After a Big Hassle
Started Jun 6, 2013 | Discussions
PaulM2 Senior Member • Posts: 2,729
After a Big Hassle
Earlier in one of my posts, we discussed dual boot etc. I needed to upgrade my OS, but had a problem with my CAD software in WIN7.
I decided to take some of your advice from that earlier post and to keep it simple with a dual boot WIN7/XP. I purchased 32bit WIN7 Home Premium-System Builder Pack and as I had plenty of room on my main hard drive, I decided to re-partition.
While running the partition software, every thing was going well and the partion's were going to be what I needed. Then the computer gods decided to throw in the "monkey wrench". Here at the Apartment Complex, we had one of those power interruptions where the power goes off, then back on in maybe 10 sec. or so. Wow when I booted the computer back up I received an error message. After fooling a bit I put my WIN XP CD in and booted to the repair. Told me that it was unable to fix.
That was 6 days ago and many hours spent on a recovery. I did not want to loose the listings for software. I have backups for most every thing, but at that point I did not know what I was dealing with.
I have a 160GB hard drive with XP on it in the closet, so I put that in the computer after a disconnect of one of the other backup hard drives. Changed the boot order and found that my old master hard drive that I was working on with the partion software, was really messed up. All the drive letters had changed in a crazy order.Some had split data and put in other drives. A big mess.
Back to the 6 days/hours, I now have the big original hard drive straightened out with 4 partitions,(still messed up drive letters) a working copy of both WIN7 and XP (dual boot works well) and I am in the process of getting every thing I basically need working again on XP which I more familiar with. My plan is to get XP some what up to speed, then in WIN7, get that populated.
I have had computer problems before, mostly hardware failures, never anything this complex. The thing that I have found is that backups are great, providing you have a place to restore to. This leads me to the following questions.
What do you people do to store license numbers? In most cases in the past, I had done a screen copy of the email that had the numbers and saved them to a folder. That was one of the folders that is unreadable. So I guess I will now store them on a flash drive?
Another question. With dual boot, am I correct that software must be installed for each OS? How do you handle email?
I have a lot more questions, some will fall in place as I work on this dual boot, but this post is now long enough.
Paul
malch Forum Pro • Posts: 13,126
Re: After a Big Hassle
Seriously, invest in a good quality UPS so you don't have to deal with that kind of nonsense again.
Just keep them in a simple ASCII text file using Notepad or your favorite replacement.
I have a bunch of such files for different purposes including one for software serials. Actually, I share them via Google Drive so they're backed up and available anywhere. Some more sensitive files are additionally encrypted.
I use Thunderbird and this is quite easy to handle.
I place my Thunderbird profile on one of my data drives. Then either operating system and copy of Thunderbird can access the same profile which includes your mail server configurations and mailboxes.
Jim Cockfield Forum Pro • Posts: 16,333
Why 32 bit? Disk image backups
What kind of PC do you have?
I'm wondering why you would go with a 32 bit Operating System, as most any CPU made in a number of years in going to support a 64 bit instruction set.   Yea... 64 Bit versions take a little more memory, but not much more, and you're limiting your flexibility by using a 32 bit OS.
Heck, I've got a netbook with a single core Celeron CPU and only 2GB of memory that I still have 64 Bit Operating Systems installed on (64 Bit Win 7 + 64 Bit Linux distros).   64 Bit versions don't take much more memory, and you get more flexibility that way, along with the ability to add more memory later that will be used by the OS.
Are you a Photoshop user?  I'm not, but it's very popular with photographers using Windows.
If you have a 32 bit version of Windows, then Photoshop will only use around 1.7GB of it, no matter how much you have installed.
http://helpx.adobe.com/photoshop/kb/64-bit-os-benefits-limitations.html#main_RAM_use_Win
For that matter, even Windows itself will only be able to use around 3.2GB of the memory you have installed, no matter how much you have (but, a 32 bit version of Photoshop won't use more than 1.7GB of it).
That's just a limitation of a 32 bit Operating System and the way the 32 Bit version of CS6 works.   You need to go with 64 bit versions for Photoshop to be able to use more of the memory you have installed.
But, you'll see the same types of issues with many other apps.  You're better off going with a 64 bit OS if your hardware supports it (and most CPUs made for a long time will support a 64 bit instruction set), as more and more apps are being optimized for  64 bit instruction sets anymore.
Another thing to consider... if you have enough memory available, run XP in a Virtual Machine under Windows 7.
With Win 7 Pro (and you can update to it from Home Premium with a new product key), you have what Microsoft refers to as XP Mode available (which is just XP running inside of Microsoft Virtual PC).  That way, you're running XP in a Window under Windows 7; and you can setup shared access to the same folders.
You can also use the free Oracle VirtualBox for that purpose, where you can install XP in a Virtual machine so that you're running both XP and Windows 7 at the same time.  Get it here (and again, it's free):
https://www.virtualbox.org/
Or, use the free VMWare Player and do the same thing (install another Operating System like XP in a Virtual Machine under Windows 7).
http://www.vmware.com/products/player/
I've got both Oracle VirtualBox and VMWare Player installed in Linux (so I can run other LInux distros, different versions of Windows, etc. at the same time I'm running Linux, so that I don't need to reboot to use a different Operating System).
Anyway, after you get everything up and running again, get in the habit of making full disk image backups on a regular basis.
That way, in the event of an issue (like the problem you just had), you can restore that disk image back so you'll be right back to where you were at the time you made it.
There are many other things that can cause serious issues (malware, software installations causing conflicts, human error, theft, fire, drive failures, and more).
So, unless you want to reinstall the Operating Systems, Programs, etc., from scratch if (or more likely, WHEN versus if) those kinds of problems occur, have a disk image backup you can restore from, and make new backups on a regular basis.
You can find a number of free utilities to make them.  For example, I've seen others here mention liking Macrum Reflect.  Get it here:
http://www.macrium.com/reflectfree.aspx
Personally, I use Clonezilla Live for that purpose.  More about it in this post:
http://www.dpreview.com/forums/post/39974007
There are many more solutions around.  But, you need to have a recent disk image backup handy for issues that may occur (as you could have a drive failure today for all you know, not just a "glitch" caused by a power failure).
JimC
PaulM2 OP Senior Member • Posts: 2,729
Thanks for the reply.
I am still playing catch up with what I can salvage from the XP stuff.It is so disorganized that at times I am considering either a whole new computer or even none at all.
But I appreciate the help.
Re: Why 32 bit? Disk image backups
Thanks Jim for your reply.
My problem ,as I see it, is one of trying to salvage what I can, rather than what I should have done.
Recently I had a birthday and I realize that at my age, I probably should give up on computers. But then again, I probably should have addressed this years ago.
At my last visit to the VA, for my annual checkup, the Doctor, who knows that I have an interest in Photography/Computers, showed me a computer program that some one, with a lot of spare time, had written. It predicted your life span along with items that deserved closer medical attention. It was based on my past medical history, that was inputed, the result showed another 8-1/2 years, not considered were Mack Trucks, Airplanes. Banana peels etc. If I am careful, I just might make the "Smucker's Jar".
But seriously, I do appreciate your help.
The problem that I have at this moment is with the dual boot. Virus checkers etc. in both boots,  Mail in WIN7, etc. But that makes life interesting?
