Differences between Dell U2410, U2412m and U2413?
Started Jun 11, 2013 | Discussions
katterina Regular Member • Posts: 247
I am looking for a monitor with the price range of £200-400. These three monitors seem to keep popping up in searches as a reasonable priced option for a monitor that will last at least a couple of years.
The Asus screens of similar quality seem to have much trouble with back light bleeds.
The U2410 seems to have a wide gamut an sRGB and has been very popular but I have seen negative reviews on the AG coating and also the brightness even at lowest setting. It does seem to be highly regarded though and retails at about £350.
The U2412m seems to have been stripped back a bit and features 95% sRGB, and less wide gamut, no HDMI and I have seen it regarded as more of a consumer model rather that for editing. But still seems very popular £209. AG again seems to be an issue. Plus its 6 bit.
The U2413 is the more expensive at £379 but seems to have better colour space etc and 10 bit. I have seen negative comments regarding the fact it only supports xrite-pro1 calibration, but actually I have one of these. Ghosting and AG seems to be a big issue and have seen some comments about contrast. I do play some games occasionally and I realize it is not a gaming monitor, and the other half will need to be able to do spreedsheets etc for work. The primary point of this monitor purchase is photo-editing.
Is the coating on the U2413 slightly better than the U2412m or 2410? Posts seem to indicate it is more aggressive on the U2410.
At the moment I am leaning towards either the U2410 or the U2413, but am unsure of what would be the best. I assume you can set a profile on the wider gamut for sRGB when doing normal stuff like browsing the internet so that the colour's are not washed out?
Many thanks
Pictus
Pictus Veteran Member • Posts: 5,566
Re: Differences between Dell U2410, U2412m and U2413?
Roy Sletcher
Roy Sletcher Contributing Member • Posts: 931
Many thanks
Hi Katterina,
I have had the U2413 for about a month now and am happy with it. I am not a techy geek so cannot comment on some of the technical controversies, and there are a few.
I use it mainly for photo editing and evaluating images for inkjet outputs that exceed the sRGB gamut. It significantly simplifies this task for me, although I could get by without the wide gamut if necessary. For me it was an issue of cost versus the value to me of the additional features. For my uses I consider it a good deal, and I am happy with the product.
For the record there are quite a few complaints about Dell's QA on this product, some even in this forum. I am probably lucky mine seemed OK out of the box. So far ...
To answer one of your questions the `On Screen Display` - Dell`s fancy words for menu. You can toggle between AdobeRGB and sRGB plus two other options you can calibrate to your requirements but only with the XRite I1 Display Pro if you want the reputed 10 but LUT. I also use it for MS Word and spreadsheets occasional youtube video, and they all display just fine.
In addition, it has been my experience that Dell is somewhat flexible when marketing this product, at least in Canada. They are also less than transparent, and frequently duplicitous in their advertising.
If you have the stomach for it, I would advise calling them on the phone and trying to negotiate up to 10% off the price. They frequently run adverts in Canada advertising up to 15% of the posted retail price. YMMV.
Willing to answer your questions, but not a techy guy, so mainly personal opinions.
Roy Sletcher
katterina OP Regular Member • Posts: 247
Roy has been very kind in talking to me about his experience with the 2413 but has anyone else experienced the ghosting effect that seems to be the major downfall of this monitor?
Many thanks
Steviepix Forum Member • Posts: 97
Good summary by Roy and I am possibly one of those he mentioned as having had a problem with the monitor. My issues were a high pitched whine/buzz and pink and green tiniting in the bottom corners so it was returned the day after it was received.
Having said that, I was quite impressed with the screen quality (away from the bottom corners of course!) and I am quite prepared to accept that I had a rogue copy. I may well give the 2413 another chance later in the year. I did not get as far as checking specifically for ghosting but I was not aware of this being an issue for the very short time that mine was installed.
Good luck with whatever you finally choose and please let us know how you get on.
Steve
I have decided to go for the 2413 after much agonising as it will serve me better for what I want to use it for at the moment. If there seems to be any problems though we will probably return it and go for the 2412m.
Its arriving tomorrow.... fingers and toes crossed!!
ryann12 New Member • Posts: 1
Hi Katterina,
It's been 9 months since your last post and I'm wondering if you are happy with your U2413 purchase?  I'm considering getting this one too.
Hello,
No I returned it due to it being faulty and reading alot of unfavorable reviews about the problems I had. It seemed like a good screen but I got a faulty model and was not willing to risk having to send another back!
In the end I got a 22inch Eizo - it was more expensive but I love it and decided that I would sacrifice size got monitor quality. I have been very happy with my purchase.
I did get a faulty Eizo in all honesty - it had one hot pixel in the middle but was replaced the next day as I bought it from a monitor store rather than amazon.
Kind regards and let me know if you have any other questions.
