Sharpest lightweight UWA lens in the corners of FX around F/5.6-11?
Started Jun 5, 2013 | Discussions
Zlik
Contributing MemberPosts: 989
Jun 5, 2013
What is the absolute sharpest lens corner to corner on FX under 19mm and under 900g ? And which one is the best value (performance/price) ? Max aperture is not important.
I am using a D800 and the wide angle lenses I currently own are the Nikkor 20/2.8 AI-S and the Nikkor 24-70/2.8 AF-S. I am looking for something a little wider (around 16-18mm), especially for landscapes and some architecture, and that doesn't weight more than 900g (2 pounds).
Nikon D800
narddogg81
Senior MemberPosts: 1,029
Re: Sharpest lightweight UWA lens in the corners of FX around F/5.6-11?
In reply to Zlik, Jun 5, 2013
either the nikon 16-35 f4 (680 grams) or the new nikon 18-35 G (385 grams).  both the nikon 14-24 and tokina 16-28 are sharper in the corners but heavier than what you specify and both flare really badly.  there is the zeiss 18mm 3.5, but the new nikon 18-35g has almost exactly the same resolution characteristics as the zeis, is lighter, is a zoom, is much less expensive, has 77mm filter threads instead of 82mm, etc...
the new 18-35 measures as more even across the frame, while the 16-35 can achieve higher peak sharpness in the center.
zeiss
http://www.photozone.de/nikon_ff/584-zeisszf1835ff?start=1
nikon 18-35
http://www.photozone.de/nikon_ff/821-nikkorafs18353545ff?start=1
nikon 16-35
http://www.photozone.de/nikon_ff/492-nikkor_afs_1635_4_ff?start=1
narddogg81
In reply to narddogg81, Jun 5, 2013
here are the same figures for the 20 2.8 (af version, but should be the same optics as your current lens)
http://www.photozone.de/nikon_ff/617-nikkorafd2028ff?start=1
anotherMike
Veteran MemberPosts: 7,881
There is no answer. Wide angles are tough designs and the d800 is ruthless at exposing their weaknesses in the corners. The only two ultrawides that I'd deem having really good corner sharpness at the 18mm and below are the 15mm Zeiss and 14-24 Nikkor, both of which fall outside your weight/size parameters. You're going to have to give up either performance or weight - take your pick, although some folks like the Tokina zoom...
-m
Leon Obers
Senior MemberPosts: 2,788
sorry faulty information
Skipped text
Leon Obers
Zlik
Zlik OP
In reply to narddogg81, Jun 6, 2013
Thanks for the response. The Nikon 18-35 4.5-5.6 looks like a really good compromise between quality, weight and price !
Zlik
Zlik OP
In reply to anotherMike, Jun 6, 2013
Yes, the 15mm Zeiss and the Nikkor 14-24 are definitely some of the best ultra wide angles around, but you pay price and the weight.
What about the Samyang/Rokinon 14mm F/2.8 UMC ? How does it compare to the Zeiss 15mm stopped down ? 14mm (or 15) might be a little too wide for my use, I would ideally get something in the 16-18mm range... The Nikon AF-S 18-35mm F/4.5-5.6 looks tempting for the price/weight.
Thanks again!
kymarto
Contributing MemberPosts: 639
Surprise!
In reply to Leon Obers, Jun 6, 2013
anotherMike
In reply to Zlik, Jun 6, 2013
If you get the Samyang, buy two - you can't get them serviced easiliy and they are built like you-know-what (curse word).
I unfortunately haven't been able to get my hands on the new 18-35 to evaluate it, so I can't say much about it.
You're right that 14/15mm is crazy wide....
-m
RBFresno
Forum ProPosts: 10,724Gear list
Re: Surprise!
In reply to kymarto, Jun 6, 2013
 RBFresno's gear list:RBFresno's gear list
Nikon D2H Nikon D4 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +12 more
mattr
Veteran MemberPosts: 3,500
As others have said, the Nikon 18-35G is probably your best option, I like mine a lot. Color/contrast/flare resistance are all excellent.
I also have a Rokinon 14/2.8 and it is terrible in the corners (maybe a bad copy).
jfk
jfk
Senior MemberPosts: 2,966
I would definetly check out the Nikon 18-35G.  I'm not sure if you made a typo, but it's a 3.5-4.5 lens.
jfk
Zlik
Zlik OP
In reply to jfk, Jun 11, 2013
Thanks, I will check the 18-35 G.
