The whole question of lens sharpness...
Started Jun 12, 2013 | Discussions
Detail Man
Detail Man Forum Pro • Posts: 16,403
Re: Sharpness not too important on 2.4MP monitor ...
Basalite wrote:
Detail Man wrote:
Basalite wrote:
Draek wrote:
Basalite wrote:
What's a "2.4MP monitor?"
A monitor whose resolution is around 2.4 million pixels.
And what "monitor" on the market has such a resolution? I know of none.
As posted by another, just multiply 1200 pixels height by 1920 pixels width = 2.304 Mpixels.
That's not 2.4MP. There is no monitor on the market with 2.4MP.
There's also nothing wrong with viewing images at 100% as that's the only way to tell how sharp your images are.
Nope; another, much more reliable method is to simply make a decently-sized print from it.
Nonsense. If you have a decent quality display you can much more easily determine the level of sharpness than in a print. The printing stage degrades image quality to a certain degree.. As it relates to sharpness, viewing a digital picture on your computer is like looking at a negative or slide with a loupe.
The typical monitor only has around 100 pixels/inch resolution. Some are higher. Printers often can exceed those resolutions. Inks and paper are critical elements in realizing that. Where monitors excel over printers is in contrast-ratio - which is much higher in the case of the typical monitor.
The ability of good monitors of today to show you the true sharpness of your images is not dependent on it being able to display the pixel density needed to produce high quality photographs. Two separate things.
Your words make very little sense.
NancyP Veteran Member • Posts: 5,280
Contrast and color just as important
Color and contrast are what make an image "pop". Sharpness tends to be associated with good color and contrast. Not all images need to be ultra-sharp, but all images benefit from good contrast. Ultra-sharp for portraits requires some softening in post-processing.
NancyP
 NancyP's gear list:NancyP's gear list
Sigma DP3 Merrill
Jeff Veteran Member • Posts: 4,796
It's a matter of craftsmanship ...
gdourado wrote:
Hello, how are you?
So, after spending a lot of time on photography sites, blogs and forums, one thing that seems to always be mentioned is lens sharpness.
There seems to be sort of an obsession about sharpness that always generates flaming debates about sharpness, bad copies, sample variation and such...
This got me wondering... Do we really need more and more sharpness? For portraits, events, models... is super sharpness even a good thing? How much is enough? And why do people get so turned on by this?
To many, craftsmanship matters.  A good, sharp lens is a necessary (but by itself, not sufficient) tool for crafting nice sharp images, whether for print or screen. Not all subject requires all of the resolution available in modern lenses, nor is max resolution required for all media.  Thought it is nice to have if you need it for a particular situation.
It's also one of the more or less quantifiable aspects of lens performance, and a proxy for overall lens quality. So in the endless discussions of price versus quality, it's an obvious target for obsessive debate.
Yes, there's still room for sharper lenses since there's always a desire for better, smaller, cheaper.  Whether the state of the art is good enough for you (or me) is entirely an different question.
Hope to hear your opinion on this matter.
Cheers!
Jefftan Senior Member • Posts: 1,426
next generation monitor
Anyone consider that next generation monitor will have 9MP?
I upgrade to a 3.7 MP monitor and already seeing much more detail
Actually anyone serious about sharpness should consider "downgrade" to a smaller sensor for the larger DOF
For example RX100 1 inch sensor will have more in focus compare with APS-C
(unknown member) Veteran Member • Posts: 5,593
Which part did you not understand?
Re: Contrast and color just as important
NancyP
There is no such a requirement to soften portraits. Some of the most interesting portraits are those that are razor sharp.
Today contrast and color can be taken care of digitally.
Detail Man
The brief declarations that you have not made an effort to explain. You could start by defining what you actually mean by "sharpness". The ability of a medium to depict spatial frequency information depends upon the maximum contrast-ratio as well as the spatial frequency response characteristics. Perhaps that is what you had in mind - but nobody will ever know if you don't explain what you are talking about, so readers can determine your actual understanding of the subject. Please elaborate ...
looper1234
looper1234 Regular Member • Posts: 314
Re: The whole question of lens sharpness...
Basalite wrote:
There is nothing "vague" about the definition of sharpness.
it's vague because it is not quantified in a universally accepted way, DxOmark did the best job they could by introducing standardized test methods and the principle, "perceptual mpx"
but these type of quantification are a far cry from what one would consider workable in the world of science.
one should consider an entity defined if it can be presented in vector or scalar form with SI units. pMp is a good unit for sharpness only if the tests used to generate these quantities are perfect and its results free from all outside influence.
the concept of sharpness cannot free itself from these constraints because it is too complex a principle, and the only way to quantify it is to do what Dxomark did, to standardized and simplify it to a form of resolution.
Klaus dk
Klaus dk Veteran Member • Posts: 3,342
Re: Most people do not want sharp vision in their glasses
Basalite wrote:
fad wrote:
Optometrist do not correct you vision fully. It makes people feel uncomfortable.
I doubt that very much.
I don't. Both my present and my former optician told me the same thing. Both are/were reputable professionals.
 Klaus dk's gear list:Klaus dk's gear list
Canon PowerShot S120 Canon EOS 500D Canon EOS 7D Canon EF 35mm f/2.0 Canon EF 50mm f/1.8 II +9 more
Detail Man
I wonder in what particular respects they modify the optical corrections, and if there exists some common standard numerical amount(s) by which they modify such correction parameters.
salla30
salla30 Senior Member • Posts: 2,596
Re: Contrast and color are MORE important :-)
I agree wholeheartedly with this.
Colour and contrast, the way the light plays naturally within an image is so important.
And colour, so important, take the RX1 for example, do a search on Flickr for RX1. A whole load of thumbs come up and the first thing you notice is the vivid, vibrant colours.
Sharpness is a nice attribute, but it's really very secondary at pixel level. The VAST majority of images are viewed at HD or much less (cellphone level or tablet) and as such the colour and dynamics of the image are FAR more important.
 salla30's gear list:salla30's gear list
Sony RX100 Sony RX1 Sony RX100 II Sony Alpha NEX-5N Sony a5000 +1 more
Klaus dk
Back on track and a word about obsessing
I also wondered, but if I asked, I have forgotten the answer. I supposed they know what they are doing. But are we not sidestepping the actual discussion here?
I agree with others, that the sharpness of a lens is a good thing and I think price considerations will keep sharpness freaks in check.
Advances in technology is not driven by a "good enough" attitude. Advances are only possible because lensmakers are obsessed with sharpness, sensor designers are obsessed with pixel count and high ISO noise and customers are obsessed with value for money.
If noone obsessed, we would still be using 1 MP cameras costing 2000 USD.
My wife insists, that all my lenses can look into the future and show how she will look in ten years time, but that is another matter entirely
Detail Man
Re: Back on an ethereal track and a word about obsessing
I find that particular information more interesting than the "discussion". First, (the "discussion") is premised upon the usage of a term without clear objective definition that describes a subjective perceptual impression. Like the term "brightness" and the phrase "image quality", "sharpness" is a term that is bound to mean and to constitute different things to different observers.
These kind of (non) discussions are all too common on these forums - and accomplish nothing.
If we are talking about the lens have a minimum of optical aberrations and a correspondingly high spatial frequency response (MTF), then I am all for that. There exists a plethora of other effects (in addition to lens aberrations) that diminish that (de-focusing, diffraction, optical filtering on image-sensors, image-sensor noise sources, de-mosaicing, in-camera and/or post-processing manipulations including noise-reduction, display/printer reslution and contrast-ratio limitations, viewing size, viewing distance, ambient lighting and human visual acuity).
Wishing for a lens that is "soft" is like wishing for an image-sensor with some limited number of photosites. It makes little sense to me to desire to impose limitations over and above all of the limitations that already exist - especially when RAW format recording and digital signal processing offers such a wide "spectrum" of ways by which the final image can be "softened" to taste.
(To me), longing for marginal lenses is akin to dreaming of audio amplifiers with vacuum-tubes so that the linearity, bandwidth, and signal/noise ratio will be compromised, based on some desire to always see the world through a particular type of rose-colored glasses smeared with vaseline. It might sound great for certain limited bandwidth program material, and fail miserably where it comes to reproducing orchestral music replete with critical high frequency information.
If we had keen vision and feeling of all ordinary human life, it would be like hearing the grass grow and the squirrel’s heart beat, and we should die of that roar which lies on the other side of silence.
- George Eliot
DM ...
ultimitsu
ultimitsu Veteran Member • Posts: 6,579
Money.
The higher the resoluton, the more reach, the smaller and cheaper the camera for the same reach.
D7100 with 70-200 F4 today can produce the resolution of D3X with 300 F4 a few years ago at a fraction of the price (assumming lighting is non-issue). sensor resolution improves year on year for free, but lens resolution improvement is hard and expensive, that is why people get "turned on" if there is a sharp lens, especially if it is cheap, like sigma 35 F1.4 or Nikon 50 F1.8G or Canon 70-200 F2.8 II.
Draek
Draek Senior Member • Posts: 2,028
Basalite wrote:
1920x1200 monitors are no longer "pretty common." They are actually rare now. It is also not a 2.4MP monitor, which is no surprise considering there is no such a thing as a 2.4MP monitor.
2048x1152 monitors are close enough you get 2.4 Mpx with just two significant digits and there's plenty of models sporting that resolution being catered to gamers and graphical artists on a budget, but honestly, do you really think it was a point that warranted all this discussion? good freaking Lord.
 Draek's gear list:Draek's gear list
Fujifilm FinePix F70EXR Samsung TL500 Canon PowerShot A1200 Sony Alpha DSLR-A390
OpticsEngineer Senior Member • Posts: 4,491
Here is a nice reference from Zeiss on sharpness and other things concerming lens quality.    It is written from the perspective of photographers.
As others have said, sharpness is important and easily understood, but one of only many important qualities that may be harder to understand.
For some type of images sharpness might be the dominating thing, for instance a models hair being blown by a large fan (not in the picture) and lit by a flash.
http://www.zeiss.com/c12567a8003b8b6f/embedtitelintern/cln_30_mtf_en/$file/cln_mtf_kurven_en.pdf
 OpticsEngineer's gear list:OpticsEngineer's gear list
Fujifilm XF1 Olympus XZ-2 iHS Canon PowerShot G7 X Olympus Tough TG-4 Sony Alpha NEX-7 +21 more
Rick Knepper Forum Pro • Posts: 13,162
Good one.
I want every aspect of the lenses I purchase to be as defect free as possible. As another poster mentioned, pricing controls a person's attitude towards such attributes. If all lenses were free, we wouldn't be having this debate.
The financially-challenged should just "own" their plight and quit clogging these forums with false arguments. For example, as a landscape shooter, medium format digital is what I really should be shooting for capturing detail but the pricing is beyond what I can spend (a Lotto win notwithstanding). I'm not going to sit here, put on airs and justify my chosen format on the basis of technical excellence when cost is the primary deterrent to moving on and upward.
Rick Knepper, photographer, non-professional, shooting for pleasure, check my profile for gear list and philosophy. TJ said, "Every generation needs a new revolution".
 Rick Knepper's gear list:Rick Knepper's gear list
Pentax 645Z Canon EOS 5DS R +2 more
Mark Smith Veteran Member • Posts: 6,336
Is Apple 30" 2.4mp?
For a while I used an Apple monitor that was 30" 2560 x 1600 they make a 27" with 2560x1440
If they aren't 2.4 mp then I'm not sure what is.
It doesn't mean they are right for doing so.
2048x1152 is a very uncommon resolution, and still not a 2.4MP monitor. As I said, there is no such a thing as a 2.4MP monitor. Photography, and the related hardware, is a technical field besides an artistic one. People need to be corrected when using terms that are obviously incorrect.
