wide angle DSLR shots looking like P&S images.
Started Jun 11, 2013 | Discussions
jopezu
jopezu Contributing Member • Posts: 501
most times i try to compose using my wide angle setup (d600 + 28mm f/1.8g), the resulting shots look like they could have come from a point-and-shoot camera.  even looking on forums, a lot of times people will have expensive wide angle combos that produce flat, ultra DoF pictures.  i know a lot of this is composition and processing, but does anybody sometimes feel the same way and have any advice?
when i use the 28mm like a longer lens, and step up to subjects and compose portraits, things get more exciting as the lens does its thing.  i just can't help looking at most of my environmental landscape shots thinking "i could've done this on a $200 powershot".
 jopezu's gear list:jopezu's gear list
Nikon D600 Nikon D7100 Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S Teleconverter TC-14E II +4 more
Zlik Contributing Member • Posts: 990
Re: wide angle DSLR shots looking like P&S images.
I guess you associate 'huge DoF' with P&S.
It is true that with tiny sensors, DoF is usually very large, and that's why low DoF shots are quite popular: they look "professional" because until recently, only big cameras could produce this "effect". And it looks like this is what you're after.
You should try a longer lens, like a 50mm f/1.8. The DoF will be much smaller on your D600, and it won't look like a P&S.
But even with huge DoF, photos from cameras like the D600 & D800 look nothing like P&S to me. The dynamic range and the noise handling in low light is not even comparable. But if you don't see it, why not get back to P&S ?
jopezu
jopezu OP Contributing Member • Posts: 501
because sometimes the pictures come out looking like this and blow me away.
i agree with what you said on slr body performance being far beyond P&S, i'm just looking for shooting and processing advice from people who may have felt that way about their shots and overcame it.
eNo
eNo Forum Pro • Posts: 11,744
Well, if the shot called for ultra DOF -- say, a landscape -- then that's what it calls for. I bet dynamic range and color alone, especially from a FX sensor, will blow away anything a P&S can get. And if not, that's still not a problem. You can take a great shot with a P&S as well as with a FX camera. My main line of advice to you is not to focus so much on "the look" as in "the core" of the image.
My other observation is that not many P&S cameras are as wide as a 28, so I'm not sure what you're comparing there.
Secondly, if ultra DOF is bothering you, open up that 28 f1.8 and focus on something close. That will not be P&S like, as in these samples, all taken with the 28 f1.8G at f/2.0.
http://imagesbyeduardo.com/
Los Angeles wedding photography that seeks the heart and spirit in each image
ata3001
ata3001 Contributing Member • Posts: 599
This image was captured with a 28mm f/1.8g lens. I also shot several other images in the same location with a tripod mounted Nikon P7700. As nice as the P&S images are, they are no match to this.
 ata3001's gear list:ata3001's gear list
Nikon Coolpix P7700 Nikon Coolpix A Nikon D700 Nikon D610 Nikon AF Nikkor 24mm f/2.8D +33 more
