LX7 external EVF
Started May 18, 2013 | Questions
dpreviewdotcom-user Regular Member • Posts: 101
LX7 external EVF
Stupid question: why would anyone need the external EVF when you can shoot with the built-in monitor?
Panasonic Lumix DMC-LX7
Jack Brandt217 Forum Pro • Posts: 12,471
Re: LX7 external EVF
Because many of us believe it is better to bring the camera up to your eye rather than hold it at arms length in order to see the scene better and hold the camera steadyer like a real photographer. You may or may not see this as important. Many on this forum also believe that a better alternative is a Clear viewer (Google it) which attaches to your camera and does the same thing but is much less bulky, less expensive and affords you the chance to cut down outside light from the .
Jack
carizi
carizi MOD Veteran Member • Posts: 9,225
Wild guess here: you shoot in 100% optimal conditions all of the time?!
I do not.  Sometimes the LCD gets so glary that all I see is my own reflection and have to literally rely on the focus beeping as indication of "nailed" focusing.
 carizi's gear list:carizi's gear list
Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD +4 more
(unknown member) Senior Member • Posts: 2,185
Interesting discussion. The fact of the EVF is the very reason I may opt for trading my RX100 in on the LX7 since I am one of those people who have a terrible time seeing the LCD screen in daylight and have difficulty composing images at arm's length.
JamesD
Happy Snappin'
 JamesD2's gear list:JamesD2's gear list
Kodak EasyShare C663 Kodak DX7590 Panasonic Lumix DMC-ZS5 Panasonic Lumix DMC-FZ70 Nikon D90 +2 more
walkaround Senior Member • Posts: 2,551
Now, is this type of response really necessary? I'm pretty sure one can be a "real photographer" while using the LCD.
Travis
Travis Veteran Member • Posts: 3,188
JamesD
Happy Snappin'
For me, adding an EVF to either the LX7 or RX100 negates the advantage of having a very compact camera.  In that case, I might as well use something bigger with a built-in EVF and articulating LCD.  The whole point of both of these cameras (to me anyway) is having the smallest body possible with the best picture quality and lens possible.  Both cameras succeed in this.
With the LCD brightness turned on Sunny mode on the RX100, it is quite useable even in bright light.  Just prepare to take extra batteries, which are cheap and ubiquitous.  On the other hand, I am quite intrigued by the Clearviewer, which is something I could see myself using on occasion.
For the LX7, I guess the LVF2 is a good option for times when you might want to pop it on when you really need it.  But there's no way I'd leave an EVF or Clearviewer on either of these cameras all the time.
Travis
 Travis's gear list:Travis's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-LX100 Canon EOS 550D Panasonic Lumix DMC-GH3 Canon EF-S 15-85mm f/3.5-5.6 IS USM +4 more
SwatOx Regular Member • Posts: 476
I use the ClearViewer, but only on a sunny/bright day: otherwise there is a lot of guess work on composition. The ClearViewer is really a magnifying glass: more like a large plastic magnifying glass. It won't give you sharpness or anything fancy, but it is a life saver *for me* on sunny days. And I take it off and put in my pocket when not in use. I probably use it 25% of the time, if that. But it is really useful. Of course, the EVF sold for the LX7 is no doubt a lot better -- but it is bulky...and expensive....
 SwatOx's gear list:SwatOx's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GX8 +3 more
Erik Ohlson
Erik Ohlson Forum Pro • Posts: 16,628
Travis wrote:
JamesD
Happy Snappin'
That's the idea - as small and therefore pocketable as Possible.
On the contrary - perhaps you confuse the EVF & the Clearviewer. The EVF is a large lump on top of the camera and undoubtedly gives a good view.
BUT, the Clearviewer takes up very little room, folding flat against the camera back:
It adds about 1/4 inch to the camera thickness right behind the LCD but doesn't actually touch the LCD so it tends to protect it when in a pocket.
Then it folds out for use:
You kook into themagnifying lens just like looking into a Telescope, with your eye right up to the magnifier (and in my case, my thumb ):
And when the right hand is also on the camera, the hands form a nice, dark, "tunnel" which keeps glare off the LCD extermely well, so you can see focus, composition Icons & Histograms very well.
These photos show a CV + a ZS# - I carry my ZS19 in my pocket ALWAYS - and always with the clearviewer attached - I would not have it any other way.
And it costs LOTS less than the EVF.
-Erik
'He who hesitates is not only lost - he's miles from the next Exit.'
www.flickr.com/ohlsonmh/ ohlsonmh@yahoo.com
Mudbug104 Junior Member • Posts: 44
This is only my opinion and reflects what works for me personally.  YMMV
I recently took a photo vacation to airplane museums in Arizona and So. California.  Extremely bright sun was the normal lighting condition. The light is not ony from the sky, but the ground acts like a "reflector" as well.
I had significant issues with trying to use the LCD screen to frame my photos.  I confess to being a serious "frame filler".  Without a viewfinder, using the LCD only, I did manage to cut the nose or tail off a number of airplane pix. I couldn't really see the LCD clearly in these conditions and was often guessing or trying to use other parts of the scene to frame the target of the photo.
The first thing I did after returning home was to order the external viewfinder for the LX7. I like a viewfinder.  I am used to pressing the camera up against my forehead to steady it before pressing the shutter button. It also enables me to get a better hold on this little camera.
Anyway, that's how I roll.
Erik Ohlson
It is a GLASS magnifier.
It ia sharp enough to EASILY see the individual dots on the LCD.
Are you sure you are talking about a folding Clearviewer, and not the early - and now superceded version which slips into the hotshoe? If the camera HAS a hotshoe?
It would take time to remove & re-install it - I just flip it closed as I return my camera - in it's plastic bag - to my pocket, and flip it open as I draw it from my pocket to take a picture, in the same motion as turning on the camera.
I haven't seen the add-on EVF, but I do have 2 cameras with EVFs, and the Clearviewer is at least as good - maybe better, as the image is much larger.
The "Regular" CV does blur the extreme corners a bit which doesn't bother me - rarely are the extreme corners important in a composition & I can actively 'look' for the corners.
HOWEVER, should the corners bother you, get a Premium (slightly less magnification) CV and the corners are just fine.
Recently I was testing some other cameras & I recall looking out the door and seeing some of our wild turkeys displaying, so I went back in, grabbed the ZS19 (for it's 20x Zoom) - and discovered that the Clearviewer was on the other camera! Gadzooks! I couldn't utilize the zoom at all!
That taught me a lesson: ALWAYS have your clearviewer on your camera (and; it protects the LCD, too)
I use mine 100% of the time.
-Erik
danielsonkin
danielsonkin Forum Pro • Posts: 11,708
I have a EVF on my LX and a Clearviewer on my ZS and I love using them both.  They are on the cameras all the time.  Personally, I just enjoy the viewfinder experience.  I have used a viewfinder for over fifty years on cameras, and although I use the LCD on my cameras some of the time, I like how I can better analyze a scene with the viewfinder. As Jack mentioned, I also like the additional benefit of stabilizing the camera in this position. A lot of people (younger?) are so used to seeing the world through an LCD, maybe its just not in their body memory the way it is for us old-timers. BTW, it's not a stupid question.
Daniel
 danielsonkin's gear list:danielsonkin's gear list
Panasonic Lumix DMC-FZ50 Canon PowerShot G11 Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Apple iPhone 6 +2 more
rollingstone Regular Member • Posts: 292
Well, after a bright day in Wine country (Paso Robles area of California), I forked out the $160.00 for the EVF. It was too hard to frame in the bright CA sunshine. Given that the LX7 is so good in many areas, I decided that the external evf is worth it when in bright outdoor situations. I will leave it unmounted and only mount it when outside. This keeps the camera very portable.
 rollingstone's gear list:rollingstone's gear list
Panasonic Lumix DMC-FZ200 Sony Alpha DSLR-A700
Veducci Contributing Member • Posts: 989
Heh,heh,heh.   Obviously, lots of folks are getting some good images holding their cameras at arms length (thanks to Image stabilization) but lets be honest , it conveys an amateurish look if nothing else.  IMO it`s an awkward way to use a camera especially when there are better alternatives available for most higher end compacts.
Of course the LCD at arms length works good enough for most folks snapping pics in most situations  but an EVF or Clearviewer offers a solid advantage.
The clearviewer (or EVF) definitely allows the user a solid 3 point stabilization  ( vs extended arms )which is a huge advantage when shooting in low light situations at slower than usual shutter speeds.
 Veducci's gear list:Veducci's gear list
Samsung NX3000
Travis
Here's how I would respond to this. First off, we're all different with different eye sight which therefore give varying abilities to see an LCD screen even at its brightest setting. Furthermore, I noticed on the Panasonic videos on YouTube that Charlie Waite (famous English landscape photographer who frequently uses the LX cameras in his workshops and his own photography), makes use of the external EVF. He carries it in his pocket and when the situation calls for it, he puts it into the hot shoe. Sometimes low level shots are made much easier with this EVF which I believe is articulating. Carrying the LX in one pocket and the EVF in another is no real problem but being unable to see the LCD screen clearly is.
JamesD
Happy Snappin'
Daniel
And herein lies, perhaps, one of the reasons for varying acceptance of the EVF - age. My eyes are not what they once were and I have considerable difficulty seeing the LCD screen in daylight. In addition, stabilizing the camera against my cheek rather than holding it out at arm's length helps when I compose. I'd also add that decades of photography using various slrs (all with viewfinders) has made using a camera without a viewfinder somewhat awkward for me. The expense of the external viewfinder is really of little importance given the low cost of the LX7. By the time you factor in the added cost, you're still under the cost of my RX100 and now have a viewfinder and a slightly faster lens.
JamesD
Happy Snappin'
Erik Ohlson
Travis
JamesD
Happy Snappin'
I don't want to beat this to death - some will say I already have
Before I found the CV, I had my own device - an old Kodak slide viewer with the diffuser removed:
That required carrying it in another pocket opening and aligning it with the camera each time it was used - each step very minor, but it resulted in many missed shots.
When I saw the Clearviewer, with all the mounting problems solved, I was sold and now - some 5+ years later, I still am.
Like so many, after 60 years of shooting with a viewfinder, arm's length just puts me off - although with Panasonic's super OIS - and the high shutter speeds I get as a bonus when shooting wide open (with ZS19) - camera movement is non-existent.
I much prefer the larger "EVF" which the CV provides to the small EVF of my FZ18, and flipping the CV open and closed concurrent with turning the camera on & off is just 'second nature'.
Placing something too large for a trouser pocket on a camera, or fixing it to the camera every time is - to me - just too much trouble.
Naturally, "YMMV" but I actually think that the objection to the CV is that people just don't realize that it is held right up to the eye, like a telescope - in my illustration, my thumb is flexed a bit too much - the thumb and finger are pressed next to the eye much like a rubber "eye cup" on a telescope or dSLR.
Even at our local camera club, people try to look through it at arm's length!
Anyway, Cheers,  -Erik
NIK11 Senior Member • Posts: 2,827
As others have said, some people like to frame and carefully compose their shots. Even the best LCD's are not good enough for this in harsh lighting. Try framing when you are surrounded by bright refeflective surfaces and facing directly into low sun - impossible. EVF's are not perfect, but much better than LCD for this.
Also, most people over the age of 50 need reading glassses, meaning without them the LCD is often out of focus even in ideal lighting. Donning and doffing glasses whilst shooting on the hoof is a pain. An EVF with dioptre adjustment solves this problem.
Nick
James Pilcher Veteran Member • Posts: 8,436
Let's rephrase the question...
Why would anyone need the built-in monitor when you can shoot with the external EVF?
I'm only pointing out that the question can be asked from opposite ends of the spectrum, in the very same way answers will come from opposite ends of the spectrum.
I put the EVF on my LX7 as soon as it arrived. I have never taken it off the camera except to prove to myself that the locking mechanism works and disengages properly!
Jim Pilcher
Summit County, Colorado, USA
 James Pilcher's gear list:James Pilcher's gear list
Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 75mm F1.8 Fujifilm X70 Olympus PEN E-P5 +7 more
Chris62 Contributing Member • Posts: 582
Re: Let's rephrase the question...
LX7 is my first camera without viewfider and what I can say ... working without one is very difficult in some lighting conditions.
I want to buy this external LVF2 (also for GX1) but I wonder what I can do withi it if the next camera will be uncompatibilie with this type - the problem is in the price in my country LVF2 costs over 300$!!!!
It means it isthe  second LX7 for people who can buy it in this price.
When we look to MFT market the new Olympus is equipped in newer better viefinder (optional) so probably Panasonic will create the better one soon.
 Chris62's gear list:Chris62's gear list
Panasonic Lumix DMC-LX7 Samsung NX30 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +2 more
Sometimes shooting without viewfider is very uncomfortable.
LX7 is my firs camera without viewfinder and the last.
In theory there is an option to buy external LVF2 but it costs over 300$ in my country
In such price people buy LX7 camera even cheaper...
Additional issue is the question if this viewfinder will be useful on the next camera.
So in sunny days I use my old NX10 (APC-C CSC.)
The problem is when I need to take small camera with zoom and there are  very bright lighting conditions - than working with the screen only is terrible.
