How to image the moon with D7100??
Started May 25, 2013 | Questions
starman1969
starman1969 Senior Member • Posts: 3,665
I do know how to take pictures of the moon and I have many. I know all about stacking, tracking etc. I did post a question in the astrophotography forum but there are so few viewers there.
The problem I have just run into is my D7100 Live View feature. When I was out last night trying to image the moon with it all I got on the LCD screen was a totally overexposed white blob. It did not matter if I lowered the ISO, increased the shutter speed or stopped the aperture down as much as I could. The moon was still a featureless blob.
This meant that I could not focus on it properly. I did not have that problem with the D7000. Does anybody have any ideas what's going on?
They are watching us......
 starman1969's gear list:starman1969's gear list
Sony Cyber-shot DSC-RX100 III Nikon D800E Nikon D600 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED +9 more
Nikon D7000 Nikon D7100
Placation101 Regular Member • Posts: 455
Re: How to image the moon with D7100??
okay so basically, just so we are on the same page. In matrix metering a picture of the moon will always be a white blob as the camera sees it. This is because it is shooting to average out the scene so it will bring up the exposure compensating for the black sky bringing it up too high for the moon (which is a tiny portion of the sky unless you have a huge lens).
the d7100 I believe is auto gain on the LCD meaning its not wysiwyg it chooses a brightness that allows you to focus. So somehow it's not keying in on the moon.
i would try playing with center or spot metering.
if you didn't zoom in try zooming in on the LCD so the moon fills a larger portion of the screen.
FujicaST605
FujicaST605 Regular Member • Posts: 462
The moon is a sunlit object.  Expose as such.
 FujicaST605's gear list:FujicaST605's gear list
Nikon D7100 Nikon AF Nikkor 50mm f/1.8D Tokina AT-X Pro 12-24mm f/4 DX II Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Nikon AF-S Nikkor 85mm f/1.8G
starman1969
starman1969 OP Senior Member • Posts: 3,665
That makes sense, thanks. I will try spot metering. That way the metering point will be completely covered by the moon. It should show up correctly then.
I can do a pic like this when everything works.
JeffryZ Senior Member • Posts: 2,236
I use manual. Set the exposure to the inverse of the ISO (1/100 th second for ISO 100)) and use the f/stop for a brightly sunlit object (f/ 16) and you will be extremely close if not right on.
Major crop and Photoshop adjustents to help the details but this was shot with my 80- 200mm f/2.8.  Never thought I could get this detail with a moon shot taken with a 200mm lens.
 JeffryZ's gear list:JeffryZ's gear list
Nikon D7100 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Tokina AT-X Pro 11-16mm f/2.8 DX +1 more
zakkix Regular Member • Posts: 377
https://blog.sony.com/2012/07/how-to-shoot-the-moon-and-get-stellar-photos/
http://www.astropix.com/BGDA/INTRO.HTM
http://www.reddit.com/r/astrophotography
lorenzo de medici Regular Member • Posts: 205
The live view mode does some strange stuff with aperture adjustments and exposure compensation.  The picture you see on the LCD screen does not necessarily correspond to the image produced by the camera.  It's some kind of simulation of what the camera thinks it will probably look like.  If you change the aperture, you have to exit live view and resume to see the result of the aperture change.  I would make sure that auto ISO is turned off, use spot focus and spot metering, and bracket your exposures anticipating that you'll get the best results around -2EV or -3EV.
 lorenzo de medici's gear list:lorenzo de medici's gear list
Nikon D600 Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Nikkor 50mm f/1.8D Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +3 more
Sammy Yousef
Sammy Yousef Veteran Member • Posts: 4,582
Stop down before entering live view, or use ND filter.
Nikon cameras can't adjust the aperture while in live view. They will adjust the aperture to shoot (when the live-view screen blinks off) but you'll have to set aperture before going into live view. And as for shutter speed for video, you get what you're given.
If you're using AF just focus on the rim of the moon and adjust exposure manually.
If you're trying to shoot video of the moon, you'll have to stop right down before going into live view and as I haven't tried it I can't promise you that will work either.
A perfectly valid alternative is to use an ND filter on the camera. I'd probably use a variable ND filter for this application because brightness of the moon will vary.
Sammy.
My forum postings reflect my own opinions and not those of my employer. I'm not employed in the photo business.
stevenjames
stevenjames Senior Member • Posts: 1,145
Use your histogram.
Switch to manual exposure settings and cut down on the exposure until you nail it.
Steve
www.StevenJamesPhotography.com
 stevenjames's gear list:stevenjames's gear list
Fujifilm X100S Nikon D7200 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Micro-Nikkor 85mm f/3.5G ED VR Tokina AT-X Pro 12-24mm f/4 DX II +9 more
