Does a "Vivid" setting increase JPEG sharpness??
Started May 19, 2013 | Discussions
Elyharbour
Elyharbour Senior Member • Posts: 1,556
Just been playing with the creative styles on my A57 - Std, Vivid and Landscape. Same scene, same everything (except the style). These were sunny day shots of buildings, boats, railings, signs, etc, about 100-150m away using a 35mm focal length, 1/320 at F8 and ISO100. Vivid gave the most pleasing colour (though not by much), but was sharper at 100% than either Std or Landscape. I didn't alter the settings for each style. They were all at default. Have others noticed this, or was it some strange one-off result I had today?
 Elyharbour's gear list:Elyharbour's gear list
Sony SLT-A57 Fujifilm XF1 Fujifilm X30 Fujifilm X-T1 Sony DT 35mm F1.8 SAM +8 more
Sony SLT-A57
rio911
rio911 Contributing Member • Posts: 973
Re: Does a "Vivid" setting increase JPEG sharpness??
I would have said no, here is a quote from the A77 manual (don't have the A57): "The saturation and contrast are heightened for shooting striking images of colorful scenes and subjects such as flowers, spring greenery, blue sky, or ocean views".
I always use Vivid on my sony cams, and have Sharpness +1 as well.
rio
 rio911's gear list:rio911's gear list
Sony RX100 Sony SLT-A77 Sony 50mm F1.4 Sony 70-300mm F4.5-5.6 G SSM Sony DT 16-50mm F2.8 SSM
Ed at Ridersite Forum Pro • Posts: 17,251
rio
If the contrast is heightened it will generally give the appearance of increased sharpness.
AEH
http://aehass.zenfolio.com/
http://aehass.zenfolio.com/blog
Question: What do you do all week?
Answer: Mon to Fri. Nothing, Sat & Sun I rest!
 Ed at Ridersite's gear list:Ed at Ridersite's gear list
Sony RX100 II Sony SLT-A77 Sony DT 16-50mm F2.8 SSM Sony 70-400mm F4-5.6 G SSM II
Elyharbour
Elyharbour OP Senior Member • Posts: 1,556
Maybe that's what I'm seeing. Actually I added +1 sharpness and +1 contrast to Vivid this afternoon and it looks more like the Std JPEGs after I've tweaked them in LR4. So might be a good setting for me when I want a JPEG direct from camera.
rio911
That's exactly why I use "vivid" as well, I prefer that the camera does its work and produce a "straight out of camera jpg" that does not need any modifications, rather than spend time working on the RAW files.
rio
zackiedawg
zackiedawg Forum Pro • Posts: 25,890
It's a great example of two things: why everyone should find their settings that work for them, because everyone's taste is different; and it shows that JPGs 'straight from camera' doesn't mean you have to give up control over how your photo comes out.
Indeed, many folks here have found Vivid mode to be a slightly better tone curve and nicer color - and then fine tune it from there to each person's personal taste.  I've been using Vivid mode on 5 different Sony cameras: A300, A550, A580, NEX3, and NEX5N.  However the 3 individual controls are often a little different.  My A580 has saturation at -1, contrast at 0, sharpness at 0.  My NEX5N has saturation at -1 and sharpness at -1, with contrast 0.  It's all to personal taste - some like to increase saturation a little more, some find Vivid does good at 0, others like to tune it down a notch.  Same for sharpness and contrast.  And it does make a difference.
Combine the right JPG settings with proper exposure when shooting, and you have complete control over your camera's output, tuned precisely to your preferences and helping avoid any need to post process.
Justin
galleries: www.pbase.com/zackiedawg
 zackiedawg's gear list:zackiedawg's gear list
Sony Alpha DSLR-A580 Sony a6000 Sony Alpha SLT-A68 Sony Alpha a6300 Sony E 18-55mm F3.5-5.6 OSS +24 more
