I held the A at a store
Started May 30, 2013 | Discussions
rhlpetrus Forum Pro • Posts: 24,486
I think it feels much cheaper than the 1 series, but I liked the LCD. The AF is very sluggish (also compared to the V1 I had with me in the same lighting conditions).
Let's hope Nikon make it better on the next iteration, especially AF and built. I wouldn't mind it being a bit larger, thicker, sturdier, with a faster lens.
Renato.
http://www.flickr.com/photos/rhlpedrosa/
OnExposure member
http://www.onexposure.net/
Good shooting and good luck
(after Ed Murrow)
 rhlpetrus's gear list:rhlpetrus's gear list
Leica D-Lux (Typ 109) Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 35mm f/2D +4 more
Nikon 1 V1
Thomas Streng Senior Member • Posts: 2,683
Re: I held the A at a store
Renato.
OnExposure member
(after Ed Murrow)
Did you also compare IQ with the 1 series?
photo perzon
photo perzon Veteran Member • Posts: 4,243
Renato.
OnExposure member
(after Ed Murrow)
Yes the 1 series is super fast.  Faster than any other compact out there.  But it is much less cheap than the 1 series.  I mean the lenses for the 1 are rubberly and loose.
The A is tight.
At any rate, the sensor is much laerger on the A and that is the point.
 photo perzon's gear list:photo perzon's gear list
Sony Cyber-shot DSC-RX100 III Olympus PEN E-PL5 Fujifilm X-A1 Panasonic Lumix DMC-GM1
rhlpetrus OP Forum Pro • Posts: 24,486
Renato.
OnExposure member
(after Ed Murrow)
I didn't need to, I have the D7000, which would be similar in IQ. I know the difference, and I would be a owner if only the AF were faster. For many situations the V1 is enough, especially trips, otherwise I can use the D7000. I can see someone liking it, but it's still a sluggish compact.
Renato.
OnExposure member
(after Ed Murrow)
Renato.
OnExposure member
(after Ed Murrow)
The A is tight.
I think you haven't used the primes on the V1. They are very well built. The zooms are ok, some say the 30-100 is excellent optically, I don't have it. I use mostly the 10 f/2.8, which makes the V1 like a compact. Of course the IQ is not at the level of the A, but that's why I'm frustrated. If it were faster, especially AF (I like shooting people, street, candids, I need the speed), I would get one to replace the V1, in a second.
Renato.
OnExposure member
(after Ed Murrow)
Feudal1
Feudal1 Regular Member • Posts: 367
I own the A, and have played with the 1 series cameras - I think the A has a pretty solid build.  Any benefit the 1 series might have in this area is small - drop either camera from a distance, and it's going to sustain damage.  The only negative aspect worth talking about when comparing the A to the 1 series is AF speed - the AF speed of the 1 series is much better.  However, the IQ of the A is really outstanding, much better than the 1 series, especially given the size of the A.  It really boils down to what your needs and expectations are.  I love my Coolpix A, even with its slow AF.
 Feudal1's gear list:Feudal1's gear list
Ricoh GR Fujifilm X100T Sony Cyber-shot DSC-RX100 IV Fujifilm X-T1 Nikon D750 +3 more
AngryCorgi
AngryCorgi Contributing Member • Posts: 916
Renato.
OnExposure member
(after Ed Murrow)
You mean cheaper than the V1?  Cuz I don't see how ANYTHING could feel cheaper than the J1/2/3.
-AC-
