The whole question of lens sharpness...
Started Jun 12, 2013 | Discussions
Draek
Senior MemberPosts: 2,028Gear list
We 'need' sharp lenses like we 'need' larger sensors and less noise...
In reply to gdourado, Jun 12, 2013
...but at least it's more fun as a subject to talk about and, given the incredible performance of lenses such as the Pentax SMC Takumar 50/1.4, much, much cheaper as an obsession to get into.
Which is why few in this forum care, of course.
 Draek's gear list:Draek's gear list
Fujifilm FinePix F70EXR Samsung TL500 Canon PowerShot A1200 Sony Alpha DSLR-A390
unknown member
(unknown member)
Re: The whole question of lens sharpness...
In reply to Chris R-UK, Jun 13, 2013
Chris R-UK wrote:
Basalite wrote:
[snip]
There is no such a thing as an image being "oversharp" because of a lens.
But is can certainly be "oversharp" because of excessive sharpening in post processing. I think that that is what the previous poster was referring to.
Chris R
The discussion is about "lens sharpness."
unknown member
(unknown member)
In reply to olliess, Jun 13, 2013
olliess wrote:
Basalite wrote:
There is nothing "vague" about the definition of sharpness.
Ok, then what's your definition of sharpness?
Are you over 40 yet?
unknown member
(unknown member)
Re: Sharpness not too important on 2.4MP monitor ...
In reply to BertIverson, Jun 13, 2013
BertIverson wrote:
gdourado wrote:
... Do we really need more and more sharpness? For portraits, events, models... is super sharpness even a good thing? How much is enough? ...
My take on this is simple. If one can fill the frame (avoiding cropping), lens sharpness is usually irrelevant when viewing on a 2.4MP monitor. Viewing a 16MP shot on a 2.4MP monitor means about 4-6 sensor pixels are rendered into 1 pixel on the monitor. In the case of a zoom lens, it only needs to be real sharp at the extreme long end. At lesser FL one will fill the frame (see above).
my 0.02 -- PS pixel peeping not allowed
Bert
What's a "2.4MP monitor?"
There's also nothing wrong with viewing images at 100% as that's the only way to tell how sharp your images are.
Draek
In reply to Basalite, Jun 13, 2013
A monitor whose resolution is around 2.4 million pixels.
Nope; another, much more reliable method is to simply make a decently-sized print from it.
unknown member
(unknown member)
In reply to UtahManSir, Jun 13, 2013
Bert
I don't care about the screen, I want good prints. The screen is irrelevant.
Lloyd
“For every problem there is a solution which is simple, clean and wrong.” Henry Louis Mencken
http://lloydshell.blogspot.com/
http://lloydshell.zenfolio.com/
WSSA #354
http://lloydshell.zenfolio.com/img/s3/v41/p234497562-3.jpg
A good screen will show if it is possible to get "good prints."
unknown member
(unknown member)
In reply to Draek, Jun 13, 2013
And what "monitor" on the market has such a resolution? I know of none.
Nonsense. If you have a decent quality display you can much more easily determine the level of sharpness than in a print. The printing stage degrades image quality to a certain degree.. As it relates to sharpness, viewing a digital picture on your computer is like looking at a negative or slide with a loupe.
BertIverson
Veteran MemberPosts: 3,410Gear list
1920x1200 is pretty common and close to 2.4MP
Bert
 BertIverson's gear list:BertIverson's gear list
Sony RX100 Sony Cyber-shot DSC-RX10 +4 more
Detail Man
Forum ProPosts: 16,160
As posted by another, just multiply 1200 pixels height by 1920 pixels width = 2.304 Mpixels.
The typical monitor only has around 100 pixels/inch resolution. Some are higher. Printers often can exceed those resolutions. Inks and paper are critical elements in realizing that. Where monitors excel over printers is in contrast-ratio - which is much higher in the case of the typical monitor.
Midwest
Forum ProPosts: 15,842
Basalite wrote:
D Cox wrote:
You don't always want a very sharp image, but often you do. It is easy to reduce sharpness, but very hard to increase it.
The ideal is to have a range of lenses in your armoury to suit different occasions. This can include soft focus lenses.
No, it's impossible to increase real sharpness if it wasn't there to begin with.
I wish that more people realized that. I've seen so many images massively sharpened in an attempt to make up for the fact that they weren't sharp to begin with. Of course as you point out that won't work, but people do try, with the result that they get an ugly and painful image to look at.
PK24X36NOW
Senior MemberPosts: 1,438
Bert
When viewing the whole image, then the effect is probably not going to be seen in a big way on screen, as you indicated, but, alas, "pixel peeping" is how critical image sharpness can be seen in a way that could only be replicated in film days with a microscope (looking at a slide or negative, not a print, which would not display all of the original's information), and that is where image sharpness differences can be seen on a computer screen. Viewing "actual pixels" on screen is the (size) equivalent of massive print sizes that are seldom, if ever, going to be made by most people. The contrast ratios available in print are also far more limited than viewing on screen.
BertIverson
In reply to PK24X36NOW, Jun 13, 2013
Bert
Craig,
I agreed with your post.
My post was not to question the wisdom of sharpness when printing large but rather to inspire  those who view on a monitor 99.99% of the time (or make smallish prints) to think about the expensive lens lust. If one fills the frame, kit lens pretty much looks the same as a $2000 super lens.
100% pixel peeping is, indeed, a good/easy way to check sharpness and yes lens sharpness is definitely necessary if one crops/digital zooms or makes large prints.
Since I am one of those 2.3MP monitor viewers and digitally zoom 2X on occasion, I ask that my lens be tack sharp in the center 1/4 region at maximum zoom (the 2X crop tosses the remaining 3/4 peripheral pixels -- leaving me with a 5MP shot)
Bert
Brad99
Veteran MemberPosts: 3,145
In reply to gdourado, Jun 13, 2013
Ultimate sharpness is important, but sharpness holding up well all across the frame at wide open apertures is probably more important.
I would like to see more emphasis on flare, contrast and colour in lens reviews.
fad
fad
Forum ProPosts: 13,976Gear list
Most people do not want sharp vision in their glasses
Optometrist do not correct you vision fully.   It makes people feel uncomfortable.
My next pair of glasses, I will have them correct my sight fully, at least, for the sake of seeing details when I photograph.
Frank
shot in downtown Manhattan.
http://sidewalkshadows.com/blog/ (street photos)
Always view all photos in Gallery or Original Size
 fad's gear list:fad's gear list
Canon EOS-1Ds Mark III Nikon D3S Nikon D800 Nikon D4S Nikon D810 +16 more
unknown member
(unknown member)
Re: Most people do not want sharp vision in their glasses
In reply to fad, Jun 13, 2013
I doubt that very much.
Frank
unknown member
(unknown member)
Bert
1920x1200 monitors are no longer "pretty common." They are actually rare now. It is also not a 2.4MP monitor, which is no surprise considering there is no such a thing as a 2.4MP monitor.
unknown member
(unknown member)
In reply to Detail Man, Jun 13, 2013
That's not 2.4MP. There is no monitor on the market with 2.4MP.
The ability of good monitors of today to show you the true sharpness of your images is not dependent on it being able to display the pixel density needed to produce high quality photographs. Two separate things.
unknown member
(unknown member)
Bert
Just to be clear, it is a mistake to think that just because most people will not be making large prints that their small prints will not benefit from a sharper and therefore high resolution (no, not MP) image. When I used to shoot medium format film i could easily see the difference in even small prints over 35mm film. Then you also have to consider the advantages of being able to crop a more sharper and therefore higher resolution image.
unknown member
(unknown member)
BertIverson wrote:
Bert
Craig,
Bert
Small prints also benefit from a sharper lens.
fad
fad
My source is my optician and optometrist at a reputable high end establishment.   I'm afraid I have no further source or technical details, and what they mean by full correction.  Possibly they are talking about 20/15 being full correction.  I do not know.  And the context is myopia.
20'/20 is an arbitrary standard and many people have 20/15.  So it could be what they are talking about.
I Googled, and undercorrection is often used with kids on the theory that it will slow the progression of myopia.   This has not been confirmed by studies, however, and has no relevance for adults.
When I next go there, I will get a more technical description of what they meant.
Frank
Frank
