What's a good wrist strap for X-E1 preferably easy to release?
Started May 27, 2013 | Discussions
Astrophotographer 10 Senior Member • Posts: 6,594
I use a leather neck strap and often this gets in the road. I was thinking a wrist strap would be more secure in a tourist area where the potential is for pickpockets to roam around. A fast release system would be nice.
Any ideas? There are lots of wrist straps on ebay but almost all have that little string that loops around the strap lug on the camera.
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 Zeiss Loxia 21mm F2.8 +4 more
Fujifilm X-E1
mjack101 Regular Member • Posts: 108
Re: What's a good wrist strap for XE1 preferably easy to release?
Greg.
I use this for my X-E1 and it works pretty well. It does have that little string but also has a quick release connector.
http://www.amazon.co.uk/gp/product/B000H02B6O
Astrophotographer 10 OP Senior Member • Posts: 6,594
The quick release aspect looks good but those plastic connectors don't inspire confidence of security.
Greg.
sibyy Regular Member • Posts: 136
I like these guys:
http://www.dsptch.com/collections/wrist
Bought a sling and a wrist strap for my X-E1. Very nice quality and love the design too.
I was a bit worried about that too but it was recommended to me and I have been using it for the last 3 months and no problems at all.
FWTOQA Regular Member • Posts: 268
Greg.
I use the same optech connector and both the string and plastic connector are more than adequate. The connector is the same sort of thing that you would find on a backpack or similar device. They just don't come loose or apart unless you want them to.
The connectors also come in packs of 4, and can be fastened to conventional straps. Enabling quick change between wrist or neck or shoulder straps. The same string fastener is kept on the camera, swooping to the alternative straps made easy.
Travelshooter Senior Member • Posts: 1,976
Re: What's a good wrist strap for X-E1 preferably easy to release?
 Travelshooter's gear list:Travelshooter's gear list
Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R +14 more
nixda Senior Member • Posts: 3,710
Op/Tech indeed
Greg.
By now, I have a whole system around the Op/Tech offerings, including large, padded neck strap, a sling, a backpack-attachment system , as well as mini-QD loops for a very compact, minimalist solution. I use it on a largish D7000 as well as on my X-E1. There is nothing flimsy about it at all, and the quick-connects are very convenient in the field. Highly recommended.
 nixda's gear list:nixda's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8
Ethel Contributing Member • Posts: 794
Check out the Crumpler Noose wrist strap - attaches to the normal strap ring and you can adjust the length / fit around your wrist.
No silly bits of string if you don't want to use them, and very secure with no quick-release clips.
 Ethel's gear list:Ethel's gear list
Fujifilm X-E1
David Lawson Senior Member • Posts: 2,776
I use one of gordy's straps, I had the regular size with the integral strap bumper. It's a bit small with the XE-1, but I had it on a smaller camera so am utilising it. If I were buying again 'd get the long one. Not quick release but easy to slip on and off your wrist, but still secure
search for gordys camera straps if this link is removed
http://www.gordyscamerastraps.com/wrist-lug/index.htm
