Anyone with an HDMI capture card?
Started May 24, 2013 | Discussions
jazzroy1972 Regular Member • Posts: 172
Hi,
I'd like to know if Nex-5n (or other, they'are all the same for output) HDMI is 8 bit or 10 bit, but to know it we need someone with a 10 bit HDMI capture card, like Blackmagic's shuttle or hyperdeck.
Sony Alpha NEX-5N
jazzroy1972 OP Regular Member • Posts: 172
Re: Anyone with an HDMI capture card?
bump
Knallberto Veteran Member • Posts: 5,478
I have a HDMI card (€70) AVerTV CaptureHD but do not use it often with cameras. You also get HDMI express cards (€110)
HDMI in Express Card
Thanks for the answer!
have you ever tried to capture from the camera?
It goes fullHD only when you hit record, so you have to record to SD to be able to capture fullhd through HDMI.
