Still missing focus with my x100s
Started Jun 3, 2013 | Discussions
zenpmd Senior Member • Posts: 1,129
Can anyone help?
Sometimes when I am taking a shot it finds the background rather than the subject. This seems to happen even in obvious situations where there is good contrast between subject and background.
Does changing the size of the focus point help?
Fujifilm X100S
il_alexk Senior Member • Posts: 2,283
Re: Still missing focus with my x100s
Yes, setting the size of the focus point to the minimum is the first thing you want to do.
Using EVF/LCD also helps when focusing on very close objects.
 il_alexk's gear list:il_alexk's gear list
Ricoh GR Pentax K-5 IIs Pentax smc FA 50mm F1.4 Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO +4 more
zenpmd OP Senior Member • Posts: 1,129
I thought someone somewhere else said that a small focus point will slow focus overall? Is that true? Are you recommending just always having the small focus point all the time?
Has anyone compiled a list of the most sensible fuji settings?
Thanks!
Toccata47 Senior Member • Posts: 2,788
Thanks!
Yes, smallest focus patch all the time.
Keit ll Senior Member • Posts: 3,706
The speed of AF should be a secondary consideration when miss-focus occurs !
Keith C
smatty Senior Member • Posts: 1,949
Read this...
Take the time to read these focus tipps concerning the Fuji X-Cameras. It should help you to improve the AF accuracy
http://fujixfiles.blogspot.com/2012/08/fuji-x-pro-1-af-autofocus-speed-and.html
Smatty
=> Homepage
=> Recent Flickr Photos
 smatty's gear list:smatty's gear list
Fujifilm FinePix X100 Fujifilm X10 Fujifilm X100S Fujifilm X100T Canon EOS 5D +18 more
Asylum Photo
Asylum Photo Senior Member • Posts: 1,277
This completely depends on the subject you are focusing on.
 Asylum Photo's gear list:Asylum Photo's gear list
Fujifilm X-E2 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R +2 more
Jeff Charles Veteran Member • Posts: 7,514
Re: Read this...
That's a good summary. His suggestion to fully press the shutter button without waiting for focus confirmation isn't intuitive, but it works with the X100 too. One addition: AF-C is better in very low light.
Jeff
"Please proceed..."
 Jeff Charles's gear list:Jeff Charles's gear list
Sony Cyber-shot DSC-RX100 III Fujifilm X100T Olympus E-M1 Fujifilm X-E2 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +5 more
Can you be more specific?
Iv'e checked your album and it looks like you do know how to handle the camera :).
I wonder if you can give an example of the subject where large AF point would be more accurate than the small one.
Re: Can you be more specific?
I don't think a larger focus frame will ever by more accurate, but it can help focus acquisition, because there's more likely to be something of high enough contrast in the larger frame. The tradeoff is that a bigger frame may focus on a background object when the frame extends beyond the intended subject.  I usually keep mine set to one bigger than the smallest, and I reduce it when I need more precision.
Jeff
"Please proceed..."
Re: Read this...
Yes, with the X100s the AF-C does work better than on the old X100. But since you can't move the central focus point in AF-C I find this mode difficult to compose the image with...
Smatty
=> Homepage
Thanks, makes sense :).
In this case I still find it easier (for me, of course) to keep the AF area as small as possible to get the best accuracy. Instead of enlarging the focusing area, I just lock focus with half-press on whatever contrast area is available, and then re-frame before the shot. Needless to say, I'm using central AF point in 99.9% of all cases.
So the AF point should be in the middle and set to "area" in the menu rather than "multi" right?
Yes, see page 48 with your user manual.
/Alex
got you, mine was alreday set to that.
The issue occures when I am photographing something which is not filling the frame in its entirety, so I will try the smaller area and see how that works
trseattle Forum Member • Posts: 87
I had the same problem repeatedly with my X100s and sold it.  I purchased a used X Pro1 and I am now getting about a 95% focus accuracy rate with the latest firmware installed.  Only occasionally mis-focuses.
 trseattle's gear list:trseattle's gear list
Samsung EX2F Nikon Coolpix A Canon EOS 6D +5 more
Tr - I agree, my x-e1 seemed to be better. How can this possibly be?
nand
nand Senior Member • Posts: 2,394
Try this.
It is important to have contrast (detail) in the subject that you want to have in focus. Not the edge between the subject and the background. If possible, keep the background out of the focus box.
When both fore and background within the focus box have contrast (detail), the camera will generally pick the foreground to focus on.
When in the focus box, the foreground is flat without contrast and the background has contrast (detail), the camera will focus on the background.
Even in poor light and low contrast, using the above suggestions, I can focus lock consistently. (1/2 sec @ f:4 @ ISO 6400)
Nand.
zenpmd wrote:
Can anyone help?
 nand's gear list:nand's gear list
Fujifilm X100T Olympus OM-D E-M5 Olympus E-M1 Fujifilm X-T1 Olympus 12-40mm F2.8 +26 more
