Why does nikon....
Started May 28, 2013 | Discussions
davidib17
davidib17 Regular Member • Posts: 390
Why does nikon....
Manufacture DX lenses and give them a FX focal length, instead of the equivalent?
 davidib17's gear list:davidib17's gear list
Nikon D7100 Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Rokinon 14mm f/2.8 IF ED MC Sigma 150-500mm F5-6.3 DG OS HSM +2 more
harpo95993
harpo95993 Forum Member • Posts: 72
Re: Why does nikon....
17-55 = 25-82
16-85 = 24-122
35mm = 52mm
55-200 = 82-300
and the list goes on.  Most are pretty close to their FX counter part.
 harpo95993's gear list:harpo95993's gear list
Sony RX100 Nikon D7000 Konica Minolta Maxxum 7D Nikon D7100 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +18 more
davidib17
davidib17 OP Regular Member • Posts: 390
I do realize that, but it just seems impractical to label something with a length it can never actually be used for.
nfpotter
nfpotter Veteran Member • Posts: 4,080
Not really.  Focal length is focal length, and many can be used on both (or more) formats.  Angle of view is what changes, thus the labeling.
davidib17
Right. But it the 35mm DX prime can never actually be a 35mm lens. It makes no sense to even bother labeling it with something that has nothing to do with it in actuallity.
sshoihet
sshoihet Senior Member • Posts: 2,538
7
The 35mm DX lens is ALWAYS 35mm, the same as a 35mm FX lens because the length of the lens doesn't change; only the portion of the images that the sensor sees changes.  People would be even more confused when comparing a 50mm FX lens to a 50mm DX lens because the labelled length would be different depending on what sensor it was made for.
With your proposed scheme, how many people would realize that a 50mm FX, 35mm DX and 18mm CX lens were all the same real focal length and that the 18mm CX lens actually gave you the same FOV of a 50mm FX lens when used on the same camera?
This is not new, we didn't change how we labelled 35mm lenses vs medium and large format lenses.  We can't just arbitrarily choose a sensor size and decide to label all the lenses based on that.
 sshoihet's gear list:sshoihet's gear list
Canon PowerShot S95 Nikon D7000 Nikon D7100 Canon EOS M Nikon D600 +14 more
Mako2011
Mako2011 MOD Forum Pro • Posts: 19,812
no such thing
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
sshoihet
Re: no such thing
Mako2011 wrote:
Because as sshoihet points out...the DX focal length of the 35mm f1.8DX lens is 35mm and not 50mm. There is no such thing as a DX equivalent focal length...there is a such thing though as a equivalent FOV.
What about when you shoot a DX lens on an FX camera, what happens then when you switch it to DX mode?  As you noted, only the AOV changes
Add to that too the fact that many DX lenses will work quite well on an FX sensor and cover the entire frame with little to no vignetting depending on the focal length and or aperture. eg the Sigma 8-16mm works quite well in FX mode at 15/16mm and is still quite good at 14mm.
http://www.dpreview.com/forums/thread/3206935?page=1
Terry Vickers
Terry Vickers Regular Member • Posts: 332
Re: no such thing
Focal length in photography is the distance of the rear nodal point of the lens to the image plane.
The formula for FOV = 2 arctan (x / (2 f) where x is the diagonal size of the sensor.
Obviously by changing the x above it will change the FOV regardless of the focal length.
FOV or AOV would probably be a more accurate way of naming lenses in terms of their "zoominess" but it's one of those conventions that has stuck. So we have to use the crop factors to get traditional 35mm FOV equivalents. While a bit of a confusing I think it would be more confusing to call something that it isn't ie. calling a 35mm focal length 50mm when it is in fact 35mm.
The use of equivalents is mainly there to have a commonly understood reference. More convention than anything else.
 Terry Vickers's gear list:Terry Vickers's gear list
Nikon D7000 Nikon D3100 Nikon D5200 Nikon AF Nikkor 50mm f/1.8D Sigma 10-20mm F4-5.6 EX DC HSM +7 more
stevehughes
stevehughes Regular Member • Posts: 426
Re: no such thing
My Dad, an experienced film photographer for decades, still wrestles with this on his D40.  When I tell I just got an 85mm lens he replies with "is that actually 85, or is it 125?"
The fact is that it is an 85mm lens regardless of whether it is mounted on a DX camera or an FX camera.  The focal length is a physical property of the lens.
What I have suggested to Dad is that he just needs to re-learn his concept of what 'normal' etc means when applied to lenses on DX
On film / FX, 50 is normal, 35 semi-wide, 28 wide and 21 ultra-wide
On DX, 35 is normal, 24 semi-wide, 18 wide and 14 ultra-wide.
Best regards,
Steve
 stevehughes's gear list:stevehughes's gear list
Nikon D7100 Nikon AF-S Nikkor 85mm f/1.8G Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Tamron SP 70-200mm F/2.8 Di VC USD +3 more
Sunshine_boy
Sunshine_boy Veteran Member • Posts: 4,823
Currency equivalent!...
That's because the FX value is a universal constant regardless of the camera it is mounted on, as the other posters pointed out. All you need to know is the 'crop factor' of your camera/sensor and multiply it by the indicated FL. Crop factors vary. Nikon's DX factor is 1.5, Canon's is 1.6 etc. So, a 200mm lens would be 200mm on any FF cam, 300mm on a Nikon DX and 320mm on a Canon DX.
Look at it in the same way as specifying a 'value' of a house expressing it in US dollars without having to bother expressing it in half a dozen other major currencies...
Best Regards
Sunshine
Visit my website for lots of pics and fun...
www.sunshine-web.com
ps If you see someone without a smile on, give him one of yours...
 Sunshine_boy's gear list:Sunshine_boy's gear list
Fujifilm FinePix F31fd Nikon Coolpix P7100 Olympus C-4000 Zoom Nikon D60 Nikon D5200 +2 more
sshoihet
Re: no such thing
Then he should have been familiar with some of the popular medium formats like 645, 6x6 and 6x7 where the "normal" lenses were approximately 75mm, 80mm and 90mm respectively.  On 8x10, ~300mm is normal.
We have 2 main sensor sizes now, things were WAY more confusing back in the days of film
coudet
coudet Veteran Member • Posts: 3,867
It would be even more impractical and wrong to label a lens something that's not. Would you label CX lenses that way too? How about medium format or large format? Should we rename those 360mm lenses for large format too and give them FF equivalent local length?
If it's a 35mm lens, you label it as 35mm and that's the end of it. And besides, what do you mean it can't be used on FF? Shave that 10.5mm and stick on a D800.
lorenzo de medici
lorenzo de medici Regular Member • Posts: 205
You can use the lens on a FX body with the DX crop enabled on the sensor.  Like everybody else said, the lens focal length is what it is.
 lorenzo de medici's gear list:lorenzo de medici's gear list
Nikon D810 Nikon D600 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/4G ED VR Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +3 more
IanYorke
IanYorke Contributing Member • Posts: 570
Agreed, focal length is focal length.
blue_cheese
blue_cheese Senior Member • Posts: 1,722
Re: Currency equivalent!...
Really now? Im curious how a 35mm format lens would fit on a medium format camera, I don't see any medum format shooters grandstanding that their sensor should be the be baseline reference for focal length to FOV relationship.
No as others pointed out, the focal length is an attribute of the lens and does not change based on the camera. What changes is the FOV and possibly the amount of vignetting of the image cirlce
And this is why Canadians have bought up half of Florida
davidib17
I wasn't looking for you guys to explain the crop factor to me. I know what that is and I know that full frame is the universal way a lenses focal length is described.
I just thought it wasn't a good idea to label a product with a completely false specification that the product itself can never actually be used for.
Mako2011
not false
Problem is...no product is being labeled falsely. Your suggestion that it is indicates you do not understand the meaning of the labeling, so folks tried to help in that regard and accurately answer the question you posed. For example. Every DX lens can be used exactly for the focal length it is labeled on DX and many FX cameras. The manual that goes with the lens explains the output results.  Do you have an example of "the product itself" unable to meet the labeling spec?
davidib17
Re: not false
A DX 35mm lens can not, and will not ever be able to take a picture at the same zoom length as a FX lens on a full frame camera set at 35mm, no?
blue_cheese
apples to apples
Sure it will, you take a 35mm lens... put in on FX (like a D800 for purposes of MP @36MP), and crop out the outer 33% all around and voila you have a 16MP D7000 image taken with the exact same 35mm.
Nothing to do with lens, not that the lens did not change in the above scenario
