guenter Borgemeister, Jun 17, 2013
Thanks again. As I have recently ordered a neutral Expodisc white balance disc I think I'll be making more use of CWB in the future.
http://digi2ap.wordpress.com/
PrebenR
Senior MemberPosts: 3,121
In reply to Johan Borg, Jun 17, 2013
I have not tested, but if you increase saturation to 0.1-0.2 would they then match?
The brief pain of taking photos is not important, the joy of viewing excellent photos is everlasting.
Johan Borg
In reply to PrebenR, Jun 17, 2013
Colors will be closer overall, but increasing saturation on the DP2M also makes it more obvious how Sigma improved shadows with the DP3M (less desaturation). So, while 45mm is my favorite focal length, the DP3M is still my favorite camera
Jefftan
Senior MemberPosts: 1,235
In reply to Johan Borg, Jun 22, 2013
Why is DP3M color better?  Is it a slightly updated sensor? or is just processing?
If just processing can get DP1M/Dp2M the same color in PP
Jefftan
In reply to Jefftan, Jun 22, 2013
In my eyes, DP1M has the worst color of the three
Johan Borg
In reply to Jefftan, Jun 23, 2013
I had a look earlier at RAW files from the DP2M with Roland's X3F Tools ( http://www.proxel.se/x3f.html ) and it appeared to me that the desaturation of shadows existed to at least some extent in the X3F file itself, making it hard to guess the original color in post processing.
Whether that means the DP3M is physically different or just has a better firmware is another question...
Jefftan
In reply to Johan Borg, Jun 24, 2013
I am only interested in the 19mm FL of DP1M.  Now that DP3M color is better for unknown reason, I think it is safer to wait for a successor model.
but that may be a long wait.
PrebenR
In reply to Jefftan, Jun 24, 2013
Well it depends if you are shooting RAW or not
Lightwriting with Sigma
