Touching up scuffs and nicks on camera body
Started Jun 11, 2013 | Discussions
Gpruitt54
Forum MemberPosts: 85Gear list
Jun 11, 2013
Is there an effective way to touch up kicks and scuffs on a Nikon camera D200 body?
 Gpruitt54's gear list:Gpruitt54's gear list
Nikon D200 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G ED VR II Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF Nikon AF Nikkor 50mm f/1.8D Adobe Photoshop Lightroom 4 +4 more
Nikon D200
Chuck Yadmark
Veteran MemberPosts: 3,456Gear list
Re: Touching up scuffs and nicks on camera body
In reply to Gpruitt54, Jun 11, 2013
http://www.brownells.com/gunsmith-tools-supplies/metal-prep-coloring/paint-finishes/air-cure-aerosol-paints/aluma-hyde-ii-prod1117.aspx
www.sportsshooter.com/cyadmark
Ann Arbor, MI USA
Equipment in profile
 Chuck Yadmark's gear list:Chuck Yadmark's gear list
Nikon D3S Nikon D800 Nikon D7200 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 600mm f/4D ED-IF II +17 more
RichRMA
Senior MemberPosts: 4,073
In reply to Gpruitt54, Jun 13, 2013
If you really go insane, you can find a paint finish to pretty much match your camera and you can actually fill dents with epoxy but it'd be a lot of work.  Just use a black magic marker.
Gpruitt54
In reply to RichRMA, Jun 13, 2013
There are only a few nicks on the body.  Surely not enough to do a paint job on the whole camera body (dred the thought). Yeah, I think a sharpie will do nicely.
Hay Great idea!  Thanks!!!
simmybear31
Junior MemberPosts: 25
I bought a d2x that had a lot of bottom edge scratching and then bought a can of Black "satin finish" car spray paint which I applied with a fine paint brush - dries in seconds and matched to the Nikon black finish a treat a few layers has helped fill the scratches - not perfect but better that the "white/light grey" scratches - it was £7.00 approx $10 and will last me a lifetime of camera scratches.
Gpruitt54
In reply to simmybear31, Jun 13, 2013
Very good idea. Multiple applications with a brudh would indeed fill in the dings, and I would not be bothered with masking the eitire camera to cover only a few scratches.
Finding a proper paint should be easy. Nikon Dx Camera bodies are a black satin finish, not flat.
