How to check shutter actuations
Started May 19, 2013 | Discussions
Dylan Johnson
Dylan Johnson Regular Member • Posts: 143
I'm trying so hard and nothing's working. I've tried multiple websites and Opanda with no luck.
I'm using a 50d and windows 7 and using straight off the camera RAW CR2 files and I either get "your camera must not give this information" or cannot find it in Opanda.
Can anybody help me with this?
Thanks in advance.
Canon 50d gripped, 70-200 f2.8L IS USM, 50mm f1.8, 18-55 f3.5-5.6, 430ex II, Carry Speed FS Pro Sling Strap
 Dylan Johnson's gear list:Dylan Johnson's gear list
Canon EOS 50D Canon EF 70-200mm f/2.8L IS USM Canon EF 50mm f/1.8 II Canon EF-S 18-55mm f/3.5-5.6 IS II Sigma 18-35mm F1.8 DC HSM Art
Canon EOS 50D
spacex New Member • Posts: 2
Re: How to check shutter actuations
try this...
connecting the chamber with the usb cable
www.eosmsg.com/eosmsg.rar
corkpix Forum Member • Posts: 85
The shutter count isn't in the JPEG EXIF info. AFAIK, it isn't encoded into the RAW files either.
There are two ways of getting the shutter count from the 50D.
1.  Connect the camera to a computer using a USB cable and use utility software to extract the shutter count.  I have used Gphoto2 on my Linux PC to do this. There are similar utilities for Windows.
2. Install Magic Lantern on the camera. This allows you view the shutter count on the camera LCD screen.
Y0GI Veteran Member • Posts: 5,228
There is also eoscount.com but that will cost you about $2.00.  You go to the website, hook up your camera with a USB cable, pay the fee and get your shutter count.
Another free possibility is EOS Info .  This is a program that you install on your computer and run it to get the shutter count via USB cable.
Yogi
When you get down to the nuts and bolts of photography, the results depend on the 'nut' behind the camera!
See the 'Gear List' in my 'Profile' for my current equipment.
Check out WilbaW's beginner FAQs at - http://snipurl.com/RebelFAQ
 Y0GI's gear list:Y0GI's gear list
Canon EOS 7D Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +2 more
tonyjr
tonyjr Veteran Member • Posts: 5,256
If you are the only owner , you can do a search for shot number like
 tonyjr's gear list:tonyjr's gear list
Canon EOS 7D Canon EOS 400D Canon EF 28-90mm f/4.0-5.6 II Canon EF 35mm f/2.0 Canon EF-M 18-55mm f/3.5-5.6 IS STM +14 more
Dylan Johnson
Dylan Johnson OP Regular Member • Posts: 143
Thanks for all the help guys. I don't want to pay for EOScount, I've tired a lot of websites and they all say my camera won't give them the shutter count. I don't know anything about magic lanturn but ill give eos info a try
elfroggio
elfroggio MOD Senior Member • Posts: 2,536
spacex wrote:
try this...
I wish that DPreview would go back to automatically create links with http addresses, but until then: Would you please use the DPreview buttons to make a "real" link, thank you.
  • Please use #1 for the Internet links
  • Please use #2 for the images links
http://www.sritch.com
Street Photography: The Dogs of Vancouver, BC
Dylan Johnson
spacex wrote:
try this...
This is the answer! Thank you! Very simple, also tells you the firmware and battery life of your camera. My shot count is at 5173.
TANWare Regular Member • Posts: 203
Thanks, this worked perfectly............
Sergey Vasilevskiy New Member • Posts: 14
This is code stolen from eoscount.com and modified in unauthorized way. This is copyright violation and a site banned from Google index. I wish you would do some more research before using and much less recommending illegal software.
Sergey Vasilevskiy
Owner of eoscount.com and all associated code.
skanter
skanter Forum Pro • Posts: 10,355
http://www.magiclantern.fm
Sam K., NYC
 skanter's gear list:skanter's gear list
Adobe Photoshop Lightroom 5 Canon EOS 70D Sony a6000 Canon EF-S 17-55mm f/2.8 IS USM Canon EF-S 10-22mm f/3.5-4.5 USM +10 more
RadGuy New Member • Posts: 2
EOSMSG is a free software download (from China, I believe).  I just tried downloading it and  scanned it with Norton Utilities.  Norton warned me this software contains a virus.   Beware.
jennajenna Senior Member • Posts: 1,298
Sergey Vasilevskiy
chill out: have some stoli.
SDPPM Forum Member • Posts: 61
I use an android app called DSLR Controller . This app cost 7 dollars I think. You go into settings and camera info and the shutter count is diplayed
 SDPPM's gear list:SDPPM's gear list
Canon EOS 7D Mark II
