Flash help needed. For A99 and Metz 52AF-1
Started Jun 11, 2013 | Discussions
VaBoater
Contributing MemberPosts: 734Gear list
Jun 11, 2013
This is the first flash I have ever purchased. I always just got by with the little I did with the pop up flash for whatever camera I had. I just got the flash last night and put it on the A99 and tried to take some shots in the house. All I could get was a very week flash and pictures that where very under exposed. So rather then play around with too many settings I put it down and decided to ask for help.
This Friday I have been asked to take pictures at a weeding reception. They have a photographer and just want me to take a lot of random shots to add to what they are getting. So nothing critical but I would like to do a decent job. They used my shots for their wedding announcements, but they were outside, no flash needed. Thanks for any help.
What if any setting do I need to adjust to use the flesh?
Any suggestion would be helpful, I just have no idea how to use it.
 VaBoater's gear list:VaBoater's gear list
Sony Cyber-shot DSC-R1 Canon PowerShot SX40 HS Sony RX100 Canon PowerShot G5 X Sony SLT-A65 +7 more
Sony SLT-A99
IanML
Senior MemberPosts: 1,627Gear list
Re: Flash help needed. For A99 and Metz 52AF-1
In reply to VaBoater, Jun 11, 2013
First check that the contacts on flash and camera are completely clean. Use iso-propyl alcohol (aka propanol) which leaves no residue.
I would try with the camera in P mode and the camera flash mode set to "fill". Check that the flash is to TTL (see page 154 of the Metz manual).
Ian
 IanML's gear list:IanML's gear list
Sony SLT-A33 Sony Alpha NEX-5N Sony SLT-A57 Sony a77 II +1 more
JusLookN
Veteran MemberPosts: 4,162Gear list
In reply to IanML, Jun 11, 2013
I would imagine you are using the adapter with this flash or not?
Glenn
I'm kinda partial to video, but I'm hangin!
 JusLookN's gear list:JusLookN's gear list
Nikon D300 Nikon D700 Sony Alpha DSLR-A100 Sony Alpha DSLR-A700 Sony Alpha DSLR-A900 +2 more
IanML
In reply to JusLookN, Jun 11, 2013
Good point.  If not using the adapter, you must be using a model dedicated to another camera, which will not have the contacts on the front of the shoe, nor the firmware required to interface to the Sony system.
In that case, you would need to exchange the flash for the Sony dedicated model, and use it with the adapter.
Ian
Dsnoir
Contributing MemberPosts: 563Gear list
This unit does not use adaptors - in the sence of the 3302 adaptor, it is dedicated to the individual make. As with all flash guns it needs good quality batteries freshly charged, so would check the batteries to make sure that they are up to the job. I use the Metz 54-i no problems.
 Dsnoir's gear list:Dsnoir's gear list
Sony SLT-A99 Sony a6000 Sony 70-400mm F4-5.6 G SSM Sony 100mm F2.8 Macro Sigma 8-16mm F4.5-5.6 DC HSM +7 more
VaBoater
Re: I am using the adapter.....
In reply to Dsnoir, Jun 11, 2013
I did buy the model for Sony Alpha caners. It does require the adapter. I have set the flash to TTL and the camera in P mode with fill flash selected in camera. Auto setting in camera is greyed out. It fire a very dim brief flash, not enough to do any good.
Is there a way to test fire the flash by itself?
IanML
In reply to VaBoater, Jun 12, 2013
If possible, try it on another Sony camera - if that shows the same problem (and you have fresh batteries), the flash must be defective.
Ian
RandyPD
Regular MemberPosts: 253
This Metz model can be firmware upgraded via USB. Check the Metz website for firmware updates.
VaBoater
Re: Thanks for the suggestions.
In reply to RandyPD, Jun 13, 2013
Thanks for the help. I don't have a different Sony camera to try. That was a good idea. It has the latest software. I cant get it to fire even by it's self off camera.
Sending it back today. Time to break out the R1 and the RX100.
