Transferring AVCHD videos to my Mac
Started Jun 10, 2013 | Discussions
GregNC Junior Member • Posts: 35
Took the family to one of those Zipline places in Mass this weekend and took lots of videos and photos.  Unfortunately when I got back home tonight and tried to download to my Macbook, the photos downloaded but the videos did not.
I typically just plug the SD card into the side of my Macbook SD slot rather then the wireless route.
Looking for solution as to how do I get my vids into my Mac?  Thanks in Advance.
GreginNorthCarolina
 GregNC's gear list:GregNC's gear list
Sony Alpha NEX-6
RGBCMYK Senior Member • Posts: 1,422
Re: Transferring AVCHD videos to my Mac
unless you set your camera to record mp4's you will need to use additional software to view.  I used Adobe Premier
www.christopherbroughton.com
 RGBCMYK's gear list:RGBCMYK's gear list
Epson Stylus Pro 4900 +1 more
Tommygun45 Senior Member • Posts: 1,324
Look into manually doing it. They are in a directory in there with a weird file name. Download VLC the video program. Its an orange and white cone. That program will let you view them but they will be huge. I hate using AVCHD on my 2008 macbook because they are so intensive it slows it down too much. But the quality is great.
 Tommygun45's gear list:Tommygun45's gear list
Sony Cyber-shot DSC-RX100 III Nikon D750 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.8G +1 more
redsim74 Senior Member • Posts: 2,156
I believe that to import AVCHD files you need to connect the camera directly to the Mac, rather than using an SD card reader.
RGBaker Contributing Member • Posts: 957
You can simply drag and drop the file from the SD card to your computer -- it is called simply 'PRIVATE' and has a Quicktime logo.  All your clips will be in this single file.  You can view it with QT or with VLC view, or if you want to import it and break out the clips you will need to use iMovie and point it at this same file.
I use either Clipwrap, a low cost app, or Premiere, to bring the clips into editing software.
GB
 RGBaker's gear list:RGBaker's gear list
Sony Alpha NEX-7 Sony E 18-55mm F3.5-5.6 OSS Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS +1 more
Rob Sims
Rob Sims Contributing Member • Posts: 589
GreginNorthCarolina
iMovie works.  I believe it should already be installed on your mac.  If you took your video at 60 fps (instead of the default 30) there might be an issue and you'll need a 3rd party converter.
In future (I know it doesn't help with the videos you already took!) you might want to think about just switching the video quality to MP4 in the settings on your camera, especially if it's for family clips where convenience is desired.
The quality of the MP4 files are still pretty good (1440x1080 30fps) and results in each clip creating an individual file. The chunky compression they employ also keeps them relatively small in size (@12Mbps), which is a huge bonus if you want to share them.  I personally find they're good enough and easier to work with than the massive AVCHD file, although you obviously lose the 1920x1080 60fps option (@28Mbps!!).  Here's a quick video I made earlier (which doesn't show the full quality was it was only uploaded at 720p):
http://www.youtube.com/watch?v=w3crMP50A_w
- I can already sense that a videographer is watching over me and will break in now to scold me for suggesting using mp4, so I'll best make a quick run for it!
 Rob Sims's gear list:Rob Sims's gear list
Sony RX100 Sony RX1 Sony Alpha 7 Sony a6000 Leica Summarit-M 90mm f/2.5 +7 more
Rob Sims
This site has a better explanation of the video formats than what I attempted to explain above:
http://www.imaging-resource.com/PRODS/sony-nex-6/sony-nex-6VIDEO.HTM
Also has a couple of sample videos shot at the different settings.
GregNC OP Junior Member • Posts: 35
Thanks to all that replied to my thread.  It appears that I will have to find a third party software to do what I want, although I'm going to try the drag and drop first as suggested and see if that works.  And from now on I will use Mp4 format.  I was following a suggestion by a professional to us APCHD as a better format, but if you can't use it what good is it? If I do find a simply solution I will post here for your information as well.
Have a great day all.  Cheers - Greg
GreginNorthCarolina
Sony Alpha NEX-6
I'm not sure how you come to the conclusion you can't use it -- I do, and it is the 'better' format of the options.  If you want to use half the bit rate, an anamorphic format of lower resolution then have at it, but it seems odd to describe the higher rate, higher resolution format as unusable.
A drag and drop will transfer it, as will the free iMovie.  Quicktime will play it as will the free VLC.
GB
saintz Contributing Member • Posts: 549
The new version of iPhoto and Aperture support AVCHD, although not 1080p60 (only the lower quality). If you upgrade iPhoto it will automatically import.
Otherwise, manually import using Quicktime to open the PRIVATE file on the SD card and then save the movies off.
Or just shoot in MP4 from now on.
 saintz's gear list:saintz's gear list
Sony a6000 Sony E 18-55mm F3.5-5.6 OSS Sony E 50mm F1.8 OSS Sony E 16-50mm F3.5-5.6 PZ OSS
SUCCESS!!! downloaded the trial version of Clipwrap and it worked like a charm even on the 60fps format!  Now I need to get one of the steady-cam units so you don't feel like you're going to puke from the movement of my videos!
Thanks all for your inputs!
GreginNorthCarolina
Sony Alpha NEX-6
Traveljunkie1 New Member • Posts: 1
Thanks for sharing your knowledge with this. I've been having trouble transferring the timelapse images from sony to macbook, and transferring my gopro time-lapse images to gopro editing app. Is it worth buying the Clipware app? Doe it really work? I didn't see any review of the clipware yet. or would you recommend getting the expensive "premiere app". I want to share my timelapse to Instsagram and Facebook.(I have the latest macbook so my computer is updated).
