Seeking ways of tracking birds in flight with 500mm lens
Started May 23, 2013 | Discussions
Barry Pearson
Barry Pearson OP Veteran Member • Posts: 7,309
Re: Barry...
brandrx wrote:
I can abtain perfect balance with my Pentax DA*300/4 on my Wimberly gimbal. One thng a lot of folks don't realize is not only do you need to move the lens back or forth to obtain balance but you also need to move the lens up or down so that the center of the lens is in line with the vertical rotation point. On my Wimberly I can drop the platform that the lens sits on all the way down for my Pentax DA*250-600mm f5.6 or raise it almost all the way up for my Pentax DA*300mm f4.
I bought a Lensmaster RH2, which doesn't have such vertical adjustment. (I understand the principle of having the axes of rotation through the center of gravity of the lens+camera combination).
In practice this means that the assembly has a tendency to move from extreme pitch towards the horizontal. The small amount of friction keeps it in place at smaller pitch, and that is normally OK for me.
Perhaps I can find a different way of moving the lens towards the axis of rotation.
 Barry Pearson's gear list:Barry Pearson's gear list
Panasonic Lumix DMC-LX100 Pentax K-3 II Pentax K-1 Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 10-17mm F3.5-4.5 ED (IF) Fisheye +20 more
miles green
miles green Veteran Member • Posts: 5,197
Re: Seeking ways of tracking birds in flight with 500mm lens
Yes, practice on anything moving.
I was practicing on soap bubbles that 3-year-old was blowing off the balcony yesterday! Lol!
Miles Green
Pentaxian with chronic LBA
Corfu, Greece
 miles green's gear list:miles green's gear list
Pentax K-5 Pentax K-1 Sigma 70-200mm F2.8 EX DG Macro HSM II Pentax smc DA 21mm F3.2 AL Limited Pentax smc FA 31mm F1.8 AL Limited +10 more
miles green
monopod?
I'm surprised nobody has mentionned a monopod yet. I don't have one, but might get one soon to try.
Miles Green
Corfu, Greece
brandrx Forum Pro • Posts: 28,337
Re: Barry...
Barry,
After looking at the illustrations in the link you have listed, I think I would be tempted to remove that drop-down L plate and make the RH-2 into an RH-1. It appears to me that the axis of rotation would then be through the center for any lens, especially the Sigma 500/4.5 and Pentax DA*300/4. It might be worth a try.
Cheers.
Ron
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
SanMat Senior Member • Posts: 2,852
Back (AF) button focusing
Another suggestion, if not mentioned already - use the focus button on the back of the camera, instead of focusing with the shutter release button.  That way, the shutter release button doesn't have to do double duty - the AF system can keep tracking the subject independently of what the shutter-release button is doing.  For moving subjects this is a nice advantage (just make sure you also disable the focus capability of the shutter release button - off hand I can't remember where that is in the camera menus).
If you look on sites/blogs like Arthur Morris/Robert O'Toole et al., they (i.e. pros) all use back-button focusing (I think the Morris blog (http://www.birdsasart-blog.com/) even has a separate tutorial on back-button focusing).  What's unfortunate in the case of the Pentax cameras is the AF button is a bit small, whereas with Nikon/Canon the dedicated AF is more pronounced.
Takes some getting used to, but I switched to exclusively using back-button focusing a couple of years ago (for all situations, not just birds-in-flight), and I have no intention of switching back.
Pete
Barry Pearson
Second field trip with 500mm lens, & lessons
This afternoon (UK time) I went back to Redes Mere to test some of the suggestions in this thread. Here are my thoughts, illustrated by a couple of the photos I took.
Hand holding
Several of the responses said " hand hold; don't use a tripod". So I did.
This confirmed what I already knew - I will not be hand holding this three kilogram 500mm lens for long periods!
I've hand held shorter one kilogram lenses (60-250mm f/4 & 300mm f/4) on many shoots over the years, and know that they are pretty well at my personal limit for longish periods. After 66 years I know this isn't about to change for the better!
I can imagine using this lens on a gimbal for much of the time then lifting it off to hand hold for a short time. But the Arca clamp on the gimbal is not rapid release. I wonder if there is such a thing?
(I wish Pentax would bring out a weather resistant 1.4 teleconverter that worked with the above two lenses!)
Image acquisition and retention
I tried the two-eyes approach mentioned a couple of times. Without some sort of sighting aid I couldn't make any connection between what I was seeing with my left and right eyes.
My problem is acquiring the subject, not shooting it. (I've sometimes had similar problems with those other lenses at airshows, so I was not surprised).
It wasn't helped by the fact that I used the waterproof cover, (that arrived this morning), because of spots of rain.That stopped me easily sighting along the lens with my left eye. Perhaps in dry conditions this might work? To be investigated further.
(Hurrah for weather resistant lenses!)
Focal length
Some responses suggested that 500mm is too long.
But look at the uncropped photos below from today - for these, 500mm is about right. And many others needed longer reach. (These are the best - most are rubbish or just blank sky). These were shot over water - I couldn't get closer!
Please note that I take your suggestions seriously enough to rapidly go out and test them!
Barry Pearson
Re: Barry...
Barry,
The axis is OK for the Sigma 500mm. It is only the Pentax lenses where the axis is higher than the center of gravity, and it doesn't cause a problem in practice because only more extreme pitches move back towards the horizontal.
The RH2 can't easily (if at all) be used like the RH1 because the Arca clamp is fixed to the drop-down L plate. But it does raise the question about what advantage the RH2 is supposed to have over the RH1? (The RH1 is obviously lighter).
The RH1 costs GBP118 and the RH2 costs GBP148. A typical price for the Wimberly mark II is GBP520. (Ouch!)
Re: Second field trip with 500mm lens, & lessons
Barry,
I suggest you try turning off SR (if you havn't already), set aperture to f5.6, and increase your speed slightly. Also, for the time being try shooting in AF-S. I would also not shoot in continuous shooting for the time being. That way the camera will not even fire unless you are in focus. Track the bird and try for a single bird in the frame and in focus. After a period of time of practicing tracking birds in the viewfinder then switch back to AF-C and Continuous High and try for a series of shots.
Good luck and have fun.
Ron
BobORama
BobORama Senior Member • Posts: 2,107
dane dawg wrote:
I have taken a ton of BIF with this combo, and always find handheld is the way to go! Its way easier and natural to track the bird..
Wow...   those are great!   In a way its a statistics game.   Even with .5% keepers, all you need is 200 shots.
I have tried a monopod with gimbal and it seems to only work for launch shots but after that I lose the bird..
 BobORama's gear list:BobORama's gear list
Pentax K-5 Pentax K-1 Sigma 10mm F2.8 EX DC HSM Diagonal Fisheye Pentax smc DA 18-55mm F3.5-5.6 AL WR Samyang 14mm F2.8 IF ED MC Aspherical +8 more
Sunwayfoto DLC-50 Duo-Lever Clamp...
Check this out:
Cheers.
Ron
solarider Veteran Member • Posts: 4,390
While on the subject of Gimbals
I found one article about Gimbal heads, perhaps there are others to help round out the subject that someone would like to contribute?
http://www.shutterbug.com/content/gimbal-heads-essential-long-lens-accessory
History would be something extraordinary, if only it were true. Leo Tolstoy
Any dictator would admire the uniformity and obedience of the U.S. media.
Noam Chomsky
Science... became scientism, which means it didn't just pursue its own truths, it aggressively denied that there were any other truths at all... Ken Wilbur
At any given moment, there is a sort of all pervading orthodoxy, a general tacit
agreement not to discuss large and uncomfortable facts… Anyone who
challenges the prevailing orthodoxy finds himself silenced with surprising
effectiveness. - George Orwell
“It's not a matter of whether the war is not real, or if it is, Victory is not possible. The war is not meant to be won, it is meant to be continuous. … The war is waged by the ruling group against its own subjects and its object is not the victory over [the purported enemy], but to keep the very structure of society intact.” George Orwell, 1984
NancyP Veteran Member • Posts: 5,317
It takes time to get the hang of it
Is this lens easy for you to hold? If not, start pumping iron in excess of the lens plus camera weight. Go to someplace with lots of seagulls, or starlings if you are short of seagulls, and practice your acquisition and panning. I use the left eye to get within a few degrees of the bird and then track through viewfinder. It took me tons of crappy shots to get to the point where I got keepers more often than not.
NancyP
 NancyP's gear list:NancyP's gear list
Sigma DP3 Merrill
Re: It takes time to get the hang of it
I should add that I am a middle-aged non-fit woman, and the total kit weighs 2.3 kilos (Canon 60D, Canon 400mm f/5.6L, the L bracket that lives on the camera body, and often the tripod ring). That is a LOT lighter than your 4 kilo kit.
NancyP
Sigma DP3 Merrill
Barry Pearson
Re: While on the subject of Gimbals
While that article is probably right about the need for a strong tripod for the biggest lenses, that is not the case for lighter lenses. My lenses that I use on my Lensmaster RH2 gimbal weigh either one kilogram (Pentax 60-250mm f/4 & 300mm f/4) or three kilograms (Sigma 500mm f/4.5).
Although I also have a heavy duty Manfrotto, I want a tripod that I can carry around in my back-pack along with the gimbal head and my lunch. I use the Manfrotto 190CXPRO4 which (gasp, horror!) has 4-section legs and a center column. It worked for me with the Sigma lens on.
Here is a 2002 article at Luminous Landscape:
http://www.luminous-landscape.com/reviews/accessories/wimberley.shtml
The principles it talked about are right, but there is more competition now.
Here is the maker I and a friend use, primarily for price, GDP118 and GBP148:
http://www.lensmaster.co.uk/index.htm
The Lensmaster website has a couple of useful videos showing the freedom of movement with a light touch. I love being able to leave the camera & tripod & gimbal to stand by themselves while I have lunch or a chat, then when bikes or cars start to approach be able to position the camera with an easy touch.
Manfrotto supply the 393 gimbal head, which appears not to be well known. I don't know a lot about it.
Barry Pearson
At 66 I know my limitations! And a nerve problem in my neck has left my right arm a bit weak. (I'm trying to get it back to normal - for me - with posture adjustment and exercise).
What works for one person doesn't work for another. Another example is hunting experience - I've never handled a gun, but I'm certain there are transferable skills for those who have.
This thread illustrates something great about photography - we can come at it from many different directions and end up with methods and results unique to each of us.
LDBOK Senior Member • Posts: 1,056
I sometimes use a home-made shoulder stock, it adds some weight, but seems to give me smoother pans when following birds. I tried shooting BIF with a gimbal, but was surprised how difficult it was to aquire and stay on the subject.
http://larrydbrown.com
 LDBOK's gear list:LDBOK's gear list
Pentax MX-1 Pentax K-5 Pentax K-3 Pentax smc DA 15mm F4 ED AL Limited Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO +11 more
miles green
Yes but when a rare bird comes and goes and all you get is blue skies and blurry trees, it's very frustrating.... Then if you want to get close, capture landings and feedings, etc, it's less statistics and more preparation...
I am still ill-prepared....
But i'm working on it!
Miles Green
Corfu, Greece
Barry Pearson
Interesting method!
Would it be possible to support some of the weight on my right shoulder? (This isn't something I'm familiar with). I can imagine that it could extend forward of the lens tripod bracket, to give greater leverage and a better grip with my left hand, then extend to on top of my right shoulder, rather than just up to it. Let's try .....
My woodworking skills are rubbish, but I just did a lash-up as proof of concept. (And used my Q to take the photos. I knew it would be useful sometime!)
When the wood behind the camera is on my right shoulder, I can just about see through the eyepiece with my right eye. And I can hold the wood in front of the tripod bracket on the lens with my left hand, and keep my left elbow against my chest for extra support. I still couldn't do this for long periods, but it does appear to offer smoother panning.
This shows promise (if done properly)! Thanks!
Barry,
My shoulder stock is made from from two pieces of wood cut from a piece of what is called 2x6 lunber in the US,    and two steel right-angle brackets usually used to support shelves. I don't have a photo available now and probably won't have time to take one for a few days. There is a company in the US called BushHawk which makes a line of shoulder-stocks which can be customized to the photographer's individual needs:  www.bushhawk.com  You can google BushHawk and find a number of reviews on their products.
Cheers,  Larry
Barry Pearson
LDBOK wrote:
Barry,
It's amazing that whatever you can vaguely think of, someone somewhere makes it, and someone on DPReview knows about it and can tell you about it!
I've just found these:
Thanks!
(Don't bother to take photos. Now that I know the principles, I can go make progress).
