light reverse engineering
Started Jun 9, 2013 | Discussions
b4cktr4ck Regular Member • Posts: 156
Hi,
I'd like to take a photo with a similar result
what I can see:
One light camera left high (shadow of the collar left side of model)
One light (beauty dish?) front of model?
One light camera right? (shadow from shirt model right and from face on collar model right)
One light for the hair camera right behind model?
One light on the background
What I like is that on both sides of the model's face there is a bit of shadow, how is this achieved?
I like the position of the head where the right side of the model is in axis with the camera and hides the ear
What I have: 3 lights (Yongnuo flashes) , 2 white shoot thru umbrellas, 1 silver reflective umbrella, 1 softbox, 1 black/white background panel
 b4cktr4ck's gear list:b4cktr4ck's gear list
Canon EOS 6D
kgbruce01 Senior Member • Posts: 1,245
Re: light reverse engineering
You haven't accounted for the addition light source in front (look at catch lights in eyes)
b4cktr4ck OP Regular Member • Posts: 156
clamshell?
Canon EOS 6D
hotdog321
hotdog321 Forum Pro • Posts: 15,447
Looking at the catchlights, I see a broad softbox directly in front of the subject set high and a second softbox or reflector down low. Both are dead center on the subject. There might be a light hitting the seamless directly behind her, or it might be done PP.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
Klaus dk
Klaus dk Veteran Member • Posts: 3,342
Maybe the top light is a beauty dish, but yes, I'd say clamshell dead center. And there's a hairlight, camera right.
 Klaus dk's gear list:Klaus dk's gear list
Canon PowerShot S120 Canon EOS 500D Canon EOS 7D Canon EF 35mm f/2.0 Canon EF 50mm f/1.8 II +9 more
hotdog321
Oh yeah, I overlooked the hair light. Might be spill from the light in back, too.
TiagoReil
TiagoReil Senior Member • Posts: 1,565
b4cktr4ck wrote:
Hi,
what I can see:
Clamshell in the front of the subject (be it with a beauty dish, a softbox, or what ever, and probably a reflector)
Rim light on our right, that gets her shoulder and part of the hair lit.
Background light.
I think that is all. Dont see any more lights there.
 TiagoReil's gear list:TiagoReil's gear list
Sony Alpha NEX-5 Sony Alpha NEX-6 Sony E 18-55mm F3.5-5.6 OSS Sony 85mm F2.8 SAM Sigma 70mm F2.8 EX DG Macro +3 more
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,161
The pose is well done and does hide the right ear perfectly.  You can learn a lot about posing from this free video tutorial.  Watch it, wait a couple of days, then watch it again - you'll learn more fine details of posing the second time than the first.
Sekonic - Frank Dispensa - Classical Posing and Portrait Lighting
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
Clueless Wanderer
Clueless Wanderer Senior Member • Posts: 1,142
b4cktr4ck wrote:
Hi,
what I can see:
Im going down the beauty dish above camera, clamshell path. I think there is a good chance that the camera right hair light is doing double duty for the hair and background. I really like the lighting a lot..
 Clueless Wanderer's gear list:Clueless Wanderer's gear list
Nikon D200 Nikon D700 Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +21 more
thanks all for the contributions. Will share my attempts soon
Canon EOS 6D
DecibelPhoto Contributing Member • Posts: 791
You have too many lights.  There are likely 3 lights, maybe 4.  Main light is centered above face, probably a medium-ish box.  Then either a reflector or active fill below.  There is a very mild hair light, and a background light.  Fairly straight forward setup.
b4cktr4ck wrote:
Hi,
what I can see:
yep makes sense in line with most of the people guessed.
Would it work to reproduce this setup using a clamshell with softbox up high and umbrella low?
For the hair light what's the best option? can a bare flash do the job?
Canon EOS 6D
