HP 1270 external DVD drive read/write formats?
Started Jun 9, 2013 | Discussions
SantaFeBill
Senior MemberPosts: 2,293
Jun 9, 2013
Does anyone know if this drive can write to double-sided (dual-sided) DVDs?
The manual is too generic. It simply says to check the HP site for the answer to this question. And of course there's no longer anything about the 1270 on HP's site, except some messages in the forum that deal with another issue.
Thanks for any insight.
Torsten Hoff
Veteran MemberPosts: 3,301Gear list
Re: HP 1270 external DVD drive read/write formats?
In reply to SantaFeBill, Jun 10, 2013
I found information on a HP 1270i, which I assume is the internal SATA version. The mechanical drive and specs should be the same; if true, the drive supports both DVD+RDL and DVD-RDL media:
48xCDR CAV
32xCDRW ZCLV
24xDVD-R CAV
6xDVD-RW CLV
8xDVD-RDL ZCLV
24xDVD+R CAV
8xDVD+RW ZCLV
8xDVD+RDL ZCLV
12xDVD-RAM PCAV
http://www.videohelp.com/dvdwriters/hp-dvd1270i/2686
Free tools like ImgBurn can also display a list of drive capabilities, which would take all guessing out of the equation.
 Torsten Hoff's gear list:Torsten Hoff's gear list
Olympus E-3 Olympus E-300 Olympus E-510 Olympus E-5 Olympus E-M1 +14 more
herebefore
Veteran MemberPosts: 3,296
Did you mean Dual LAYER discs or double sided disks.  The two things are completely different.
I haven't seen any "double sided" DVDs or CDs (as blanks) for a long time.
Larry Lynch
Mystic, Connecticut
Be Careful, sleep can be a symptom of caffeine deprivation
I figured out why I cant lose weight! The only exercise Im good at is CHEWING
Don't take yourself so seriously. No one else does
In all matters of opinion, our adversaries are insane.
Oscar Wilde
SantaFeBill
In reply to herebefore, Jun 10, 2013
Larry Lynch
Mystic, Connecticut
Oscar Wilde
Thanks. I of course meant dual layer. I was suffering from caffeine deprivation when I wrote my post ... .
SantaFeBill
In reply to Torsten Hoff, Jun 10, 2013
Thanks very much!
