Nex 5n noisy lcd when shooting in low light
Started Jun 5, 2013 | Questions
Taufiq Ahmed
Taufiq Ahmed New Member • Posts: 2
My Sony Nex 5n LCD becomes really noisy when shooting at low light (dark environment). Although it doesn't show up when you are reviewing the pictures. Is it normal? I didn't have this issue with my previous Canon S90.
This doesn't seems to be happening in Day or very bright environment.
love minimalism and simplicity
 Taufiq Ahmed's gear list:Taufiq Ahmed's gear list
NEX-5T Sigma 30mm F2.8 EX DN Adobe Photoshop Elements 10 DxO Optics Pro Standard
Canon PowerShot S90 Sony Alpha NEX-5N
D Cox Forum Pro • Posts: 13,874
Re: Nex 5n noisy lcd when shooting in low light
This is normal.
nevercat Senior Member • Posts: 3,193
Yes it is normal. To show a usable picture in live view you have to use a kind of video mode, taking 25 or 30 fps,. In dark situations, the camera has to bump up the ISO, to give you a usable view, this can end in noisy liveview. The exposuretime off the picture in the end is shorter and at lower ISO and will not show the noise.Why your Canon did not have this? Maybe that camera used a larger apperture, or it applied more noise reduction in live view. Maybe the LCD was smaller, not showing the noise as much...
Trollmann Senior Member • Posts: 1,311
We can have it two ways in the dark:
- fast update and grainy images (due to short integration times, physics dictate)
- slow update and less grainy images (the price to pay is lag)
Sony offer a grainy view almost without lag even when it gets dark - to me that is a sound choice.
Taufiq Ahmed
Taufiq Ahmed OP New Member • Posts: 2
Thank you very much. I was worried
TiagoReil
TiagoReil Senior Member • Posts: 1,568
As many said, this is cause there is no magic in the LCD, it is still a video in low light, and to achieve it, sony bumps the ISO for preview/LCD/EVF. On a conventional DSLR you would get a dark viewfinder. On an electronic viewfinder you get noise, but you are able to see what you are shooting. As others have said, the other option is lag.
 TiagoReil's gear list:TiagoReil's gear list
Sony Alpha NEX-5 Sony Alpha NEX-6 Sony E 18-55mm F3.5-5.6 OSS Sony 85mm F2.8 SAM Sigma 70mm F2.8 EX DG Macro +3 more
Zhe Zhang Regular Member • Posts: 161
My NEX-3N's LCD is very noisy as well in low light, especially if you set the LCD brightness to "sunny weather". However, under the same condition, the LCD noise of my other NEX-5R is a lot less without significant lag. The noise in the pictures are minimum in both cases. Not sure what is the reason. Maybe Sony used some kind of noise reduction on the signal to the NEX-5R display?
 Zhe Zhang's gear list:Zhe Zhang's gear list
NEX5R Sony Alpha NEX-3N +3 more
forpetessake
forpetessake Senior Member • Posts: 4,892
And people will complain no matter which of the two solutions manufacturers would choose. I'd suggest they had an option for the user to select the low light refresh rate.
I'm of the opposite opinion. I think Fuji did it right keeping the images in EVF clean at the expense of motion lag. We are talking about low light here, static scenes, so there is hardly any detriment other than esthetics to having a lag. But having a noisy image prevents one from clearly seeing what he's shooting, and especially bad for manual focusing.
Did you use the same lens and apperture settings on both cameras? The Nex shows their picture with apperture closed to the set value. it is posible that the 5n has a less noisy sensor, or asyou say there is some noise reduction
photoac New Member • Posts: 17
Try changing Setup/Live View Display/Setting Effect/OFF. It defaults to ON.
The display will then show the preview before the lens is stopped down to the selected aperture, so more light reaches the sensor and there is less noise.
Photac
Two cameras side by side. exactly the same settings. The pictures taken (RAW, with ISO12800, F4, 1/50 sec) have about the same amount of noise, so I can only assume the sensors are about the same. The only thing I could think of is the 5R has some noise reduction before the signal is sent to the LCD.
DtEW Senior Member • Posts: 2,167
(Edited)
 DtEW's gear list:DtEW's gear list
Canon EOS 6D Sony a6000 Samyang 14mm F2.8 IF ED MC Aspherical Samyang 24mm f/1.4 ED AS UMC Sony E 50mm F1.8 OSS +17 more
saintz Contributing Member • Posts: 549
On my NEX 3, it didn't seem to be as much of an issue. I find the 5N definitely gets grainier in low light than the earlier bodies. This also seems to affect the focus peaking, and hence manual focus. I found on the 3, I could easily get focus peaking on eyes in portraits in dim light. On the 5N, this seemed much harder to do.
 saintz's gear list:saintz's gear list
Sony a6000 Sony E 18-55mm F3.5-5.6 OSS Sony E 50mm F1.8 OSS Sony E 16-50mm F3.5-5.6 PZ OSS
