Wet leaves on a rainy day. (3jpg)
Started May 18, 2013 | Discussions
Aidan Gibson Regular Member • Posts: 109
All Pictures taken on the Bleach Bypass Filter, which I think can be quite fun to use.
 Aidan Gibson's gear list:Aidan Gibson's gear list
Pentax K-5 IIs Sigma 50mm F1.4 EX DG HSM Pentax smc DA 55-300mm F4.0-5.8 ED Sigma 30mm F1.4 EX DC HSM Pentax smc DA 18-55mm F3.5-5.6 AL WR +1 more
samomatic Junior Member • Posts: 30
Re: Wet leaves on a rainy day. (3jpg)
Really cool effect, very interesting toning with good contrast.
So this was shot on 35mm film? Thanks for sharing!
www.samomatic.com
math guy Senior Member • Posts: 2,421
I like them... especially the third one.
-- Joe S.
Why do they call it a "building"? It looks like they're finished. Why isn't it a "built"? ~ Jerry Seinfeld
http://www.pentaxphotogallery.com/artists/josephschmitt
 math guy's gear list:math guy's gear list
Pentax K-50 Pentax K-3 Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 70mm F2.4 AL Limited +6 more
Aidan Gibson OP Regular Member • Posts: 109
Thanks and no, I took them on my K-5iis with the 35mm f2.8 macro which is a beautiful lens!
cheers
-- Joe S.
Thanks a lot!
RedFox88 Forum Pro • Posts: 24,571
For wet leaves, you really have to get in closers and get ontop of them.  Shooting at this angle does not make for anything special.  And a P&S camera often does better for more DOF and the ability to get it real close again with that more DOF to get everthing in focus.  The major reflection in the last one is one that would have me delete it and learn from it.
Tan68
Tan68 Veteran Member • Posts: 5,542
What's to learn ?
I agree with the leaves being larger and filling more of the frame.  This might be the same for dry leaves and degree of filling varies by what the photographer is up to, I guess.?  Detail would be easier to see if they were tighter.
Using a P&S camera can be a good tip.  The APS-C has a little more DOF to offer; the aperture used was pretty moderate. I figure she wants to use the Pentax.
A thing that can help, I think, is to look carefully at the axis of the leaf and where you would want focus to fall.  Just the same with anything, if the subject runs from side to side in front of the camera, more will be in focus than if it runs away from the camera.
With leaves, I figure holding the camera level is not such a worry.. as long as there is nothing that makes orientation look weird.  No bit of horizon or grass or branch (Picture 2) or etc.  So turning the camera some way or other can help put focus on the right spot.
As far as hot spots or bright reflections, I have wondered if white paper or tissue could help.  I haven't tried it outdoors, but I think it could help if you have a hand free to use paper/tissue as a dodge.  I took a picture of a slimy slug.  I like the picture but it is quite hot in spots.  Later, I thought the tissue might help but it hadn't occurred to me at the time.
Since I am not a leaf and slug hunter, I haven't tried it myself...  Just a thought to try.  Maybe a white umbrella could be easier to manage than paper.  Who knows.  Are these good recommendations for learning ?
 Tan68's gear list:Tan68's gear list
Phase One Capture One Pro +1 more
Tan68
Well, a polarizer would help with the reflection and that might be the better route...
The tissue idea wasn't to cast a shadow so much as to only somewhat cut the light and diffuse it even on an overcast day.  I do need to try it..  I have used it indoors with constant light sources when taking pictures of reflective things.
Anyway, hope the ideas help.
Thanks for the tip.
I tried it but had to stop because of really bad rain. haha will try it again tomorrow.
* I figure he wants to use the Pentax.
cheers
Tan68
Yeah, I thought about this after it was too late to do anything.  I figured I would keep the foot where it was and see how far I had stuffed it.  Glad some bit of all that ramble was of some interest...
cheers
Aquaroid
Aquaroid Contributing Member • Posts: 806
Well done!!! Like the colors!
dpr://galleries/489967037/photos/687959
By the rules I can't point out that my camera has an R letter in its name and the number ONE, but, hell, we all must obey the rules...
 Aquaroid's gear list:Aquaroid's gear list
Sony Cyber-shot DSC-R1 Canon PowerShot SX260 HS Fujifilm X-A1 Fujifilm XC 16-50mm F3.5-5.6 OIS Fujifilm 50-230mm
