Whats causing the grainy, dirty look to my photos after using lightroom? Ronkinon lens just arrived
Started Jun 4, 2013 | Discussions
Nano princess
Nano princess Regular Member • Posts: 288
Two things okay several things.
Why do my photos always have this grainy dirty .  Am I actually editing jpeg? in Lightroom I always see this with my photos
Two.. what constitutes good bokeh.  I got the 85mm 1.4 and ran outside and started snapping.  I know odd things.  But I just started snapping anyways.  I never ever got the circle things with my 35 1.8
What do you all think? Not critique my photo but the circle things I love!!! The dark grainy, dirty look what cause that in photos.  I never see it on great photographers.  But I have seen it a lot with newbie photographers as myself.  So what am I doing wrong.
zakkix Regular Member • Posts: 377
Re: Whats causing the grainy, dirty look to my photos after using lightroom?
If you have purchased a 85mm 1.4 and need to know the above then really read a photography book, online courses, sign up for photography classes.
Nano princess
Nano princess OP Regular Member • Posts: 288
Are you serious??? that's your helpful answer.  Okay I will surely wait for others to chime in.  I love the circle bokeh? But some hate it I have found.  Soooooooooo just want to know what you all thought of it?   are you saying that's a terrible thing to have? or good? the dirty grimy look I see maybe due to lowering the shadows or raising the something.
That was your helpful answer.  Why are you here???
Mark K W Senior Member • Posts: 1,507
What LR adjustments are you doing? I presume you are starting with a RAW....
In LR's Develop Module, the ones to check for affecting graininess are Sharpening (not too much), Noise (apply enough to smooth the image; you are shooting at high speeds at ISO100, so I presume your images are in real bright light and so there is not much noise coming from the sensor to start off with), Contrast (again apply just enough), and then Clarity (be very very careful with that and use very sparingly unless you want a heavily processed effect). There is also a Grain effect but I assume you are not applying this.
Also what Export settings do you have for the JPEGs? Are you Sharpenng there again?
Ron Poelman
Ron Poelman Veteran Member • Posts: 5,178
All the shots are hovering on the edge of under-exposed..
Possibly your monitor is tuned too bright ?
Why not re-run a couple at 1/3 to 1/2 a stop brighter and see what you think ?
The other question is what was the light like on the day ?
From here it looks like overcast grey.
 Ron Poelman's gear list:Ron Poelman's gear list
Sony Cyber-shot DSC-H2 Sony Cyber-shot DSC-R1 Sony SLT-A57 Sony Alpha 7R Sony DT 55-300mm F4.5-5.6 SAM +13 more
Hugo600si Contributing Member • Posts: 749
Are you using a camera profile? I'm frequently using the standard one from http://www.piraccini.net/2011/02/profili-colore-sony-a900-per-adobe-lr.html on my raw files when I'm lazy. If not lazy I play with the settings (top down in development view)
What alterations do you do on your raw files in lightroom developer?
My simple flow is (using a sample photo, values will differ per shot):
1. set lens profile if required
2. Crop to my liking
3. Adjust exposure to my liking
4. up contrast a little if needed (low values)
5. increase whites and or highlights (+26 in my playing sample) looking at the histogram to not loose data or burn out the photo
6. reduce blacks same thing (-17 in my sample, these values are normally a bit lower)
starting to get more color
7. increase vibrance (+5 to +12)
8. increase saturation (+5 to +10)
I like velvia (on portraits I am a lot softer as I used to love portra 160 from Kodak)
9. Sharpening, add a bit (+37 in my sample, do not over do this!)
10. luminance noise reduction, 24, watch your detail, do not over do this, could be far less
11. color noise in higher iso images, not in my test
That's about it for a quick touch up, there are probably good guides on how to do this... but I haven't gone through the trouble of reading them Lot is on personal taste, most important, do not overdo it!
Hope this helps a bit
Some of the experts here can say where I'm going horribly wrong
Edit, forgot to add, for my 24/1.8 on the nex I sometimes have to remove fringing too.
Shamelessly promoting my favourite painters website (my wife's ) and my handiwork:
http://EdithsArt.com and http://EditshArt.nl (Dutch)
 Hugo600si's gear list:Hugo600si's gear list
Sony Alpha DSLR-A700 Sony Alpha NEX-7 Sony SLT-A77 Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* Sony 70-400mm F4-5.6 G SSM +11 more
Nano princess
Re: All the shots are hovering on the edge of under-exposed..
Darn... thank you.. for the help.  Underexposed.  Ty for the help
it was sunny but I was under a pergola so shaded.  Darn I was so hoping you all were going to say great lens... LOL
Nano princess
thank you so much for the details in how you edit some of your photos through lightroom.  I so appreciated that info.
Blessings
Nano princess
Hello, I just upload them from my camera card to liveroom.  Then do my thing.  I am doing something really really wrong.  I will figure this out.  Thank you so much for the help.
No I just upload the photos and then sharpen but no more then the number 50.  What number do you all usually go to on contrast in light room? Clarity I love clarity .. LOL trying to calm down my hand on that little lever.  LOL
I don't know maybe Me uploading off the camera card and yes.. I shoot in raw.   That then their fore is raw I am converting right? I couldn't figure out what I was uploading when I had my camera set to raw and jpeg.  So now I just keep it set in raw.  Thank you
Ron Poelman
Under exposing has it's uses .....
you just have to choose which bit counts !
I am very sparing on all my adjustments (starting with an A900 or A700 RAW file). I adjust Highlights/Shadows/Whites/Blacks by holding down the ALT key which shows you clearly where the limit point is. Contrast I just tend to nudge up a bit to my taste, but often not over 15 or 20. Exposure is set with an eye on the histogram and how I want my image.
Clarity is both great for things which have natural structure (e.g. clouds, bricks, flaky paint, wood), but also can be very excessive for things which are naturally smooth, and should always be used very carefully in areas where the image is naturally dark because all it will do is accentuate the noise. I often only use clarity heavily in an area with either a graduated filter (e.g. for cloudy skies) or else with adjustment brush.
Sharpening and noise reduction are in some ways opposites, and you just have to adjust carefully each to your taste being mindful of the 1:1 image view panel set to an appropriate area in the image as you do it. There is an actual science as to how to do both as "accurately" as possible, but it's not something to explain simply as it depends on the image content.
You can see from the filename in LR what is file you are making the adjustments on. Sony RAW is .ARW file.
Nano princess
Re: Under exposing has it's uses .....
Now isn't that seriously underexposed? sorry.. looks cool though.  ayyayaa will I ever get this down.  Yes I will one day.  Smiles..
Thank you so much
Nano princess
Thank you again for the detailed support.  Here I thought the grainy dirty look.  Which shows up massively more so when I convert photos to black and white.  thank you for the alt key info.  I remember seeing a video about that sometime back.  But have not been doing it that way for awhile.  Looks like its time I go back that.  Blessings
Ron Poelman
Best thing to do with PP.....
is shove all those sliders all the way and all the way down and see what happens.
Remember, it's supposed to be fun.
You have no obligation to the rest of the planet to be an instant expert.
Nano princess
Re: Best thing to do with PP.....
Thank you Ron
LOL... alright went back in and did my own way of my over pp editing.  But I love my over pp editing.  This is me!!! LOL.. I was trying to tame my editing earlier.  But it was blah to me. Thank you Ron.  I just don't want to overprocess because I cant get the fundamentals down as of yet.
dlkeller Veteran Member • Posts: 6,922
To me that looks very overexposed which leads to a washed out look.  The trial that you felt was very under exposed may be a little bit, but not much.  In any case the things he did gave a very sharp, clear image--which is what I would want for the crystal pendant.
Dave
Nano princess
Dave
Ahhhh okay I see.  Thank you.
Ed at Ridersite Forum Pro • Posts: 17,252
If you are using LR4, it appears to me that you need to move the Luminance NR slider to the right a bit - maybe to 10.  Slide it just a bit and pay attention to the background.  If it doesn't clear up, slide it a bit more and wait a second.  Continue this until it meets your expectations.
The EXIF says aperture = F1 - not sure why.  So, I assume you were shooting wide open at f1.4.  I see some CA/PF.  Not a lot, but enough that a few spots could use some correcting.  Either use the adjustment brush (moving the defringe slider to 100) and brush a few strokes over the purple fringe, or use the Remove Chromatic Aberration box to get rid of the purple fringe.
AEH
http://aehass.zenfolio.com/
http://aehass.zenfolio.com/blog
Question: What do you do all week?
Answer: Mon to Fri. Nothing, Sat & Sun I rest!
 Ed at Ridersite's gear list:Ed at Ridersite's gear list
Sony RX100 II Sony SLT-A77 Sony DT 16-50mm F2.8 SSM Sony 70-400mm F4-5.6 G SSM II
stan_pustylnik Veteran Member • Posts: 3,864
bokeh is good, use exposure compensation
I my oppinion "dirty, noisy look" in these samples come from slight underexposure. try +0.5  ot +0.7 Exposure compensation.
Bokeh of this lens is good, lens with bad bokeh would create donuts instead of circles.
Person is taking photos, not camera. When photograph is bad, it's because photographer doesn't know how to choose settings optimal to "own preferences". Then blames camera for bad IQ.
This is same as blaming car about arriving to wrong destination.
http://stan-pustylnik.smugmug.com
 stan_pustylnik's gear list:stan_pustylnik's gear list
Panasonic Lumix DMC-TS2 Sony Alpha DSLR-A850 Sony SLT-A55 Sony DT 18-55mm F3.5-5.6 SAM Sony 50mm F1.4 +11 more
Draek
Draek Senior Member • Posts: 2,028
Re: Whats causing the grainy, dirty look to my photos after using lightroom? Ronkinon...
To respond to the easiest question first... what constitutes "good" bokeh is entirely up to the individual. Do you like it? then it's good. You don't? then it's bad. Myself, I hate the bokeh from the Helios 44-2 58/2.0 russian lens I own, but many owners of the same lens like it. Are they wrong? nope. Am I wrong? nope. It's subjective, like saying your liking of strawberry ice cream is "wrong" somehow.
As for the "grainy" look, well that one's tougher, as I don't see anything of the sort. One possible reason is noise, which is to be expected since all cameras produce it at all ISOs to one degree or another, so if you look hard enough you'll always find it, specially in RAW images which haven't had noise reduction applied to them. Another possible reason is, well, that your lens ain't the sharpest one in the bunch and lacking in micro-contrast as well, which is to be expected from a fast lens shot wide open---try shooting with it stopped down to f/4 or so, and see if the image becomes sufficiently clearer. And a third alternative is that you've simply cranked Lightroom's sharpening algorithms far too high, and what you're seeing is sharpening artifacts around; I don't think that's the case myself, but do try lowering it to 10-25, or even down to zero altogether and see if things improve then.
 Draek's gear list:Draek's gear list
Fujifilm FinePix F70EXR Samsung TL500 Canon PowerShot A1200 Sony Alpha DSLR-A390
