Wife Dropped My 2 Week Old RX100 :(
Started May 20, 2013 | Discussions
MikeWarner
MikeWarner Forum Member • Posts: 64
I got in the car yesterday and put the seatbelt on, but my seatbelt was uncomfortable against the RX100 in my jacket pocket, so I handed it to my wife to "look after" while I was driving.  She put it on her lap and forgot it was there, so when she got out of the car, it was sent falling to the ground.  It was in a Crumpler case and landed onto flat concrete, but somehow managed to find the only stone in the area to land lens down onto.  The stone pieced the Crumpler case and dented the rotating ring.  It is now scratched and the ring does not rotate freely as it is bent in slightly.
So - first off, I'm glad I spent the extra for the 3 year warranty and accidental damage cover.  But it is going to take longer to fix than I've owned the things for to start with.
You can see the damage above (next to the Sony logo) - it doesn't look like much, but enough to stop the ring rotating smoothly.  It is harder to rotate and the friction varies depending on its position.  Apart from that, It seems to work fine.
Hopefully it won't take longer than 6 weeks to fix as I'm going on holiday to Egypt then and would really like the camera with me!!!!! Not happy at all.
 MikeWarner's gear list:MikeWarner's gear list
Sony RX100 Adobe Photoshop Lightroom 4 Apple iPhone 5 Apple iPad WiFi
Sony RX100
Travis
Travis Veteran Member • Posts: 3,188
Re: Wife Dropped My 2 Week Old RX100 :(
Bummer!  Hopefully, you'll get it returned soon.
What 3-year warranty were you referring to, by the way?  My RX100 is about the same "age" as yours and I haven't gotten any accidental warranty.  But I'm thinking maybe I should before we go on our trip to Disneyworld.
Thanks,
Travis
 Travis's gear list:Travis's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-LX100 Canon EOS 550D Panasonic Lumix DMC-GH3 Canon EF-S 15-85mm f/3.5-5.6 IS USM +4 more
MikeWarner
MikeWarner OP Forum Member • Posts: 64
I'm in the UK and the cover is with John Lewis (the store I bought it from).  It was only £47 (about $72) for the 3 years.  They are saying 'up to' 4 weeks, so fingers crossed there won't be any delay.  I'll have to use my old HX5V for the duration.
Enir4 Senior Member • Posts: 2,386
I hope you will get your RX100 back before your trip. If not, your wife will understand if you get the RX1. More shock resistant. It's the right moment.
Enrique
 Enir4's gear list:Enir4's gear list
Sony Cyber-shot DSC-RX100 III Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +4 more
cmc1 Regular Member • Posts: 170
Never mind, it's only a little camera. There was once a time (probably 1950's) where she would have felt the back fo your hand for that.
Only joking. Just get the RX1 and tell her It's the latest RX100.
 cmc1's gear list:cmc1's gear list
Sony RX100 Fujifilm X100T Nikon D610 Nikon D7200 Nikon D5 +3 more
tex Veteran Member • Posts: 6,832
Why you should consider another bag...
you need more padding for this sort of carelessness.  Try Lowe, Think Tank, Kata....
tex_andrews
"Photography is the product of complete alienation" Marcel Proust
"I would like to see photography make people despise painting until something else will make photography unbearable." Marcel Duchamp
 tex's gear list:tex's gear list
Sony Alpha 7R Pentax 645Z Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Rokinon T-S 24mm 1:3.5 ED AS UMC +15 more
jeanmichd Junior Member • Posts: 32
I dropped mine too and had the whole front body replaced by Sony France for €77 all included in just one week !
I still use the tiny Lowepro bag for regular usage (I just take some more care...) but invested in a Pelican 1010 Micro Case Box for 100% protection while biking or hiking
The RX100 fits perfectly in this box like it was custom tailored.
JeanM
lenshoarder Contributing Member • Posts: 609
I dropped mine taking it out of the box the first time.  No damage though.
MikeWarner
I have a small Lowepro too (Apex 20AW), but it is a bit bulky to put in a pocket.  As I was only using it indoors, I thought I'd use the small Crumpler case instead (which is really for my old HX5V)....... oh well.  Won't do that again.
SyberianShot
SyberianShot Forum Member • Posts: 95
Whenever anyone else handles my Rx100 I insist that they use my locking wrist strap.
 SyberianShot's gear list:SyberianShot's gear list
Adobe Photoshop CS6 extended Adobe Photoshop Lightroom 4 +1 more
Michael's Photos Regular Member • Posts: 290
Consider disabling the ring. First, you don't need it. You can access any function you need with the Fn, then use the scroll ring on the back. Simple, easy. Then, you can get a push-on lens cap that protect the delicate lens cover mechanism, which you can't really use if the control ring is active.
Digital Nigel Veteran Member • Posts: 4,087
I thought there were a few functions only accessible using the front ring, such as choosing scene modes or focusing.
 Digital Nigel's gear list:Digital Nigel's gear list
Sony RX100 Panasonic Lumix DMC-FZ1000 Canon PowerShot G7 X Sony Alpha NEX-7 Sony a6000 +10 more
For Scenes: Make sure "Mode Dial Guide" in the Menu (toolbar section) is set to "on,"  then when you turn the mode wheel on top of the camera to "SCN" you'll see the different scenes, and you can scroll to the one you want with the wheel on back of the camera. As far as manual focus, that one I don't know since I never manually focus.
Digitall
Digitall Regular Member • Posts: 417
RX100 will be the camera that falls more often the hands of photographer? geezzz I've read enough reports RX100 accidentally fall. A design error eventually? Is that my wife has dropped precisely our RX100, made a small dent on the edge of the metallic base of the camera, hardly noticeable. I was psychologically affected I wonder what you feel...
Ordered today the Richard Franiec grip for better handling. Let's see if it works.
MikeWarner
I'm the sort of person who buys and iPhone and after 2 years sells it on and can describe it is "looks new", so any scratch on my RX100 is going to really upset me.  Even though I have accidental damage cover on it.  The cover does not cover cosmetic damage though - but in this case the funtion is impared, so hopefully all scratched parts will be replaced making it look new again.
Having a better grip on it wouldn't have helped in this case, but in future I think I'll make sure my wife doesn't get her hands on it ever again.  To think she suggested selling our 3 year old "looks new" HX5V, saying we don't need two cameras.  I think she just proved that we do!!!!  She previously lost a Panasonic DMC-FX150 of mine leaving it in a planetarium.  That was a really decent camera at the time too.
Keeping the camera as is and not using the front ring isn't an option for me - I just couldn't live with an imparied product.
elliottnewcomb Forum Pro • Posts: 10,678
I have same warranty, I would take it to Egypt, use it, have it fixed later. Have a back up camera, perhaps one that takes regular batteries.
Back up your pictures while you are there, ...,
Of course post shots upon return, enjoy the trip.
Elliott
 elliottnewcomb's gear list:elliottnewcomb's gear list
Sony RX100 Sony RX1R Olympus Stylus 1 Sony Cyber-shot DSC-RX100 III +1 more
About two or three years ago my wife took my Canon S90 to the boat, she wanted to photograph the beautiful scenery. It was a stormy day. A wave went over her and the S90. No fun. Now she has her own camera and my cameras feel safe.
Enrique
Stephen McDonald
Stephen McDonald Forum Pro • Posts: 13,044
Drop & Dunk Warranties
Be aware that every penny they write up as the charge for fixing the camera will come off the limits of the warranty, which is the purchase price. If they say the repair was worth $300., then you have only $350. left for future damage. If you have a major repair need later, they may say that it exceeds what you have remaining and you'll get only what was left as a refund and they'll keep the camera.
If you can figure a way to bend the parts back enough yourself, so they'll rotate freely, you'll be in a much better position.
Liz Z.
Liz Z. Senior Member • Posts: 1,267
Wife slapping-- such an amusing reference.
These wives-- so easy to fool 'em! You can go out and buy a fancy $3000 camera, 'cause they won't know the difference between that and a $600 one anyway.
Yeah, I know, where's my sense of humor?
 Liz Z.'s gear list:Liz Z.'s gear list
Fujifilm FinePix F31fd Sony RX100 Adobe Photoshop CS6 +1 more
