Dumb Lenovo R61 question/s
Started Jun 9, 2013 | Discussions
scott_mcleod Contributing Member • Posts: 968
Ok so a couple of days ago I noticed that my trusty (ahem) R61 was not charging. The battery is a large OEM replacement and fairly new. The AC adapter is plugged in and working - I measured 20.1V across the terminals (open circuit) and it charges my folks' Lenovo laptop. While I was able to get to it the battery monitor showed that it was still "Good" with something like 64Wh of capacity still available (though almost flat at the moment). Currently (sorry!) the battery does not have enough charge to go through a normal shutdown.
By a process of elimination:
- if the battery monitor can be trusted, it's still good (but I don't have another R-series to try it in)
- the AC adapter is good, because it's charging another machine as I type this
- the R61 does nothing with the battery removed and the AC adapter plugged in - should it be able to run like this? I mean no lights, nothing, it's totally dead
- that leaves the power management circuitry on the motherboard. If that's fried I'm looking at a new machine, correct?
Does this sound like I'm on the right track? I know this is an old machine that's been turned on almost continuously since 2007, but I've installed extra RAM, a new HDD (cloned from the original), a new fan/heatsink (PITA), and replaced the battery. So you could say I have a lot of time and effort invested in this thing and I am loath to replace it if I'm wrong.
The other thing that's giving me a headache is that I have a legal, activated copy of PS on it (the other copy is on the desktop). If the mobo is fried, I need to find some way to deactivate it so I can install & activate it on whatever I replace it with, which sounds like an adventure I could live without...
Any advice on whether this machine is actually deceased or if I've missed something obvious would be greatly appreciated
TIA,
Scott
Ricoh Caplio R6
digitalshooter
digitalshooter Forum Pro • Posts: 19,604
Re: Dumb Lenovo R61 question/s
You should be able to run off of power supply no battery.
You can call Adobe if there is an issue if you need to reinstall.
Thanks,
Digitalshooter
PS: all posts are just my opinion!
 digitalshooter's gear list:digitalshooter's gear list
Sony Alpha DSLR-A700 Canon Pixma Pro9000 Mark II
herebefore
herebefore Veteran Member • Posts: 3,296
TIA,
Scott
The socket inside the laptop that receives the plug from the power supply is broken. (not passing power to the laptop).
This can happen if the power cord gets "Yanked" fro the laptop..  I have a laptop in my basement, collecting dust, from this sort of damage.
Larry Lynch
Mystic, Connecticut
Be Careful, sleep can be a symptom of caffeine deprivation
I figured out why I cant lose weight! The only exercise Im good at is CHEWING
Don't take yourself so seriously. No one else does
In all matters of opinion, our adversaries are insane.
Oscar Wilde
digitalshooter
If the plug has come loose on the mainboard, its an easy repair (nt)
Thanks,
Digitalshooter
scott_mcleod OP Contributing Member • Posts: 968
Ok, so the problem issomewhere inside the laptop
Cool - thanks for the tip!
Scott
Thanks,
Digitalshooter
Thanks for this - the way my machine sits on the desk at home puts the power cord/socket at an undesirable angle. I've had this thing in pieces before (*sigh*) so checking the condition of the power socket should be easy...
Once more into the breach! (but fingers X'ed just the same)
Scott
