Polarizing filter for which lens?
Started Jun 1, 2013 | Questions
QuakeO Regular Member • Posts: 138
I'd like to add a circular polarizing filter to my bag. In your opinion, which lens would benefit the most?
  1. Panasonic 14mm
  2. Sigma 30mm
  3. Oly 14-42mm II
  4. Oly 40-150mm
Thanks for your advice!
 QuakeO's gear list:QuakeO's gear list
Panasonic Lumix DMC-GF3 Olympus PEN E-PL5 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +1 more
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,049
Easy: whichever lens you use the most.
A polariser can be used on every type of lens, but it is often not recommended for ultra wide lenses because the polarisation effect becomes too different between the left and right part of the frame (when you use it in sunny outdoor conditions).
A polariser is not only used to make the sky a more distinct blue but also to eliminate reflections on metal, windows and water surfaces. It can be used at any focal length. If you are buying just one you should get one for the lens you use the most. Alternatively you can buy one that fits the largest lens and use step up rings to mount the polariser on other lenses.
Slowly learning to use the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +5 more
BBbuilder467 Senior Member • Posts: 1,460
Re: Polarizing filter for which lens?
With my Panasonic system, I can use the same 52mm CPL with everything I have. I planned it that way.
I'd say for all intents and purposes, "I" use it more often with the 14-45. It matches the focal length range well and I don't like using it with the longer zoom, more because of the awkwardness trying to adjust with the physically longer lens.
I use it a lot more on wet, cloudy days than bright sunny days, for wet foliage and nature subjects. I use a grad ND more than the CPL to create blue skies on cloudy days here in the mountains.
Initially at least, I'd say you'll have more use with the CPL and 14-42.
I started buying the Sunpak filters for testing to see if I really need/want a particular effect. They have nice, smooth mounting rings and work well if you want a low cost starting place. The "novelty" of using filters can wear off real fast.
QuakeO OP Regular Member • Posts: 138
Re: Easy: whichever lens you use the most.
My most often used lenses are the 40-150mm and the Sigma 30mm. (I also have the 14mm which has the same thread as the Sigma, and the 14-42mm, which is used less often.)
I have two choices to make:
1. Get a 58mm filter and a 46mm->58mm step-up, or two filters?
2. Which brand? The B + W and the Sigma filters are priced similarly, a notch above the Hoya and twice the price of Tiffen.
Opinions most welcome!
Bizzarrini Regular Member • Posts: 497
 Bizzarrini's gear list:Bizzarrini's gear list
Panasonic Lumix DMC-ZS7 Fujifilm FinePix X100 Olympus Tough TG-2 Panasonic Lumix DMC-GF1 Olympus OM-D E-M5 +25 more
agentul
agentul Contributing Member • Posts: 618
i have a Kenko Zeta, and i must say that it was quite expensive. i don't know about your budget, but it might not be worth buying two filters. I would start with a 58mm diameter filter, because it will be easier to buy an adapter for 46mm. you could go the other way, but i don't know if it wouldn't cut the edges of the frame.
for the 46mm lens you will most likely not be able to use a hood with the 58mm filter on. if you buy a model that has a thread on the outside maybe you can get a threaded round hood. that will also make it easier to adjust the filter. i have to adjust the filter and then mount the hood, as i am using the 14-42mm kit part.
 agentul's gear list:agentul's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix DMC-LZ2 +1 more
Thanks, but I've never found that comparison particularly helpful. At any rate, test results for a bunch of 72mm polarizers don't answer my questions...
shihhan Regular Member • Posts: 307
  1. Panasonic 14mm
  2. Sigma 30mm
  3. Oly 14-42mm II
  4. Oly 40-150mm
P 14 f2.5 - 46mm
S 30 f2.8 - 46mm
O 14-42 II - 37mm
O 40-150 - 58mm
Just get 58mm and step up rings from 46 -> 58 and 37 -> 58. However, you'd have to take the hoods off...
Ok, too bad. I figured it might help with part two of your question, which brand to get. I doubt the size will influence the test results much. Personally I bought a Marumi DHG filter. So far very pleased with it.
Hoya's are pretty good (or Kenko, the Japanese version of Hoya is cheaper).
The Hoya Green/Blue series CPLs are uncoated, Pro1 D are multicoated, and HD are hard multicoated.
Coating matters less for CPLs as you tend not to shoot the directly at light sources, so it's really up to price. Personally I use Kenko Pro1Ds.
