"Plot Twist" | Long Exposure Landscape | a77+10-20mm+ND filters
Started May 29, 2013 | Discussions
José Ramos Senior Member • Posts: 1,765
11
"Plot Twist" | Carrasqueira, Portugal
José Ramos ©
Sony a77 + Sigma 10-20mm
Exposure: 30 seconds
Aperture: f11
ISO: 100
Hitech 3 stop soft ND grad
Hitech 10 stop ND
Tripod
Remote Shutter
Sony SLT-A77
tjwaggoner
tjwaggoner Senior Member • Posts: 1,112
Re: "Plot Twist" | Long Exposure Landscape | a77+10-20mm+ND filters
Stunning as always
 tjwaggoner's gear list:tjwaggoner's gear list
Olympus E-10 Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-FZ1000 Canon EOS Rebel SL1 Canon EF-S 18-135mm f/3.5-5.6 IS STM +2 more
moimoi
moimoi Veteran Member • Posts: 3,696
Excellent capture.  The wide angle is well used here.
All harsh, impolite and/or unreasonable replies will be simply ignored.
Measurebators are out of my world, photography is not about babbling behind a computer... but rather being out of your home, shoot and share photographs with other people. Shoot and Share...Thanks.
 moimoi's gear list:moimoi's gear list
Canon EOS 6D Canon EF 70-200mm f/2.8L IS II USM Canon EF 16-35mm f/4L IS USM Canon EF 35mm F1.4L II USM
esmall Contributing Member • Posts: 626
Great capture.  I'm interested in the Hitech filters.  Any advice?  Are you using the 85mm or 100mm size?  I've read with the ultra wide angle lenses that 100mm is needed to avoid the vignetting   Also what holder do you use or recommend?
Ernest
a77/a300/CZ 24-70 f2.8/Tamron 10-24mm/Tamron 70-200 f2.8/Sony 35mm f1.8/Tamron 17-50 f2.8/Minolta 24-105/Minolta 100-200/Minolta 50 f1.7/Tamron 90 SP Macro
http://www.ernestsmallphotography.com
See my PhotoStream
http://www.flickr.com/photos/ernestsmall/
 esmall's gear list:esmall's gear list
Sony SLT-A77 Fujifilm X-E1 Fujifilm X-T10 Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Fujifilm XF 35mm F1.4 R +10 more
TheVoid Senior Member • Posts: 1,566
Beautifully composed and captured. Thanks for sharing the technical details too.
Jeremy
 TheVoid's gear list:TheVoid's gear list
Panasonic Lumix DMC-FZ30 Sony Alpha DSLR-A580 Sony 70-300mm F4.5-5.6 G SSM Tokina AT-X Pro 11-16mm f/2.8 DX Sony DT 16-50mm F2.8 SSM +2 more
Maxxuman Senior Member • Posts: 1,674
Excellent!
Great composition, colours, dramatic sky, very well seen and executed.
Barry
José Ramos OP Senior Member • Posts: 1,765
Hi Ernest.
You do definitely need to use the 100mm filters with ultra wide angle lenses. Even with the 100mm filters you will need the wide angle adaptor ring, if you use an Hitech holder, or to invert the holder, if you use the cokin z-pro holder.
I'm using the Cokin Z-Pro holder, but I'll receive a Hitech holder soon (got a sponsorship from them) to try it.
Steve Cohan Senior Member • Posts: 1,638
Beautiful work, Jose!! nt
No text.
 Steve Cohan's gear list:Steve Cohan's gear list
Sony RX100 Sony Alpha DSLR-A700 Sony Alpha DSLR-A850 Sony a77 II Tamron AF 18-270mm F/3.5-6.3 Di II VC LD Aspherical (IF) MACRO +19 more
cosmonaut
cosmonaut Senior Member • Posts: 2,189
Do you have many flare issues with the Hightech filters? Do you have to clone many?
www.gregmccary.com
As long as I clean the filters, there isn't much issue with flare. 95% of the flare is created by the Sigma.
FlyNavy Regular Member • Posts: 395
Excellent work!
Aranea Forum Member • Posts: 86
Wow!
It looks great!
And now a newbie question: what's the advantage of using NDs and then increasing the exposure time over a shorter exposure without the filters? Thanks.
Re: Wow!
Aranea wrote:
It looks great!
The ND filters and the longer exposure achieved blurred the water.  The ND Grad was likely used to enable the foreground (water, pier) to be brightened, so they wouldn't appear dark relative to the bright sky.
Barry
Re: Wow!
Maxxuman wrote:
Aranea wrote:
It looks great!
Barry
Thank you very much. Explained like this it makes a lot of sense and I can see it in the photo.
brian14478
brian14478 Senior Member • Posts: 3,703
I knew it was going to be nice.....and it is
A gorgeous shot.
The color charachteristics of the a77 and the extra resolution and mps is perfect for your photography....
You really use the a55 to its potential.  Now you can really "get down to buisiness."  Thank you for sharing your equipment/technique and i hope you are making revenue from your photography.  The time, effort and artistry involved isnt something that comes cheaply or easily.   What you capture is a life lived so to speak right down to the title.
I hope to be able to capture nature/landscapes as beautifully as you have always done, it may not happen for quite a while though because i am a big animal lover right down to little bee....Thanks for sharing,brian
A gorgeous shot.
Brian, you have no idea about how much those passionate comments inspire to keep shooting more and more.
Yes, the a77 is a match made in heaven. I can only imagine it being topped by the a99, but then I'd have to spend a fortune in lenses.
As to the revenue, it keeps steadily coming, in an unpredictable way. Fortunately, it is not my main earning source.
Keep loving the animals, they deserve it!
robert614 Senior Member • Posts: 1,322
Excellent work as usual Jose!
regards,
Robert
nivla16
nivla16 New Member • Posts: 1
great shot! I would love to do long exposures as well
Just ordered an a57 along with a variable nd filter (a really cheap one - i know it's not as good as the other branded ones, but i wanna try it out and experiment first)  and will be here by next week..
one question though.. with long exposures, can you see the final result thru the evf (wysiwyg feature)? thanks!
busch
busch Forum Pro • Posts: 31,547
Exceptionally good composition with great colors! Bravo!!
Busch
Take the scenic route! Life is too short to do otherwise.
My Photos
 busch's gear list:busch's gear list
Sony Cyber-shot DSC-R1 Panasonic Lumix DMC-ZS7 Sony a77 II Sony 70-200mm F2.8 G Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +11 more
Nathanio Regular Member • Posts: 234
Stunning, absolutely perfect
 Nathanio's gear list:Nathanio's gear list
Sony a77 II Sony DT 50mm F1.8 SAM Tamron SP 70-300mm F/4-5.6 Di USD Sony DT 16-50mm F2.8 SSM Sony DT 18-135mm F3.5-5.6 SAM +1 more
