Tripod Pan handle came off.. Help requested
Started May 23, 2013 | Discussions
JunzInc Regular Member • Posts: 472
I have been using a Vista Explorer 60-Inch Lightweight Tripod. I know this is a crappy $25 tripod and I probably got what I paid for. I was pretty happy with it for using my NEX5n. Couple of days before as I was getting it out of the bag the pan handle came off and a nut also came loose.  This might sound stupid, but I cant find out where the nut came out from so I can put it back in place. Here is a picture of it. Does any one know or have any suggestions? Appreciate any help.
 JunzInc's gear list:JunzInc's gear list
Olympus E-M1 Sony a6000 Olympus 12-40mm F2.8 Pro Adobe Photoshop Lightroom 4 Corel PaintShop Pro X4
Sony Alpha NEX-5N
LordShadow New Member • Posts: 1
Re: Tripod Pan handle came off.. Help requested
The exact same thing happened to me. I know this post is almost a year old, but I was wondering if you ever found a way to get this fixed?
scorrpio
scorrpio Veteran Member • Posts: 3,595
Most likely, there is a slot for the nut somewhere.    Probably underneath or on the 'inside' side.
hotdog321
hotdog321 Forum Pro • Posts: 20,283
That's what I figure, too. Somehow the handle has to thread though that nut, and the nut has to go inside the head. Looks really common, too, so a replacement nut can be found at any hardware store if it is stripped.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
Photofunster
Photofunster Senior Member • Posts: 1,548
Hi,
Please go to the following Tiffen link, and in the left column click on
Davis  & Sanford
Where you can find your parts and a contact point, is little further down the column.
http://www.tiffen.com/products.html?tablename=vista
Vista, a division of Davis & Sanford Tripods & Support Systems, offers this series of lightweight tripods that combines compact design with sturdy construction. They are easily maneuverable and perfect anywhere - especially in tight places. Materials have an excellent strength-to-weight ratio. Backed by a 10-year warranty!
Best of luck...
Chas
D800, AF-S NIKKOR 80-400mm f/4.5-5.6 G ED VR, B+W Clear MRC 77mm, AF-S NIKKOR 24-120mm f/4G ED VR, Sigma DG UV 77mm,
SB-910, WG-AS3, ME-1, Lexar Professional 600x 64GB SDXC UHS-I 90MB/s*, 400x 32GB SDHC UHS-l 60MB/s*
Vanguard ALTA PRO 263AT, GH-300T, SBH-250, SBH-100, PH-22,
Lowepro S&F Deluxe Technical Belt and Harness~Pouch 60 AW 50 AW & 10, S&F Toploader 70 AW, LC 11x26cm
FE, NIKKOR 2-20mm f/1.8, OPTEX UV 52mm, Viivitar Zoom 285,
Kodacolor VR 1000 CF 135-24 EXP DX 35mm, rePLAY XD 1080P
 Photofunster's gear list:Photofunster's gear list
Nikon D800 Nikon AF-S Nikkor 24-120mm F4G ED VR Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR Apple iPad 3G +WiFi +2 more
Havie New Member • Posts: 1
if you look on the back side of the tripod pan head, the rear of where the handle goes in you will find a slot to reinsert the nut.
good luck
Nathan23 New Member • Posts: 1
Hi Lordshadow: I'm from the Philippines and I bought the same tripod wayback 2014 when I had job assignment in US. I also had the same problem with yours just last night  6/30/2016 but after 1hour of trial and error and full effort of trying to fit the nut in the middle of the gap, at last I've found out where the nut should belong. The nut has a special place rear back under area of the screw panel where you insert the handle. Just turn upside down and I'm sure you can find it.  No need to take off the round plastic nut because you can just insert the nut under. Please refer to the picture. I hope that I was able to help you on your problem even it's already 2years ago. I was just happy the I've figure it out and would like to share and help others.
vgklicks New Member • Posts: 1
thanks a ton Nathan23...I was struggling with this screw past 4 months and finally thought to give a last try by searching something on google...and there i found ur reply.
annebetter New Member • Posts: 5
Thanks! It has helped me too!
 annebetter's gear list:annebetter's gear list
Nikon D5200 Samsung NX2000 Fujifilm X-T1 Fujifilm XF 56mm F1.2 R Apple iPhone 6 Plus
H4mm3rY New Member • Posts: 1
After two years of your post and its still useful.
The handle was off the moment I unpacked my tripod for the 1st time and I was about to give up hope fixing it till I saw your post. Thanks a lot for sharing it
SriViewFinder_17 New Member • Posts: 1
thanks man that drove me crazy but fixed it, you saved my time with the pic especially..
