What to take ? 4 days in London
Started Jun 6, 2013 | Discussions
Zlik Contributing Member • Posts: 990
Hi, I am flying to London in a couple of hours. I will visit London with my girlfriend (= gotta take care of her between the shots ) for 3-4 days.
Here is what I packed so far:
  • Nikon D800
  • Nikon 24-70/2.8 AF-S
  • Nikon 20/2.8 AI-S
  • Nikon 85/1.8 AF
  • ND8 + c. pol for the 20 + 85 lenses
  • lots of memory cards
  • second battery
  • small tripod (~10 inches high, high quality metal construction )
  • GPS tracker
What I am leaving at home:
  • Nikon D3200
  • Nikon 35/1.8 DX AF-S
  • Nikon 50/1.4 AF (I would have taken it with me, but the left side has sharpness problems)
  • Nikon 80-200/2.8 AF-D
  • Nikon 70-210/4-5.6 AF
  • Nikon 28-85/3.5-4.5 AF
  • Nikon 105/2.5 AI-S
  • Nikon 135/2.8 AI-S
Would you change anything ? I am trying to keep the weight down (carrying everything all day) without compromising quality. I prefer to have less focal lenghts but with excellent quality than to cover almost everything with lower quality.
Nikon D3200 Nikon D800
Zlik OP Contributing Member • Posts: 990
Re: What to take ? 4 days in London
Oh and by the way, there is a shop on the way to the train station that has the Nikkor AF-S 50mm f/1.8 G at a very good price (converted to 205$), which will replace my deffective 50/1.4. I could grab it on my way, and leave the 85/1.8 at home to save some weight and to have a more usable focal length for low light, because I am not sure that I will do a lot of portraits there...
Simon Garrett Veteran Member • Posts: 4,991
Even in cities, I usually take something long (>150mm).
You mention a few things other than lenses; I assume you're including a charger for your batteries (and power adapter, or get one at the airport, or pretty much any tourist gift shop in London).  Flash?
Simon
 Simon Garrett's gear list:Simon Garrett's gear list
Nikon D800
Peter Budd
Peter Budd Senior Member • Posts: 1,002
Personally as someone who grew up in london I would not bother with the 85mm ( or 50mm ) unless you have something specific planned.  The weather is good in London at the moment 22-24 degres C. Lots of sunshine. You will need the 20mm if inside, churches etc.  For 4 days that would do me.
Peter
GMT
 Peter Budd's gear list:Peter Budd's gear list
Nikon D810 Olympus E-PL7 Nikon D500 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G ED VR II +15 more
Keith Aitken Veteran Member • Posts: 6,564
I agree w/ Simon - I would find that 70/85mm is not enough range, especially on FF. Obviously we all have different priorities
WA and low-light lenses are strong contenders for the prize, although with the D800 maybe not so vital. On FF I like to go out to around 200mm when travelling. Nikon's 180mm AF F/2.8 for instance makes a lightish, fast mid-telephoto - I know you don't have that one, and the 80-200 is a bit of a beast, but . . . Hard to leave the 24-70 behind, too
Even in churches, or inside buildings, one can sometimes need to isolate a higher item, statue, architectural accent, distant subject whatever, and 85mm doesn't cope with that.
I was just in London in April, using FF with a 28-200mm, 180mm, 85 f/1.4 and fisheye, all of which were used. Also had a 50mm. Though I tend to be a prime user, the 28-200 got the most walkaround use, then the 85mm, with the 180mm and 10.5 fisheye about the same . . .
Maybe you shouldn't take your camera, and just concentrate on the GF
Have a great trip
Keith
 Keith Aitken's gear list:Keith Aitken's gear list
Nikon D3S
Simon
Yes, charger included . But I was forgetting the power adapter, thanks !
I don't know if I should take the 70-210/4-5.6 ... I am not a big fan of the quality and the whole bag is getting a little heavy... Difficult choice.
Maybe I should reconsider my travel kit. In the future, I might go for this set:
Nikon 18-35/3.5-4.5G AF-S
Nikon 50/1.8G AF-S
Nikon 70-200/4 G AF-S VR
And keep the 24-70 and 85/1.8 for events. Don't know if I should sell the 80-200/2.8 after getting the 70-200/4 VR...
forest23 Forum Member • Posts: 60
I suggest a pub crawl in the back streets off Tottenham court road will be worthwhile.
So a 50mm 1.4 will come in handy. The british Museum is also nearby for still life! and crowd shots.
bob M
