I am downright impressed.....with the X-E1!
Started May 19, 2013 | Discussions
Ben Herrmann
Ben Herrmann Forum Pro • Posts: 17,410
For years I've been shooting only RAW with countless brands of digital cameras that I've owned since 2001 (well, those that had RAW capabilities) - the total of which approached nearly 90 (since 2001).  My reasoning (and it still holds true in most cases) is that I can coax much higher quality out of RAW files than with JPG's.  Even with the gorgeous Olympus JPG's, I still shot RAW.  I had my RAW workflow down to a T.
Well, I've been reading with interest over the past year or two about the absolutely silky, superb JPG's that the X series of cameras are capable of generating.  So what the heck, I tried it in JPG fine (Provia mode).  All I can say is that I'm hooked - especially after reading the DPReview review comments about RAW not having much of an advantage over the X-E1 JPG's.  Yes, the rich, creamy (for lack of a better term) and superbly DR images are a revelation.  In a way, this kind of torques me off at the same time because previously, I was dishing out a bundle for micro 4/3 cameras and accessories.  I can't believe that for me - a victim of habit - I will now shoot only JPG's with the X-E1.  Mannnn, I'm stoked to the max - not to mention, a doubling of the amount if images I can shoot on one 16 Gig card!!!!!
Now to budget for additional X series lenses - and am now fully hooked to the Fuji camp.  Damn, I hate this (in a nice sort of way).
Sorry - I just felt that I had to blurt this out without much forethought!
Have a great one....
Bernd (Ben) W. Herrmann
North Carolina, USA
link
 Ben Herrmann's gear list:Ben Herrmann's gear list
Olympus XZ-1 Canon PowerShot G12 Canon PowerShot SX50 HS Nikon Coolpix P330 Fujifilm X20 +38 more
Fujifilm X-E1
bestbyte Regular Member • Posts: 155
Re: I am downright impressed.....with the X-E1!
North Carolina, USA
link
Damn, you are right!! The Fuji's Jpeg engine is captivating,almost addictive! Enjoy the Silky-Smooth-Output
Astrophotographer 10 Senior Member • Posts: 6,682
Fuji's jpeg engine and white balance is standard for other manufacturers to meet for sure.
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 Zeiss Loxia 21mm F2.8 +4 more
zuiko fan Junior Member • Posts: 47
Ben,
One reason to continue shooting RAW is that you can later use the in-camera RAW developer to redevelop using other film profiles, or sharpness/saturation, etc. inputs.  I have read on this forum of people hooking the camera up to a monitor and doing PP that way, and still having the benefit of RAWs developed by the camera's jpg engine, which seems to be superior to what is yet available through PC-run software.  Loved your Oly pix, hope you're pleased with this camera as well.
Beat Traveller Contributing Member • Posts: 744
I must say I'm very impressed with the camera's auto WB, using the dropper in Lightroom usually only ever pushes the hue slightly in one direction. It does make shooting only in JPEG a real possibility.
 Beat Traveller's gear list:Beat Traveller's gear list
Fujifilm X-E1 Nikon D60 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 18mm F2 R Fujifilm XF 60mm F2.4 R Macro
PeterPrism
PeterPrism Senior Member • Posts: 1,060
zuiko fan wrote:
Ben,
I agree 100% this is a very GOOOOD suggestion, infinite jpg developed in camera.
 PeterPrism's gear list:PeterPrism's gear list
Fujifilm X-Pro1 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18mm F2 R +1 more
Ben Herrmann
Ben Herrmann OP Forum Pro • Posts: 17,410
Never thought about that...good points
Will keep that in mind - that's for sure.  And my admiration for the Fuji X-series of cameras is not at the expense of my love for the m43 field.  I'm firmly entrenched in micro 4/3 end of things.  So between the OMD E-M5, which has impressed me so much - along with some of the other Oly/Panny models - now adding the X-E1 to the mix brings even more capabilities to the table.
North Carolina, USA
link
BillyInya
BillyInya Senior Member • Posts: 1,453
If you nail the exposure and don't want to 'fake' your photos too much there's no need for RAW at all.
RAW is a thing of the past for a lot of us.
 BillyInya's gear list:BillyInya's gear list
Fujifilm X-E1 Nikon D7000 Tokina AT-X Pro 12-24mm f/4 (IF) DX Nikon AF-S DX Nikkor 18-135mm f/3.5-5.6G ED-IF Nikon AF Nikkor 50mm f/1.8D +8 more
jl_smith
jl_smith Veteran Member • Posts: 3,669
Very good to hear this.  I have a used XE1 + 18-55 incoming and I cannot wait!
I'm just like you too, I've used a lot of cameras and never relied on just JPEG, even with my OMD.  Oly's JPEGs are pretty good, but I could still get an appreciable boost in DR and sharpness / noise performance from the RAW.
I have a feeling I'm going to love Astia (?) and Velvia on the EX1, and maybe monochrome (though I will probably stick to Silver Efex 2 for that).
At the minimum, I hope the XE1 will convert me to at *least* a RAW+JPEG shooter  That way, as said earlier, I can use the RAW to convert to another JPEG if I wish.
JL Smith
www.flickr.com/photos/jl_smith
www.clickingwithsmitty.com
 jl_smith's gear list:jl_smith's gear list
Fujifilm X-T10 Samyang 85mm F1.4 Aspherical IF Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
It's not so much about faking the right exposure as having extra options. Actually, the thing I like most about RAW files is their longevity. I've pulled out files I took years ago that looked like crud on the existing conversion programs, and putting them through the latest software is a great way to bring out the scene as I remember it.
BillyInya
That doesn't make sense.
A jpeg image will capture what's there as would a RAW file so I'm not following you.
If you go back to that jpeg image you are not going to see something different over the years.
However, if your "memory" is vastly different to what was actually truly there, say pink with white dots sky and orange ocean then sure, RAW is great for that cause can you work it to give you any fake look you like.
In that case it's not your jpeg's that are failing, it's your memory.
Al Valentino Senior Member • Posts: 4,667
I now the feeling. Its been five momths since my Nikon left the house. I used to shoot raw exclusively but now I shoot jpeg 95% of the time and raw + jpeg the rest. I did put the time into lesrning which film modes I prefer in Different situations and sometimes bracket film modes. Anyway, there are a lot of little things to master like shadow comtrols and DR settings but nce you get that down you an set your camea to get pictures that require almost no exta post work. It is also a pure joy to use and if made photogrpahy fun again.
have you tried the panorama mode yet. That is another nice feature.
 Al Valentino's gear list:Al Valentino's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Rokinon 8mm f/2.8 UMC Aspherical Fisheye +6 more
You misunderstand me. Because the eye is capable of making micro-adjustments by opening and closing rapidly to suit varying light conditions, it has an effective dynamic range of over 24 f-stops (the actual range of the eye when kept open is much lower, but because of the speed of neural processing you don't notice these shifts, you amalgamate them into one 'exposure').
No current digital sensor comes anywhere near this, but both sensors and demosaicing technology are improving over time. Hence, if I attempted to capture a scene with massive dynamic range a few years ago, my eyes would record both high and low key details perfectly but the camera would usually blow highlights and crush shadows. If I'd shot in JPG, that's the photo forever. But I've taken RAW files from years ago and, thanks to improved algorithms in most software, it's possible to push the dynamic range closer to what I actually remember from the day I took the shot, without posterising the colours or making it unbearably noisy.
mcshan Veteran Member • Posts: 3,707
Yeah the jpegs from the XE1 really are good and the kit 18-55 is a good one. I seldom use zooms but this one delivers and I am enjoying it.
wayfarers Regular Member • Posts: 211
Yes, modern JPEGs and RAWs have limited dynamic range when compared to human eye. This is one area which is being improved in the sensors, generation after generation, still a long way to go. However assuming that in camera conversion does its job correctly (and Fuji currently has the best JPEG engine) full dynamic range the sensor was able to record will be present in both JPEG and RAW files. Thus no external software will be able to improve dynamic range beyond what the sensor recorded, unless it extrapolates and guesses. Obviously you are correct if in camera JPEG engine is poor - not the case with Fuji.
...Hence, if I attempted to capture a scene with massive dynamic range a few years ago, my eyes would record both high and low key details perfectly but the camera would usually blow highlights and crush shadows. If I'd shot in JPG, that's the photo forever. But I've taken RAW files from years ago and, thanks to improved algorithms in most software, it's possible to push the dynamic range closer to what I actually remember from the day I took the shot, without posterising the colours or making it unbearably noisy.
mediasorcerer
mediasorcerer New Member • Posts: 6
Ive had one about 7 days now and im prety impressed too, but i still shoot raw, for me it's not quantity but quality, i can't wait to get the new 200-zoom and the 35 1.4 as well as macro later on,
it's a fabulous camera that does a few things really well, just what i need.
Glad you like it too.
I believe the thing is with raw files, post processing options are increased and very fine details show better when magnified.
I guess it depends on what your application is with the photos you take?
Leopr Regular Member • Posts: 313
Hi Ben. That is high praise indeed from a Connoisseur of cameras such as you. It confirms for me that I made a good choice in trading my Oly E-M5 and m43 lenses for the X-E1 and 18-55 kit.
I sometimes miss my E-M5  because I have enjoyed it so much when mt wife and I visited Germany last September but I wish i had the X-E1 with me now that I have experienced the Fuji pictures. However I was pleased with the Oly at the time. Here is a link to mt Flickr sets of Germany in case you are interested.
http://www.flickr.com/photos/leor3/sets
Have a good day with your new Fuji.
Leo Reinhard, Pickering Ontario
 Leopr's gear list:Leopr's gear list
Olympus E-M5 II Olympus 12-40mm F2.8 Canon EF 35mm F1.4L II USM
Ben Herrmann
Re: Panarama mode....
Haven't tried that yet - in fact, I've never used that mode with any of the cameras that have them.  But there's always a first time, y'know!
North Carolina, USA
link
Ben Herrmann
For this 18-55...the term "kit lens", I feel, is inappropriate....
We're all used to the term kit lens as they applied to the inexpensive optics that N, C, O, and P provide with various cameras.  But this 18-55 that Fuji provides with the X-E1 is entirely too good to be labeled a kit lens.  This is the kind of lens that folks normally would shoot for as an upgrade to a "kit lens."
North Carolina, USA
link
Ben Herrmann
Nice pics of Germany - interestingly enough.....
I've never been back.  I was born in Moosburg (Bavaria) in 1949 and we emigrated to the US in the mid 50's.  My father, who was a German Wehrmacht Officer during WW II, and my Mother, who was a secretary with the German General Staff during the War, met and following the war, they elected to emigrate to the "new country" for a new beginning.  We always talked (as a kid) about visiting again, but it never occurred.  As a result, any relatives we had who still lived in Germany, have long since passed on.  I would love to visit Bavaria though and some keen memories are still there of my being raised on a farm.  Heck, at the age of 3 - wearing leather shorts in mid February, I can remember American Tanks rolling through the streets and the US soldiers giving the kids candy - that I can still remember.
But as my father clearly stated when we first arrived in the US, he said, "We are going to be the best Americans we can be.  We will learn the language, learn the history, and be as productive as we can be."  And that's exactly what we did - and we never looked back.  Unfortunately, that is not the case anymore with some of the immigrants coming to the US.  In fact, my father - who was a Hauptmann (Captain) with the Deutsche Panzer Korps in WW II, was one of the only Germany Army Veterans to be able to join a local VFW in Philadelphia in the early 60's because he was so well liked - with the members there making him an honorary member.  He used to walk around with a Phillies Baseball cap on and a cigar and folks loved him.
People always ask me, "wow, for a German, how did you get the name of Ben?"  Well, my full name is Bernd Werner Herrmann - as German a name as one can have.  But there were/are no nicknames for Bernd (pronounced "Bearnt").  So as a kid, other kids started calling me Ben and it stuck.  Of course, kids can be mean, and others called me "that friekin Nazi" because I was German - which wasn't nice, but I learned to ignore it.
North Carolina, USA
link
