nx300: where is "shoot without lens"
Started Jun 12, 2013 | Discussions
Un dbutant Regular Member • Posts: 150
i just got my nx300 this afternon
i cant find anything in the menu to set "shoot without lens", which i believe is necessary to be set to "enabled" if one is to shoot with legacy manual lens
i read the manual like 3 times and i couldnt find it there either
am i missing something here?
fw is still the original 1.0
Samsung NX300
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
Re: nx300: where is "shoot without lens"
If you use a suitable adapter for legacy lenses, the camera will shoot without any problem!
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
viking79
viking79 Forum Pro • Posts: 14,152
Your adapter just has to depress the mechanical switch in the lens mount. Some adapters are problematic, most are fine.  As Technoworld already stated, there is no firmware setting in the menus.
Eric
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
OP Un dbutant Regular Member • Posts: 150
ow
i thought i had to set something in the menu
like what i read about nex
its good news then
now i can start looking for that adapter
thank you
monkeybrain Regular Member • Posts: 424
Search this forum for discussion of adaptors, some work better than others.
 monkeybrain's gear list:monkeybrain's gear list
Samsung NX10 Samsung NX100
