Optimal Memory Cards for x100s?
Started Jun 7, 2013 | Discussions
Steve Rothman Junior Member • Posts: 41
I've just purchased an x100s and wonder about memory cards. The author of Mastering the Art of the Fujifilm X-Pro 1 says that he and many of his colleagues recommend the fastest card available (95 MB/s I think). He says, that especially for bracketing function this is useful. The local camera store guys (Glazers in Seattle) say that there is no advantage to these super fast cards, except for shooting hi-def video. I'm probably not going to do much hi-def video. Do you all believe that the fastest cards are useful for still shooting?
Thanks, Steve (near Seattle)
Fujifilm X100S
muzzlok
muzzlok Junior Member • Posts: 48
Re: Optimal Memory Cards for x100s?
For stills only, I prefer the 95 MB/s speed and 8 gbyte storage card.  It's fairly cheep around $20 USD and allows thousands of pics before you need to move them to a long-term storage/burn to disk option.
http://www.amazon.com/SanDisk-Extreme-Class-Memory-SDSDXPA-008G-AFFP/dp/B007NDL542
I find the start up of my X100/X100s to be faster too.
Enjoy.
 muzzlok's gear list:muzzlok's gear list
Fujifilm FinePix X100
El Chubasco
El Chubasco Contributing Member • Posts: 511
Enjoy.
+1
 El Chubasco's gear list:El Chubasco's gear list
Fujifilm X-Pro1 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +12 more
Travelshooter Senior Member • Posts: 1,976
+2 with a caveat.  I prefer 32gb size since I can average 100+ frames a day traveling and shoot raw on trips. The XP-1 get 1291 raw images to a 32gb card. For a three week trip I would take three cards.
Martindareff.com/National-Parks-and-Historic/Miami-Zoo-FebruaRY-2011/15942203_4fbco#1195817020_VhtD6-L-LB
 Travelshooter's gear list:Travelshooter's gear list
Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R +14 more
Steve Rothman OP Junior Member • Posts: 41
Many thanks to both of you for your responses.
Steve
Jonavin
Jonavin Regular Member • Posts: 438
I agree on the card and the 32GB size. It seems to be the best cost/GB anyways.
 Jonavin's gear list:Jonavin's gear list
Fujifilm X100S Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
lnbolch
lnbolch Senior Member • Posts: 1,995
I treated myself to the 95Mb/s card and did an unscientific test of it against the 45Mb/s card I had been using. I filled the X-Pro1 buffer with each card and timed how long it took to shoot and to clear. The fast card took about half the time—about 20 seconds vs 45-50 seconds.
That said, the slower card never caused the loss of a single exposure. I started out with an ordinary Class 10 card with the X100, followed by the faster cards. Shooting sports or video with a dSLR, there would be a significant advantage, but the Fuji cameras tend to encourage a more contemplative and less machine-gun approach.
On the other hand, with cards being so cheap, why not go for the fastest? If you shoot sequences, they do write to the card more quickly. When you transfer to the hard-drive, they will read more quickly as well. The difference in price is really not significant any more.  When I began moving to digital cameras, a gigabyte of cards (195MB was the biggest) a gigabyte of storage was $2,550US on very slow cards. Not hard to find a gig for a buck now, even with Class 10 speed.
 lnbolch's gear list:lnbolch's gear list
Fujifilm FinePix Real 3D W1 Fujifilm FinePix X100 Nikon D700 Fujifilm X-Pro1 Nikon AF-S Nikkor 14-24mm f/2.8G ED +8 more
CraigArnold Contributing Member • Posts: 695
With the X100 there was certainly a very large difference in responsiveness and stability when using a fast card.45Mb/s was essential, with only a minor improvement at 95. But 30 or below was horrible.
The X100s however has much faster electronics and a much larger buffer so you may not need a very fast card. However fast cards are not very expensive, and if you buy online there is almost no penalty to getting a 95Mb/s card.
A fast card is never going to slow your camera down, and I would much rather have an 8Gb fast card than a 32Gb slower card. But really we are now only talking about a difference of 20$ on a $1000 camera. It's not like there are a million extras needed for the X100s - go on get a good card.
Blog ------------------------ http://craigspics.net/?tag=blog
X100 Blog ----------------- http://craigspics.net/?cat=6
X100 Quickstart Guide -- http://craigspics.net/?page_id=1345
 CraigArnold's gear list:CraigArnold's gear list
Fujifilm FinePix X100 Olympus Tough TG-4 Sony Alpha 7R Sony FE 35mm F2.8 Sony FE 55mm F1.8 +2 more
Indulis Bernsteins Regular Member • Posts: 439
I found out there are cards that say 45 MBytes/sec but it is only for READ, in small print the card is slower for write.
However the Sandisk card at 90 MB/sec really *is* 90MB/sec write. Same for their 45 MB/sec card.
In the X-E1 the difference between a real 45MB/sec card and a 90 MB/sec card was small.
But the X-100S is a newer camera and may be able to drive data to the  card faster, so you may be able to take advantage of the speed difference of the 90 MB/sec card.
A cheap way to find out is to get 2 x 8GB cards, one of each. Do the test. Then buy the bigger capacity card. That way you have "emergency" cards which you can use in case the main card bites the dust.
 Indulis Bernsteins's gear list:Indulis Bernsteins's gear list
Fujifilm X-E1 Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-200mm f/4L IS USM Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
NachoYogi Regular Member • Posts: 142
+1 Well said.
 NachoYogi's gear list:NachoYogi's gear list
Canon PowerShot G10 Canon PowerShot S110 Fujifilm X100S Nikon D300S Fujifilm X-Pro1 +9 more
baobob
baobob Veteran Member • Posts: 7,222
32gb or bigger UHS SD
This as you mentionned allows any type of combination FJPEG+RAW, bracketing, large autonomy during a trip
Ideally 2 32GB for flexibility and safety better than 1 64GB
Sony RX100 Olympus Tough TG-4 Fujifilm X-T1 Nikon D7200 Fujifilm X-T10 +12 more
