can you tell the IQ/ISO difference game: canon5dmk3 vs D800e at iso 6400
Started May 24, 2013 | Discussions
Wei Kelun
Wei Kelun Contributing Member • Posts: 524
Re: REVEAL TIME (big surprise!)
clarkent1234 wrote:
first one is Canon 5d mark III - 50L 2.8 iso6400..NR/sharpening etc off - both cameras identical in settings
second is: ..............wait for it................................CANON 40D......YES CANON 40D - 35L 2.8 iso1600 (its max!!!) shot at 1600 pushed 2 stops in PP. I am sure most are familiar with ISO pushing technic, so i wont get into that.
NoiseNinja was used at the exact same settings on both. and USM equally the same on CS6.
40D Raw looked a bit more grainy after being pushed 2 full stops in PP. But after Ninja on same setting used on 5dmk3, things looked about identical. Strange but true. Framing was about the same due to crop factor.
2006-7 mid-consumer-whatever-u want to call it- camera replaced by several generations...payed $200 used with high shutter count VS new $3500 full frame camera. Shot at 2.8 since my 35/50 is identical at 2.8!
I've shot weddings with a 40D as my main camera for years, its capable. Before someone says straight out of camera/straight jpeg is cleaner. Sure but not by a mile, and only at 100 percent you will see some differences. but if you payed money on either camera, with todays software available and you do not editing? thats a waste of any dslr/money.....even on one that doesn't even do video or even able to focus in live view (40D)
Nicely done.
Great Bustard Forum Pro • Posts: 33,334
Surprising, indeed!
The DOFs look remarkably similar, which is a surprise.  I imagine you shot the scenes from the same position since the 40D photo is framed a tad tighter than the 5D3 photo, as we would expect since 35mm on 1.6x is equivalent to 56mm on FF.  If so, it is indeed surprising that the DOFs look about the same.
Also, the 5D3 photo should be significantly less noisy as the exposures were the same, which puts 2.56x more light on the 5D3 sensor, and the 5D3 sensor is more efficient to boot.
Something seems amiss, here!
sean lancaster
sean lancaster Veteran Member • Posts: 6,787
Honestly, I thought the second image was better, but I also thought the D800 should look better than what I was seeing (however, I trusted that you weren't lying so I went with it). The sony sensor is outstanding in the Nikons. Even though I selected a 6D, if I was shooting landscape then I wouldn't have hesitated to get a current FF Nikon.
 sean lancaster's gear list:sean lancaster's gear list
Sony Alpha NEX-5N Sony Alpha 7 Sony Alpha 7R II Voigtlander 35mm F1.2 Nokton Sony FE 55mm F1.8 +4 more
Mako2011
Mako2011 MOD Forum Pro • Posts: 20,135
Love these
clarkent1234 wrote:
hey,
simple game, pick the image you like better based on IQ and high ISO results! after 15 guesses, i'll reveal which images belongs to each camera.
(CHEATERS: exif data was removed)
image 1
image 2
Second image seems to easily resolve more detail and the noise pattern seems finer. Pixel count though shows that the two images were sampled differently or the same area was cropped but the subject distance is different.
Based on that...I like the slightly greater detail and finer noise in the second pic. Resolution seems to say it's the D800 but that might be a focus or lens issue throwing it off. Still, just based on noise, I prefer the second pattern better as presented. Thanks much for sharing. Exposure/color in both are pretty close.  Good job presenting.
Now to go back and read the thread and see how off I was
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
Mako2011
That was fun!!
That was fun!!!  Thanks
clarkent1234 OP Forum Member • Posts: 85
Re: Love these
Mako2011 wrote:
clarkent1234 wrote:
hey,
image 1
image 2
oh you were off! lol
read the "reveal" post
Nicely done.
thanks
TTMartin
TTMartin Veteran Member • Posts: 7,304
Well I was right about the DOF.
My go everywhere camera is a Canon XTi and EF 40mm f/2.8 STM.
The 40D and XTi are close cousins, and both of them have amazing image quality.
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 40D Canon EOS 400D +26 more
Johnyguy Regular Member • Posts: 203
Re: can you tell the IQ/ISO difference game: canon5dmk3 vs D800e at iso 6400
Image 2 is the canon 5dmk3.
pgb
pgb Senior Member • Posts: 1,839
Great thread but you should have revealed later and caught more fish.
I thought the 2nd was D800 since it was a bit sharper and noisier but I'm happy to
know it was a 40D as I have one in front of me.
Noise Ninja here I come.
There was a similar shootout between $3000 mic preamps and the $300 Behringer, the votes were
undecided and some very annoyed people too.
In the beginning was the rhythm but I had forgotten and was waiting for the beat.
 pgb's gear list:pgb's gear list
Canon EOS 40D Sigma 17-70mm F2.8-4 DC Macro OS HSM Canon EF 28mm f/2.8 +8 more
SubPrime Senior Member • Posts: 1,238
t.c. marino wrote:
if these were shot at the same aperture/shutter speed(ev)my guess is image 1 is canon..from my experience with both brands..canons seems to have slightly more exposure than nikons at the same setting
My experience is quite the contrary and I own both cameras.  The Nikon is prone to over exposure and the Canon is prone to under.
qianp2k Forum Pro • Posts: 10,350
Top from D800E and bottom from 5DIII that is slightly sharper and should be
 qianp2k's gear list:qianp2k's gear list
Sony RX100 Canon EOS-1D Mark III Canon EOS 5D Mark II Canon EOS 5D Mark III Sony Alpha 7R +20 more
40D rocks for its age. And its all about the lens...In this case 2 great lenses that produce a similar image on 2 completely different camers..and a touch up in PP
image 2 is canon 40D pushed beyond its 1600max ISO to 6400 in post.
in the link you have the option of viewing at 100 percent. Which others did and still failed.
Re: How can it possibly matter with these images?
sure is meaningless....I was tired of the whole prosumer crowd was raving about 6D/5d3 being light years in better high iso and how now they are able to finally go past 400-800 iso. shot 2 is canon 40D....10mp with a max iso of 1600..shot at 1600..iso pushed digitally to 6400 and both had identical post treatment. And in the end most guessed it as a 36mp full frame sensor.
or to necessarily go 'full frame" for the sake of ISO performance? since its clear most people couldnt tell image 2 is from a canon 40D....a camera with a native of 1600iso max....pushed digital to 6400.
Just another Canon shooter
Just another Canon shooter Senior Member • Posts: 4,691
ISO does not determine (shot) noise, total exposure does. What was the EXIF in both cases?
 Just another Canon shooter's gear list:Just another Canon shooter's gear list
Canon EOS 5D Mark II Canon EF 15mm f/2.8 Fisheye Canon EF 35mm f/1.4L USM Canon EF 50mm f/1.2L USM Canon EF 135mm f/2.0L USM +4 more
for the sake of not repeating it over and over again. ISO in combination with SS does. 1/2500, 1/1000.
Smart man! better to have a "lesser" camera all the time than a full frame in a fancy bag at home in the closet.
