Firmware upgrade causes AF slow down on 18-55!
Started May 23, 2013 | Discussions
svx94 Senior Member • Posts: 2,289
Just did upgrade and now the AF on my 18-55mm is slow as hell.  Anyone else experience the same problem?
 svx94's gear list:svx94's gear list
Nikon Coolpix 4500 Fujifilm X-M1 Nikon D700 Nikon AF-S Nikkor 24-120mm f/4G ED VR Nikon PC-E Nikkor 24mm f/3.5D ED +9 more
helmus
helmus Contributing Member • Posts: 532
Re: Firmware upgrade causes AF slow down on 18-55!
What a FW Version is on your 18-55 ?   1.01 ?
Did you update the body with the lens connected ?  You should not do that !
 helmus's gear list:helmus's gear list
Fujifilm X-E2 Fujifilm X-T1 Fujifilm X-Pro2 Fujifilm XF 14mm F2.8 R Fujifilm XF 35mm F1.4 R +14 more
jl_smith
jl_smith Veteran Member • Posts: 3,668
Fuji say nothing about having the lens connected if one updates firmware, only to not remove the lens during the process.
JL Smith
www.flickr.com/photos/jl_smith
www.clickingwithsmitty.com
 jl_smith's gear list:jl_smith's gear list
Fujifilm X-T10 Samyang 85mm F1.4 Aspherical IF Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
ohmydentist Senior Member • Posts: 1,918
I don't get what Helmus was saying either.  Are we supposed to have just a body cap on body, when updating??
^__^
Just Shoot !
baobob
baobob Veteran Member • Posts: 7,222
Not really
My 18-55mm is desperately slow at 55mm dim light and often does not lock but FW upgrade didn(t change that
In normal light the 18-55mm has always been really slower than others 18 and 35mm and is still slower It's not my copy because at my dealer when i bought it I notices that too
The 60mm in dim light is faster and also locks anyway even if very very slow, very few misses
Sony RX100 Olympus Tough TG-4 Fujifilm X-T1 Fujifilm X-T10 Nikon D7200 +12 more
baobob
Exactly! since you are asked body or lens.
AB8ND
AB8ND Regular Member • Posts: 170
Mine is fine, at either 18mm or 55mm. I had the lens on during the upgrade, only took it off for the first step.
 AB8ND's gear list:AB8ND's gear list
Fujifilm X100S Fujifilm X-E1 Canon EOS 6D Fujifilm X-T10 Fujifilm XF 14mm F2.8 R +5 more
bigpigbig Senior Member • Posts: 1,721
If you don't have the 55-200, is there any reason to apply this update?
 bigpigbig's gear list:bigpigbig's gear list
Fujifilm X-E1 Fujifilm X-T1 Nikon D810 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 35mm F1.4 R +12 more
57even Senior Member • Posts: 9,441
Nonsense. As long as you make the right selection you are fine.
But you do need the latest lens FW to go with the body FW.
My 18-55 seems to focus fine now, haven't upgraded yet.
 57even's gear list:57even's gear list
Fujifilm X-Pro2
Ross Kennedy Regular Member • Posts: 300
baobob wrote:
Not really
Hey Baobob, are you sure your 18-55 is working properly? The linear motor should make it focus faster than the primes. My 18-55 is considerably faster than my 35mm (in any lighting conditions). It's locking on in a fraction of a second.
baobob
True in bright light not true in dim light I have tried several copies they are all similar
All in all find the 18 and 35mm faster in avreage lighting conditions
In very dim light the 60mm can achieve focus where the 5mm does not
No miracle, 2.8 instead of 1.4; 4 instead of 2.4
suvi New Member • Posts: 4
JL Smith
On Fuji site under FW update instructions says:
Turn the camera on while holding down the [BACK] button, while XF lens is not attached to the camera body.
So if you are doing FW update for body, you should remove lens before you start update.
 suvi's gear list:suvi's gear list
Fujifilm X-E1
helmus
To do the update, without a connected lens, was a part of the 1.04 FW install instuction, which was attached to the 14mm lens.
Sorry...
There are differing instructions.
I assume this was written because people were making the wrong selection between lens and body.
But I generally update the body FW before attaching a new lens anyway. However I have not so far had a problem if there was an old lens attached at the time.
Fujifilm X-Pro2
suvi wrote:
JL Smith
It works either way, but this way it ensures people do not accidentally overwrite the camera firmware, which would disable the camera, by choosing the wrong menu option.
I am sure it has happened a few times.
Fujifilm X-Pro2
True, but the 18-55 has a much shorter focus throw, and in good light mine is definitely pretty fast.
Fujifilm X-Pro2
mcshan Veteran Member • Posts: 3,706
I will skip this upgrade as I will never buy the 55-200. I consider the 18-55 focus to be fast especially since I came to the Fuji via the Leica X1 which is very slow.
I have always done firmware updates with a lens attached but as noted it is important to pick body or lens.
Good luck to all who need this upgrade for eventual 55-200 use.
baobob
My purchase of the 55-200mm lens will be linked to a reasonable fast AF since this lens will be used to catch fast action from a distance
If it is not the case I'll continue buying fantastic old glass may be a 200m I already ordered a 135mm 3.5 compact in size pure MF....
94
94 Senior Member • Posts: 1,060
Good choice. I was surprised to get good results from my old B&H/Canon FD 135 f1:2.5 S.C. using an adapter to my X-Pro1.  It's not what could be called a lightweight lens (probably heavier than the new 55-200mm) but it gave me immense pleasure to get good results from a lens that had been on a shelf with all of my old film Canon stuff.
I don't know enough about the physics of it all that would make a 135mm lens fill the frame with these sensors but it does it. Too bad I couldn't get the Fuji manual focus assist to switch on with the old lens attached. That would have been perfect.
I'd bought the adapter to use my FD 50mm F:1.4 SSC on a Canon bellows to photograph stamps to sell, and tried the 135 just for kicks.
 94's gear list:94's gear list
Fujifilm X100T Canon EOS 5D Mark II Canon EOS-1D Mark II N Fujifilm X-Pro1 Fujifilm X-T1 +26 more
baobob
I already got a tamron 90mm 2.5 macro and its ext tube to get up to 1:1 ratiomacro, a 17mm Tokina that will go with the tilt and shift Kipon adapter that should arribe in 2-3 days and ordered the Pentax K mount 135mm 3.5 that hyas got good reputation
If the AF of the 55-200mm is not fast enough a 200mm f4 costs in Minolta or pentax 60€....
The EVF with 3 or 10x allows rather easy focus handheld wide open
