Which one D3200, D5100 or D90??
Started Jun 9, 2013 | Discussions
rohanmanohar New Member • Posts: 1
Hi I'm now looking at getting a decent entry level DSLR,
A little experience with film cameras but pick things up straight away so even with a pro camera I will eventually work out the system.
Basically I would like your opinion on which camera set I should get and why?
Nikon D3200 Nikon D5100 Nikon D90
kgbruce01 Senior Member • Posts: 1,245
Re: Which one D3200, D5100 or D90??
The one that costs the least. Why? So you can get a nice lens, a flash, a tripod, a camera bag, cleaning kit, an extra battery, a memory card,  and all the other little things that go along with a new camera system.
If you really can figure things out quickly, then you will be able to produce more, with less. Good luck.
BlueJakester
BlueJakester Senior Member • Posts: 2,079
I cannot tell you which of these three is best for you, but I can tell you what I bought as my first DSLR a couple of months ago: a refurbished D3100.
It came with the 18-55mm kit lens. If I had to do it over again I would try to buy the body only and buy a sharper lens, like the 35 f/1.8 prime for $200.
Regarding the D3100, I think it has been an excellent learning platform. From what I have read here and elsewhere, the D3200 is an even better camera. That said, I'm taking advantage of Nikon's current "Buy together and save" promotion and have just ordered the D5200 and 70-300 lens.
http://www.bhphotovideo.com/c/promotion/10386/nikon-buy-together-and-save.html
That deal is on until June 29th according to the B&H page.
D3100 with 35mm F/1.8 prime lens
stevenjames
stevenjames Senior Member • Posts: 1,145
D90. It has more advanced features than the other two.
Steve
www.StevenJamesPhotography.com
 stevenjames's gear list:stevenjames's gear list
Fujifilm X100S Nikon D7200 Nikon AF-S DX Micro-Nikkor 85mm f/3.5G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 50mm f/1.8G +9 more
CaptainAmerica Forum Member • Posts: 86
I have had a D90 for three years and recently got a D3200 for my daughter. Despite the higher resolution and newer electronics in the D3200, I still prefer the D90 because:
- It has more dedicated buttons
- It has more features
- The larger and heavier body fits my hands better
- The viewfinder is larger and brighter
I have no experience with the D5100. Of course some of what I consider pluses in the D90 could be minuses for others
photoeng Senior Member • Posts: 1,129
Of the three you listed - the D90 is the only one with in body focusing motor.  With the in body focusing motor, you can use the 50mm F1.8 AF or AF D which is a stellar lens which can easily be found for $100.
David
http://photo.blogrlabs.com/
My gear list: D40 / D70s / D200
A bunch of lenses
 photoeng's gear list:photoeng's gear list
Panasonic Lumix DMC-LX5 Nikon D70s Nikon D300 Nikon AF Nikkor 50mm f/1.8D Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G II +7 more
sworth Contributing Member • Posts: 937
D7000 Refurb.
I use my 50mm f/1.8D on my D40 & D5000 all the time... And they don't have focussing motors. Why would someone not be able to use it on a D5200 or D3200?
Wait, there isn't a reason.
David
A bunch of lenses
gunkan
gunkan Regular Member • Posts: 187
D90 es que best choice for the money.
I was in the same point that you but i finally got a Nikon D5100. The reason was the price.
D5100 is very limiting in a lot of characteristics (1/4000 without iso low), but the sensor is better than D90 and is cheaper.
 gunkan's gear list:gunkan's gear list
Panasonic Lumix DMC-FZ1000 Nikon D40 Sony Alpha 7 Samyang 14mm F2.8 IF ED MC Aspherical +4 more
john Clinch Veteran Member • Posts: 3,040
I think AF has many benefits and to pretend that the lack of focus motor is no issue isn't helpful. Yes its possible to autofocus....
Its worth playing with the cameras. In the end I got a lightly used D90 mainly for the view finder. The Af points are easier to see, it has grid lines which I find useful for getting the camera level. The viewfinder is alot bigger and brighter
AdamT
AdamT Forum Pro • Posts: 58,425
Yep agree
D7000 refurb by a Mile .
Canon PowerShot G1 X Nikon Coolpix P330 Panasonic Lumix DMC-GM5
Poor John
John, have you ever evenconsidered that its just YOU that has a problem manual focussing? You know, we did it for years and years years with no problems whatsoever. (and still do to this very day)
Dont go thinking that just because manually focussing is problematic for you, that it is for everyone. That is the height of huberous. I can teach you some tricks to learn how, send me an email... I can tech you to drive your camera without autofocus or the cameras meter.
Interested, John? Or are you a 'line up the meter blindly and press go' type of shooter?
Just checked your entire gallery of photos and counted the number of shots where you came up to this 'limitation' of 1/4000th of a second exposure time... Seems its a huge limitation for your type of shooting there.
fotolopithecus Senior Member • Posts: 1,699
D5100, if you don't mind a smaller dimmer viewfinder than the D90.
 fotolopithecus's gear list:fotolopithecus's gear list
Nikon D610 Nikon AF-S Nikkor 50mm f/1.8G Tamron SP AF 90mm F/2.8 Di Macro
Brev00
Brev00 Veteran Member • Posts: 7,429
I think all three can be a perfectly good way to go in terms of image quality. What may make a difference for you is body size and weight. You may want to handle each to get a feel for what you will be gripping. I shoot with a D90 and have also used a D5100. The D5100 seems much smaller and lighter especially with the small kit lens attached. My D90's size is an advantage for me in balancing a heavier zoom. If you check them out, I think the decision will come easily.
http://www.flickr.com/photos/brev00
 Brev00's gear list:Brev00's gear list
Nikon D90 Nikon D7100 Tokina AT-X Pro 12-24mm f/4 DX II Sigma 17-70mm F2.8-4 DC Macro OS HSM Sigma 70mm F2.8 EX DG Macro +3 more
Re: Poor John
Interesting point. I only manual focus my dslr when zone focusing for stitching. So yes you are probably correct I do have a problem manual focusing.
Thanks. As it happens I did know that. Infact I've owned 5 SLR cameras in my life time. 2 digital 1 AF film 2 manual focus film. My recollection is that both the manual focus SLRs had huge bright view finders, a far cry than the dark tunnel on say my D70s and other pentamirror cameras. They also had excellent focusing aids which did make focus confirmation very easy.
Yes you right its not something I've not really tried. Not sure how you knew that I wasn't good at manual focusing as I never said I found it difficult. I merely pointed that not having being able to use AF if you want to is a disadvantage. I still stand by that
It would be if it was true but I didn't assume others can't manual focus
I probably am guilty of over using the cameras meter. Less so on the D90 than the D70s where I use exposure compensation more often. The D70s meter was much more consistent. Icertainly rely on post processing RAW files to get what I want. Usually I use aperture priority. I have done some long exposure work, that takes more thought. As does manual exposure for stitching where the chosen exposure is a balance of the needs of numerous photos
Sadly when I wrote this I didn't notice I'd typed autofocus as the last word, I meant manual focus. oops sorry
John
