about new XF55/200: I've seen only now
Started May 23, 2013 | Discussions
PeterPrism
PeterPrism OP Senior Member • Posts: 1,060
Re: about new XF55/200: I've seen only now
more long, more plastic
 PeterPrism's gear list:PeterPrism's gear list
Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +1 more
baobob
baobob Veteran Member • Posts: 7,222
peter
a thunderstorm in a cognac glass ???
Sony RX100 Olympus Tough TG-4 Fujifilm X-T1 Nikon D7200 Fujifilm X-T10 +12 more
EricWN Senior Member • Posts: 1,875
1drey wrote:
Similar seam present on 18-55. So what?
Moscow VR blog - http://1drey.wordpress.com
Exactly, just cause it's also used somewhere else means we gotta like it, right?
It's still plastic, and still ugly to some. That counts for those Zeiss lenses with that stupid name too
baobob
baobob
Peter
i just received some old glass that I'll use with the X Pro1
The Tamron 90mm 2.5 and the ext tube for macro and the Pentax 135mm 3.5 to wait till I can get a 55-200mm
They are built like tanks and despite their 20-25 years of age they are still in very good condition
BUT they weight a few tons...
I just would like also to remind you that the fabulous Macro Canon 100mm 2.8 L IS lens is mad eof pure plastic at 1000€ (at launch) and it is really a fabulous lens
Modern technology allows new ways of designs and built.
yes it is not as noble as steel copper or brass but it oftens allow much better performance in terms of comfort and easyness
These were my 3 grains of pepper in the sauce..
Cheers
Bob
actaswu New Member • Posts: 9
Although a metal barrel would have a better quality feel, it hasn't got the thermal stability of a polymer. A metallic inner tube may cause play or tighten up when temperature increases as its inertia is different from the outer barrel. (With primes this is less of an issue because the lens doesn't extend that much.)
And a good quality polymer such as Delrin is as or more expensive as metal.
 actaswu's gear list:actaswu's gear list
Fujifilm X100S Sony Alpha 7
nidri Regular Member • Posts: 129
PeterPrism wrote:
Travelshooter wrote:
The dashboards of 2.7 billion cars now have a brother.
damn but fuji works for ford?
Subaru is owned by Fuji Heavy Industries, and the interior of any Subaru is 100% pure plastic (if plastic can be said to be pure). Proof that, yes, there is a 'probable conspiracy' by Fujifilm to replace everything on the planet with plastic, including our brains. Okay, so Fuji Heavy Industries is not the same company as Fujifilm, but it's close enough, and I'm not about to let the truth get in the way here.
 nidri's gear list:nidri's gear list
Samsung NX1
liquid stereo
liquid stereo Veteran Member • Posts: 7,255
Miss-step
PeterPrism wrote:
I am convinced that these are missteps that Leica does not commit.
What are you on about? Did you buy a Fuji by mistake?
 liquid stereo's gear list:liquid stereo's gear list
Fujifilm FinePix X100 Canon EOS 7D Fujifilm X-Pro1 Canon EF 50mm f/1.4 USM Canon EF 50mm f/1.8 II +6 more
