Inconceivable! Nikon can't repair my 80-200 AFS!
Started May 23, 2013 | Discussions
Guidenet
Guidenet Forum Pro • Posts: 15,720
Is this just a mistake?
KewlEugene wrote:
I don't know how to call Nikon Service and talk to an actual repair guy these days, but way back when Nikon repair guys used to be accessible by phone, they cleaned the insides and fixed my 15-20 year old AFS 70-210/4.0-5.6, AFS 20/2.8, AFS 80-200/2.8, AFS 300/2.8, N2020 AF body, and more, which I then sold on eBay. They held most for years until they found the used parts.
Is this a simple typo or mistake because there is no such thing as an "AFS 70-210/4.0-5.6 or an AFS 20/2.8." Makes me wonder if the other two are AFS as well considering how long ago you're talking about. You sure you don't mean AIS or just AF?
Take care.
Cheers, Craig
Follow me on Twitter @craighardingsr : Equipment in Profile
 Guidenet's gear list:Guidenet's gear list
Canon PowerShot G1 X Nikon D300 Nikon D700 Nikon D3S Nikon D800 +31 more
Nikonparrothead Veteran Member • Posts: 4,610
Re: United Breaks Guitars
Sorry if I offended
'Nice pen, bet you write good stories with it.'
 Nikonparrothead's gear list:Nikonparrothead's gear list
Panasonic Lumix DMC-TZ1 Canon PowerShot S95 Fujifilm FinePix X100 Nikon Coolpix A Panasonic Lumix DMC-LX100 +13 more
coudet Veteran Member • Posts: 3,867
Re: Inconceivable! Nikon can't repair my 80-200 AFS!
r e cummings wrote:
I told them that my 80-200 afs stopped focusing and more than likely had a dead focus motor. They had me send it to them. Status of my repair is "• PARTS NO LONGER AVAILABLE • NO REPAIR item shipped". How is this even possible?
Not only is it possible, it's quite normal and not just with Nikon. Manufacturers will support a discontinued product up to a point and until spare parts are available, but not forever..
KewlEugene Regular Member • Posts: 306
Re: Is this just a mistake?
It's a typo. Nikon El Segundo fixed all those. Also I hear companies don't have to keep parts for more than 10 years.
Gittix Forum Member • Posts: 60
Not just Nikon.
I am in the car business and just to let you know, other companies are getting the same way. Since auto companies have gone to coded keys for ignition switches, most companies keep a database of key codes available to the owner. So with the VIN and proof of ownership to the dealer, an owner can have a key made. However, Ford has decided to only keep codes for 10 years.
If you have a Ford over 10 years old and lose or break the key, your only option is to have a locksmith make a key and have it towed to a Ford dealer for programming. This is a ridiculous expense for something as basic as a key. How difficult would it be to maintain the database for older vehicles? Considering the ease of keeping these codes and vehicles lasting longer and longer, this is horrible customer service. So if you have an older Ford with anti-theft, go make yourself an extra key!
 Gittix's gear list:Gittix's gear list
Nikon D3S Nikon D7000 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF +5 more
pdxflint Regular Member • Posts: 100
It does appear that there are some motors available for a couple hundred bucks, and that the ones for the 80-200AF-S are the same as the ones for the 28-70AF-S. Not sure if these are original Nikon or not, but at least it looks like there is a source for these things.
Meanwhile... I'm sticking with my AF-D 2-ring workhorse...
http://www.partshe.com/catalog/product/view/id/4409/s/oem-28-70mm-swm-80-200mm-2-8-silent-wave-motor-unit-new-repair-part-made-to-fit-nikon-af-s/
 pdxflint's gear list:pdxflint's gear list
Nikon D300 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF Nikkor 50mm f/1.8D Tokina AT-X Pro 12-24mm f/4 (IF) DX +1 more
Tim the Grey Veteran Member • Posts: 6,310
Now I'm scared! I just received a used AF-S 80-200, and it squeaks like a b*stard...
It was pretty cheap, so I MAY just bite the repair, and overhaul, but how long before I have a paperweight???
http://farm3.static.flickr.com/2443/3633920342_94e2b30000_s.jpg
The world's best Vulcan, XH558, after 14 years on the ground, lives again.
www.tvoc.co.uk
http://www.flickr.com/photos/sandfish_imagining/
sean kendrick Forum Member • Posts: 55
I told them that my 80-200 afs stopped focusing and more than likely had a dead focus motor. They had me send it to them. Status of my repair is "• PARTS NO LONGER AVAILABLE • NO REPAIR item shipped". How is this even possible? This was their premier zoom, and only went out of production in 2004. All I can say is LAME! Very sad because this is such a fantastic lens.
will they not give you a comparable lens? especially if it's still under warranty
r e cummings OP Regular Member • Posts: 207
No warranty. Stopped production 9 years ago.
kayone Regular Member • Posts: 316
dwa1 wrote:
Definitely not good news. However, I would check with some of the Authorized Nikon Service facilities. Perhaps one of them may have the part in stock? My first choice is always APS in Chicago.
http://nikoncamerarepair.com/
I wish you well in getting your lens repaired.
Wayne
an authorized Nikon service facility will likely order the needed parts directly from Nikon, and if the HQ service center does not have the parts, I doubt a 3rd party authorized center will either.
Wayne
Already found a 3rd party authorized center that has the parts. :~)
Midwest Camera Repair had the parts and replaced focus motor, focus sensor, clean, lube and calibrate for $420. :~) If Nikon had even had the parts, they would have charged over $600.
Cytokine Contributing Member • Posts: 661
Thats a really good outcome, well done! John
lac111 Veteran Member • Posts: 3,229
That's a great outcome, I wondered what was going on with that.
Lora
Profile is wrong, I've been on Dpreview since June 2006.
 lac111's gear list:lac111's gear list
Nikon D750 +1 more
10 years
Mfgs only keep parts for 10 year old products. Then it's up to repair shops to fix older gear. Because of technology, repairable cameras and lenses are fading away, likewise repair shops are rapidly vanishing. But we have the internet to communicate where the remaining good repair shops still are. So not all is lost.
iso800 New Member • Posts: 19
Re: 10 years
I must be lucky I've just had my 80-200 AFS lens repaired by Fixation in London.
I purchased the lens from Grey's of Westminster with 12 month warranty didn't think that Grey's would be willing to pay for the repair, I only had the lens about 5-6 months when the lens would stop focusing or focus intermittently, it wasn't a cheap repair but Grey's of Westminster gave the go ahead.
Had to wait for parts from Japan so took about a month in total. The parts replaced was the SWM unit, DC-DC converter and a Contact unit 10. Had the lens on Tuesday and all seems fine seems to focus faster, quieter and smother than before so I'm very happy and lucky to get parts.
Thanks to Grey's of Westminster and  Fixation for the repair.
K
(unknown member) Senior Member • Posts: 4,624
Re: 10 years Grey's
K
From all I have read, Grey's seems a wonderful company.
Enjoy.....believe in yourself..
 Bajerunner's gear list:Bajerunner's gear list
Nikon D300 Nikon AF-Nikkor 80-200mm f/2.8D ED +8 more
Cope
Cope Veteran Member • Posts: 6,327
Re: Nikon can't repair my 80-200 AFS!
Leonard Shepherd wrote:
My notes indicate this lens was withdrawn 10 years ago when the original 70-200 was introduced.
Whether it is reasonable for Nikon to carry parts 10 years later is really what this thread is about.
Leonard Shepherd
Many problems turn out to be a lack of intimate knowledge of complex modern camera equipment.
Sadly, the days when manufacturers carried parts for discontinued product are over.
Never ask a man where he's from. If he is from Texas, he'll tell you. Otherwise, don't embarrass him.
 Cope's gear list:Cope's gear list
Nikon D7000 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Tokina AT-X Pro 12-24mm f/4 (IF) DX +3 more
Re: 10 years
Interesting that Greys ordered parts from Japan. I wonder why Nikon US wouldn't do that? They just flat out said they didn't have the parts! Epic fail.
bryantroll New Member • Posts: 2
I just sent in my Nikon 80-200 AF-S to Authorized Photo Service due to erratic autofocus. I'd say about 1 out of 10 times I focus on something far away, it will not autofocus. If I point it at something nearby and focus, then I can point it at the intended far away subject and focus fine.
I was hoping the repair would be minimal but after inspecting the lens they found it needs a pretty extensive repair. The rear mount is worn which I knew and expected needed to be replaced, but they also found that the flex circuit board (fpc) inside the lens needs to be replaced as well. I asked a bit more detail on that and they said they have diagnostic equipment that runs the lens through a series of tests to identify the cause of the issue and that they are confident this is the root of the problem, not just the worn mount creating a poor contact. They will also clean and lubricate everything so it should come back to me even better than I ever remember it.
Unfortunately this full repair requires complete lens disassembly and the cost of the repair is $650 plus shipping costs both ways, which did shock me. I would be more hesitant to blindly give them the go ahead on the repair but since they have so many positive reviews I will have to trust them and just get this thing fixed up and back in my hands. Its a tough situation but the lens is a workhorse and as long as it comes back to me ready to perform as well or better than ever. I purchased the lens in used excellent condition 10 years ago and have used it extensively in that time so I have certainly gotten my value out of it. Hoping I'll get at least another 10 years out of it now.
I also sent in a Nikon 85mm f1.4 AF-D which I suspected had a backfocusing problem, which they confirmed. I was hoping for an inexpensive fix but that one's going to be $170 plus shipping both ways as it apparently required substantially disassembly to adjust the shims in the lens that affect focusing accuracy. Again, not happy, but there's no real choice if it means the equipment will work properly for me.
Unexpected expensive week with these repairs. I need to stop eyeing up this very interesting Sigma 35mm f1.4 and stop the bleeding for a while, haha.
