How important is the D?
Started Jun 3, 2013 | Discussions
JVPhotography Regular Member • Posts: 261
I'm considering buying a non D lens but will shoot matrix metering and flash with it almost 100% of the time.
Is this a bad idea?
kithg
kithg Veteran Member • Posts: 6,206
Re: How important is the D?
My older 50 f 1.8 is a non-D lens. It doesn't give your camera distance information, or your flash either. But it will AF just fine.
 kithg's gear list:kithg's gear list
Panasonic Lumix DMC-ZS7 Nikon D7000 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF +3 more
brightcolours Forum Pro • Posts: 12,812
Makes no sense at all.
Is this a bad idea?
Why do you want a non-D lens for matrix metering of all things and flash?? Are you just trying to get reactions or something?
JVPhotography OP Regular Member • Posts: 261
Makes perfect sense
Makes perfect sense. There were some wonderful optics long before D was introduced.
I don't believe any of the 3rd party lenses have the distance information, but maybe I am wrong?
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 12,552
I shot my 85F1.8 AF (non-D) and (a lot less often) my 50F1.8 AF (non-D) for over 15 years.   The 85 got used a pretty fair amount with flash.
I can't say I've ever seen a shot that came out 'wrong' because of lack of D info.
The D-related info (distance) is, in my opinion, only used in a rare circumstance with flash to help determine the flash power to be used on a subject, probably when there is some very reflective element or perhaps back lighting involved.
Matrix metering works fine with AF lenses.   So does flash, 99.9% of the time.
Craig
www.cjcphoto.net
Nikon 1 V1 Nikon D200 Nikon D300 Nikon D700 Nikon D800E +35 more
RBFresno
RBFresno Forum Pro • Posts: 11,024
I worried a bit a about non-D" withthe Zeiss 100/2.
Is this a bad idea?
HI!
I had this same concern before I got the Carl Zeiss 100/2 ZF Makro, but finally got it, figuring I'd try some way to deal with the non-D issue and flash.
In practice, it's never been a problem for me. This was heavily back lit:
Nikon D3 ,Carl Zeiss Makro-Planar T* 2/100 ZF ,SB-900
1/2000s f/2.8 at 100.0mm iso200
Best Regards,
RB
 RBFresno's gear list:RBFresno's gear list
Nikon D2H Nikon D4 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF +12 more
Re: Makes perfect sense
So tell me, which wonderful optics were there, that did not re-appear as D version?
You are wrong.
And it still makes no sense at all, saying you are going to get a non-D and then only shoot it with matrix metering and flash.
Catalana Senior Member • Posts: 1,258
Re: I worried a bit a about non-D" withthe Zeiss 100/2.
The "C" lenses seem to do just fine...
 Catalana's gear list:Catalana's gear list
Pentax K-5 Nikon D600 Nikon AF-S Nikkor 18-35mm f/3.5-4.5G ED Nikon AF-Nikkor 80-200mm f/2.8D ED Pentax smc DA 15mm F4 ED AL Limited +10 more
bakhtyar kurdi Contributing Member • Posts: 596
there is no difference
The only difference is the letter (D)
If you remove the letter from a (D) lens, and add that letter to a non D lens, no one can find out which one is which, even Nikon experts.
i-TTL uses pre flashes to calculate the exposure, no D needed.
Use a D lens and a none D lens in any situation, and tell me if you find any difference in exposure.
jdrpc Contributing Member • Posts: 502
Re: there is no difference (NOW) then, there was, but small...
The D lens were for the time of the 'old' TTL flash.... and still, for most occasions, there was no difference whatsoever...
It was more like a marketing gimmick, real World difference was null or minimal...
 jdrpc's gear list:jdrpc's gear list
Nikon D700 Nikon D300 Fujifilm FinePix S2 Pro +1 more
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 10,596
D can fine tune matrix exposure in some situations by up to about 0.75 stops - e.g. long focus distance low contrast scenes usually works better with slight under exposure.
Assuming you are digital often there is time to check the histogram and make any adjustment you think might produce a better result.
Nikon Coolpix P7700 Nikon D800 Nikon D7100 Nikon D810 Nikon D750 +24 more
Art Jacks Senior Member • Posts: 2,191
A quick hijack, I still have a couple of pre D lens  bought at the time of the F4, when AF ing the lens the manual focus ring rotates, was there a later version of the pre D lens where this did not happen or was the next upgrade straight to the D versions ? They both work perfectly but the rotating manual focus ring means being careful when holding the lens.
Rotating manual focus has nothing to do with D
I have D and non D version of the same lens both rotating
schipp
schipp Forum Member • Posts: 83
I have a 24 mm and a 85 mm non-D versions, no problem with metering and/or flash.
And a lot cheaper !
 schipp's gear list:schipp's gear list
Nikon D610 Nikon 1 V1 Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR Nikon AF-S Nikkor 50mm f/1.8G Nikon 1 Nikkor 18.5mm f/1.8 +3 more
Zlik Contributing Member • Posts: 990
Is this a bad idea?
I have compared the 80-200/2.8 AF non-D vs the D version, with and without flash, with various subjects. I literally saw 0 difference in focus accuracy  (other than the D being a little faster thanks to a slight mechanical update), metering, and flash exposure. Don't worry about going with non-D lenses.
mbernard Senior Member • Posts: 1,080
I have five pre-D Nikkors. Although I use them rarely at present, I have not been able to see any difference with the D-Nikkors concerning the exposure or AF.
Michael Benveniste
Michael Benveniste Senior Member • Posts: 2,435
Quite true; they are independent "features."  But in at least two cases, Nikon made significant design changes between the "D" and "non-D" versions of a lens.  The two I can think of are the 28mm f/2.8D (improved), and the 35-105mm f/3.5~4.5D (not so much).
In the latter case, I wouldn't be surprised if the behavior at issue also changed.
 Michael Benveniste's gear list:Michael Benveniste's gear list
Nikon Coolpix 995 Nikon D200 Nikon D800 Nikon 1 V1 Sigma 12-24mm F4.5-5.6 EX DG Aspherical HSM +33 more
mikeyyy New Member • Posts: 14
I have a nikon 35-70mm f2.8 non d lens and when I shoot with flash it seems to make a differance I use a sb-600 flash on a d7000 and I get better resaults when the flash is in the FP mode only (I turn off BL) the exposure is more consistent.
turbsy
turbsy Contributing Member • Posts: 813
You are wrong.
Maybe because it is cheaper? Just because it makes no sense to you doesn't mean your right.
 turbsy's gear list:turbsy's gear list
Olympus XZ-1 Nikon D800 Nikon D300 Nikon D50 Sigma 24-70mm F2.8 EX DG Macro +11 more
Peter Damroth Contributing Member • Posts: 611
ALSO, I think the AF nonD lens may not allow manual focus fine tuning when using the lens in AF mode....
Peter Damroth Photography
 Peter Damroth's gear list:Peter Damroth's gear list
Kodak DCS Pro SLR/n Nikon D300 Nikon D600 Nikon AF Micro-Nikkor 60mm f/2.8D Nikon AF Nikkor 24mm f/2.8D +14 more
