Focusing screen not square (450d/XSi)
Started May 21, 2013 | Discussions
AnthonyL Senior Member • Posts: 2,067
From time to time I've tried to use the focus points to try and align vertical and/or horizontal lines for instance of buildings, only to get home and find I'm having to rotate the image to get it square.
Today I belatedly tried a couple of tests using the frames of the lounge window.  In this picture the centre focus was directly on the vertical/horizontal intersection, the vertical points on the vertical bar and the horizontal points on the horizontal bar.  Handheld but that isn't the problem (I'm still fairly steady ).
A similar test using the grid lines on live view is satisfactory.
I reckon the image is about 2.15deg out.  Are there any easy solutions?
Focus points where aligned to bars when taken.
 AnthonyL's gear list:AnthonyL's gear list
Canon EOS 450D Canon EOS 700D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 55-250mm f/4-5.6 IS Canon EF-S 18-55mm f/3.5-5.6 IS STM +2 more
rsn48 Veteran Member • Posts: 7,254
When questions about image...
If you are posting questions about images, the data is almost a necessity; in this case what focal length are you using.
Hindsight is better than foresight, except for lost opportunity costs.
(unknown member) Senior Member • Posts: 5,590
Re: When questions about image...
What would the focal length have to do with a question such as this?
TTMartin
TTMartin Veteran Member • Posts: 7,304
Re: Focusing screen not square (450d/XSi)
The focus screen is visible when you remove the lens.
On cameras some cameras like the 50D they are designed to be changeable.
The focus screen on the XSi it is not designed to be changable.
There is a company that makes replacement screens for the camera that has directions on how to do it.
WARNING: Focus screens are soft and scratch easily. I would not recommend messing with it.
But, if you still feel compelled to mess with it, here is a link to the directions.
http://www.katzeyeoptics.com/files/install7.pdf
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 40D Canon EOS 400D +26 more
AnthonyL OP Senior Member • Posts: 2,067
Mmm - well apart from the risk of damage I'm not convinced that I could take it out and put it back with any more accuracy so I'll take your recommendation to not mess with it.  I'll try and find a better way of ensuring that verticals are vertical and horizontals are horizontal now I know I have this problem.
I'm don't think the focal length is very relevant but if it helps you answer my question it was taken with the 18-55mm lens at 34mm at a distance of about 3m from the window.
If ultra wide, could be distortion
I asked because if you had been shooting in the ultra wide range, disortion is the order of the day.  But you weren't shooting in that focal range.
To me it is just normal problems with hand holding.  I recognize it because I do it so much.  I shoot very fast often and as a result I get tilted images, many of them. I just fix them in post production, easy to do, take seconds.
There's nothing wrong with your camera.
PhilPreston3072 Senior Member • Posts: 2,272
If it's just the focusing screen that is out of alignment then I don't think it should cost too much for it to be serviced by technicians, since it's fairly easy to access. Hopefully no more than half the cost of a new body.
You might also want to check if your sensor is in alignment by setting your camera to manual sensor clean and visually checking if the sensor is still square with the body.
 PhilPreston3072's gear list:PhilPreston3072's gear list
Canon EOS 450D Canon EF-S 18-200mm f/3.5-5.6 IS +1 more
WilbaW
WilbaW Forum Pro • Posts: 10,693
I'd try it on a tripod so that you can be sure it's not you tilting the camera when you press the shutter button.
It's easy to remove and replace the focus screen in a 450D if you know what you're doing, but yeah, daunting the first time and easy to mess up.
Check out the unofficial Rebel Talk FAQ - http://snipurl.com/RebelFAQ
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
Re: If ultra wide, could be distortion
I'm not going to get that sort of extertion even with my 10-22 at 10mm.
I think you have not understood my issue.  The dots I see through the viewfinder line up exactly with the bars.  I have mistakenly used these to help align vertical and horizontal only to get home and find that I'm a couple of degrees out.  This is not a hand holding problem.  When I have aligned using a tripod I get the same result.  Put another way, if you look at the original image, the dots would not fit in the centre of the squares at the extremes.  If it was easy to rotate the focusing screen by 2deg then they would align.
Next time I take an image of say a building I will align the leftmost point below the horizon and the rightmost point above the horizon unless anyone has a better suggestion.
Or use the live view grid if I'm on a tripod.
Tripod makes no difference.  The dots don't align exactly with the squares.
I don't know if replacing would make a difference, I was hoping to rotate.
Do you have the full URL for the RebelFAQ site - Firefox is warning me against going to that URL, presumably because snipurl has been used for linking to some dodgy sites?
If you do a google search on "Focusing screen in Canon not aligned" or similar you will see that this is a fairly common issue, especially on the Rebel / xxx class models and I'm not sure there is much that can be done about correcting it I'm afraid.
You could use the frame of the focussing screen for lining up horizontals perhaps rather than relying on the AF points, as this should be aligned correctly even if the focussing screen with its etched AF points are slightly out.
Y0GI Veteran Member • Posts: 5,228
Here is a direct link to the FAQs.
And Here is a focus screen tutorial for the XSi/450D.
Good luck!
Yogi
When you get down to the nuts and bolts of photography, the results depend on the 'nut' behind the camera!
See the 'Gear List' in my 'Profile' for my current equipment.
Check out WilbaW's beginner FAQs at - http://snipurl.com/RebelFAQ
 Y0GI's gear list:Y0GI's gear list
Canon EOS 7D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100-400mm f/4.5-5.6L IS USM +2 more
photonius Veteran Member • Posts: 6,474
I wouldn't bet on it.
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
I have the same feeling with my 550D, I tried  using the dots for alignment, and then it's not straight in the final picture. I have not done a rigorous test, but when I tilt the camera a bit so the dots don't quite line up (in opposite direction of the tilt), then it looks more straight afterwards. As suggested, in live view that problem shouldn't exist.
I suspect it may not be unusually for the viewfinder to be off by 1 or 2 degrees - which is of course not desired. I will have to test it seriously with the camera on a tripod and a level to make sure all is perfectly aligned (a horizon may not always be horizontal either).
The reason I am not surprised about variation is that in my 550D, the central spot exposure metering point was actually not in the center at all, but substantially off to the right. Took Canon several attempts to fix it, because initially they didn't figure out what was wrong, I had to pinpoint the exposure problem for them.
WilbaW
Just in case we're misunderstanding each other, when I said replace I meant put it back in again to see if seated better, I didn't mean put in a replacement.
Ow, first time I've seen that. Thanks for letting me know. I can't tell whether it's a problem with snipurl itself or some sites you get to via its redirection. I'd better use the direct link in my sig for a while.
Check out the unofficial Rebel Talk FAQ - http://www.dpreview.com/articles/1905744226/rebel-forum-faq
Midwest Forum Pro • Posts: 16,101
I've gotten that sort of warning before on links that used something called tiny url - I guess because it disguises the true address of where you're heading when you click the link.
mfait Contributing Member • Posts: 648
You don't actually see through the focusing screen.  The focusing screen is under the mirror.  The focus points are for display purposes in the viewfinder so you know where they are located.
See http://www.dyxum.com/columns/photoworld/fundamentals/optical_viewfinder.asp
Therefore, either you mirror or your pentamirror is a bit off tilting the image in the viewfinder.
 mfait's gear list:mfait's gear list
Canon PowerShot S100 Canon EOS 450D
TTMartin
You don't see through the focusing screen, but, you do see the image projected ON the focusing screen.
On the 450d/XSi focus squares are etched on the focus screen.
Tilting a mirror does not rotate the image.
Thanks for the correction.  I was thinking about the focus sensor.
