Underwater compact camera that shoots raw?
Started Jun 12, 2013 | Discussions
Waterengineer Contributing Member • Posts: 872
Can someone please direct me to one of the underwater compact cameras that shoots raw?  Thanks.
EthanP99 Senior Member • Posts: 2,421
Re: Underwater compact camera that shoots raw?
 EthanP99's gear list:EthanP99's gear list
Sony RX1 Sony RX1R Canon EOS-1Ds Canon EOS 5D Mark II Sony Alpha DSLR-A900 +21 more
tkbslc Forum Pro • Posts: 10,601
RAW looks worse on cheap cameras
If you are thinking one of the sub $300 tough compacts, then RAW would not be a benefit.   You'll end up having major CA, distortion and noise in every single photo.    JPEG + autocorrections are a good thing on these cameras.
 tkbslc's gear list:tkbslc's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS Samyang 7.5mm F3.5 UMC Fisheye MFT Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS +3 more
AllMankind
AllMankind Contributing Member • Posts: 564
Without using a special underwater housing... there is none.
For some unknown reason, every manufacturer, including Nikon, has deceided to NOT include this feature, which, in my opinion, is an absolute must in such a camera.
I would like to see someone (such as Nikon, who used to own this market) offer a good waterproof camera, using say a 1" sensor, and RAW file ability.
Oppose Tyranny in all its forms.
AllMankind
Disagree completely (nt)
GordonBGood Veteran Member • Posts: 6,301
Re: RAW looks worse on cheap cameras
I agree with you that you won't likely be able to do much using raw that isn't already corrected with the in-camera JPEG engine as far as lens imperfections such as vignetting, distortion, and Chromatic Aberrations (CA) go, but noise might not be too bad for lower ISO sensitivities up to about 400 or 800 without the in-camera Noise Reduction (NR).
Anyway, to answer the OP's question of which underwater cameras support raw, the easiest and least expensive would be to use the Canon D10 or D20, both of which were toward the top of reviews for such cameras, with the free CHDK firmware add-on which should allow these cameras to output raw DNG files.  Of these two, the D20 is probably preferred being newer and using a CMOS Back Side Illuminated (BSI) sensor, which should be of lower noise than the older CCD sensor used by the D10, although the D20 has quite a bit slower lens wide open at f/3.9 as compared to the D10's f/2.8, meaning that higher ISO's may need to more often be used with the D20 than the D10 in order to stop motion blur.
Other than that, any camera that has raw output could be used underwater by using it with a waterproof housing, with larger sensored cameras preferred as underwater generally also implies low light, so the suggestion of a Sony Rx100 and underwater housing with its large 1" sensor may be a good one although at a much higher cost.
Regards, GordonBGood
hjulenissen Senior Member • Posts: 1,900
Sony rx100 in a rugged/3m depth version, without being too bulky? Where can I line up?
-h
