What are you using for macro photography?
Started Jun 12, 2013 | Discussions
vbuhay
vbuhay Senior Member • Posts: 2,328
Re: What are you using for macro photography?
I use the Pentax 645A 120mm (78mm equivalent) Macro with "No Glass" adapter, F4.0, old school Manual only.
 vbuhay's gear list:vbuhay's gear list
Nikon Coolpix AW100 Pentax K20D Pentax K-5 Nikon D750 Nikon AF-S Nikkor 14-24mm f/2.8G ED +30 more
Michael Benveniste
Michael Benveniste Senior Member • Posts: 2,438
Do microscopes count?
In my previous response, I neglected to mention that I've been playing with an Amscope 3.5-90x low power trinocular scope and a Nikon V1 with 1:1 relay lens.  Optical quality is "meh," but it's a lot of fun getting really close-up.
Another person using a Pentax 645 120mm macro in the Nikon forum?  What are the odds?
I miss the days when I used to be nostalgic.
 Michael Benveniste's gear list:Michael Benveniste's gear list
Nikon Coolpix 995 Nikon D200 Nikon 1 V1 Nikon D800 Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF +33 more
mmalkin15 Regular Member • Posts: 258
Re: macro photography? Nikon 200, Sony NEX, Wild Photomakroskop, Takumar 100
Insects and flowers In the field:  Nikon D800, nikon 200/4 AF-D Micro, Sigma 150/2.8 Macro
Also experimenting with NEX6 with old SuperTakumar 100/4 SMC macro  with Novoflex rotating collar on the lens adapter
In the field for butterflies - d800 or D3  with 70-200 /4 Nikon AFS sometimes on tubes sometimes with 1.4x.  New setup this year - looks very promising
In the field for higher magnifications : Zeiss Luminar 63mm and 40mm on tubes.  The NEX is nice as it has focus peaking and electronic first curtain shutter settings for minimal vibration
rotating tripod collar on all field setups  - makes a huge difference for me.   Add Nikon PN11 where needed to get this capability with some lenses
in the lab for higher magnification I use a Nex7 mounted on an old Wild M400 photomakroskop with 1:6 APO zoom that gets up to about 50x.   Lighting with fiber optic/halogen sources for brightfield, darkfield, incident, and incident ringlight
Macro is my thing......
Jose Rocha Senior Member • Posts: 1,029
Re: Canon
I really envy that MP-E lens on Nikon's lineup. Truly amazing piece of engineering!
 Jose Rocha's gear list:Jose Rocha's gear list
Nikon D700 Olympus OM-D E-M10 Nikon AF Nikkor 180mm f/2.8D ED-IF Tamron SP AF 90mm F/2.8 Di Macro Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +3 more
Leonard Migliore
Leonard Migliore Forum Pro • Posts: 13,232
Partly there
Glen78 wrote:
The newest models (D600 definitely and I believe D4, D800, D7100, maybe the D5200) have an option for up to a 3 second exposure delay (option d10 on mine). When used in conjunction with mirror lockup the first click of the shutter (or remote) locks up the mirror and the second click starts the 3 second delay before exposure. Should solve the problem you are describing without resorting to the dark side.
It's good to hear that Nikon's fixing the ghastly live view implementation that my D300 has. But it still doesn't have an electronic first shutter curtain like Canon and (gasp!) Sony. And has Nikon fixed the auto stopdown in live view? That's another piece of grief. Fortunately, I use an AI Micro Nikkor for close-up/copy work and I can set the aperture anywhere I want. I like to focus at f/4 and then stop down to whatever the image requires.
Leonard Migliore
 Leonard Migliore's gear list:Leonard Migliore's gear list
Canon PowerShot G12 Sony Cyber-shot DSC-RX100 III Nikon D300 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G +8 more
JJ Martinez New Member • Posts: 9
Re: Sigma 150 f2.8
The new Sigma 180 looks awesome... although it is bigger, heavier, and more expensive than the 150.  Most reviews suggest it is one of the sharpest lenses ever made, but a few user reports here seem to suggest that the 150 might actually be sharper wide open.
Any other first-hand comments on how these compare would be appreciated...
Osvaldo Cristo
Osvaldo Cristo Veteran Member • Posts: 4,089
Sigma 150 /2.8 Macro & Tokina 35 f/2.8 Macro on D300S
For macro I am currently using Sigma 150 /2.8 Macro & Tokina 35 f/2.8 Macro mounted on my D300S.
Eventually I am also using Canon 500D filter mounted on Nikkor 12-24 f/4.
O.Cristo - An Amateur Photographer
Opinions of men are almost as various as their faces - so many men so many minds. B. Franklin
 Osvaldo Cristo's gear list:Osvaldo Cristo's gear list
Olympus Stylus 1030 SW Nikon D200 Nikon D300S Nikon D810 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED +32 more
L Bourdillon Regular Member • Posts: 170
Re: Do microscopes count?
Not very well in my experience... the microscope I have here can count up to about three; but, then usually forgets the next number...
(Sorry, couldn't resist)
Larry
Leon Obers Senior Member • Posts: 2,788
Enlarger lenses
Enlarger lenses on a Nikon PB-4 bellows, with tilt/shift movements.
Specially the Rodenstock APO Rodagon lenses (105mm) do have a good quality when used in tilt/shift positions by their good sharpness and micro-contrast at borders / corners in this position.
Leon Obers
vwcrusher Regular Member • Posts: 228
D7000 w/ 60mm micro version G
No text.
brightcolours Forum Pro • Posts: 12,824
Nice and odd
Nice lenses, although if I had Nikon I would prefer the Nikkor 40mm f2.8 DX micro over that 35mm Tokina, for its smooth bokeh.
Odd... I do not think a close up lens will do much at all on a wide angle. Close up diopters are worthwhile on tele lenses, not wide angles...
Better idea is to get a 12mm (or a bit less) extension tube, and use it at 24mm or thereabouts.
Ray Soares Veteran Member • Posts: 3,106
Zeiss 100mm f/2 Macro Planar
Just an amazing top lens, as I can't see a macro work with AF!
Best
Ray Soares
See my pictures at www.pbase.com/raysoares
 Ray Soares's gear list:Ray Soares's gear list
Nikon D7000 Nikon D4 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 24mm f/1.4G ED Nikon AF-S Nikkor 85mm f/1.4G +1 more
sjprintz Regular Member • Posts: 382
Re: Zeiss 100mm f/2 Macro Planar
Great photo. I like the 3D quality.
Question about the Zeiss lens. How would you compare it to the Nikon 105 F2.8 micro lens?  I am debating between the two.
SJP
 sjprintz's gear list:sjprintz's gear list
Nikon D800E Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF Nikkor 85mm f/1.4D Nikon AF-S Nikkor 24-120mm f/4G ED VR +1 more
VadymA Contributing Member • Posts: 896
Vivitar 105 2.5 1:1 Macro
Paid around $100 last year. For the money, I love it.
I also like "the look" from Nikon 35-70 f2.8 in macro mode but it doesn't magnify as much as Vivitar as cost at least four time more. Here is an example; this is pretty much as close as you can get (I think the distance from the lens was approximately the same as Vivitar above).
Here is Vivitar lens; it looks and feels very nice:
 VadymA's gear list:VadymA's gear list
Nikon D300 Nikon AF Nikkor 85mm f/1.4D Tokina AT-X Pro 11-16mm f/2.8 DX Nikon AF-Nikkor 80-200mm f/2.8D ED +2 more
Daisy AU
Daisy AU Senior Member • Posts: 1,564
Nate8833 wrote:
Just curious... what is everyone using for macro photography? I have the D7000, and I'll add a macro lens eventually.
I use the Nikkor 105 f/2.8 VR with my D7000.  Extremely sharp lens!!  Not cheap, but well worth the investment.  I recently also purchased a macro rail ('Velbon' Mag Slider) to try focus-stacking.
 Daisy AU's gear list:Daisy AU's gear list
Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +8 more
You can't be wrong with either
I just prefer the color rendering of Zeiss and IMO it has a bit softer transition regarding its bokeh (which is amazing!!!).
Best
Ray Soares
ERROL FLYNN Forum Member • Posts: 64
Zeiss 100mm F2 and I have just acquired the Sigma 180F2.8
The Zeiss is a stunning lens, though only goes to 1:2 and MF only of course, early days on the Sigma .........seems sharp enough, the OS, AF, rotating collar and extra reach will come in handy, though a bit heavy with the D800E on the back, just set up a home made flash bracket on a King Cobra, heavy to carry about but very easy and stable to use once set up.
Pete
 ERROL FLYNN's gear list:ERROL FLYNN's gear list
Nikon D810 Nikon AF-S Nikkor 400mm f/2.8G ED VR II Sigma APO Macro 180mm F2.8 EX DG OS HSM Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR Tamron 15-30mm F2.8 +1 more
